Old 02-18-2014, 11:32 PM   #113
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Originally Posted by spitfire481 View Post
I had it without the screws but there were gaps and it was just too loose. I tried some tape but there are only two small spots where you can tape it and it just wasn't enough
Go get some heavy duty 3M mounting tape that use for exterior will help holding that gap.
Old 02-18-2014, 11:54 PM   #114
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I have my own body shop. I have just about every tape/adhesive you could imagine lol. You just can't hold the pressure required with the small area available. At least on mine that is.
Old 02-19-2014, 12:21 AM   #115
sirsol66
Drives: 2013 FRS- Hot Lava
We'll that kind of sucks, having to drill into the bumper is a bit of a deal breaker. Would it be possible to attach a thin plate with studs on it to the back, and them tape that to the bumper maybe? Just a random thought.
sirsol66 is offline   Reply With Quote
Old 02-19-2014, 12:24 AM   #116
spitfire481
Drives: 2JZ FRS
You can drill two holes about 2" under the factory points and it will screw into your grille. That way the bumper is untouched. If you ever take it off just replace the center grille and be good to go
Old 02-19-2014, 12:30 AM   #117
FRSHunter
Drives: Asphalt FRS
Wait I thought the OEM one screw into the grille? I already have two holes from my license plate, could i possible just screw through that for the mounting point on the lip?
FRSHunter is offline   Reply With Quote
Old 02-19-2014, 12:34 AM   #118
spitfire481
Drives: 2JZ FRS
The holes on the trd lip want you to screw into the bumper. I believe they would be the same holes as if you already had an OEM front plate bracket installed prior. If you have no holes in your bumper and don't want to drill any, you can go lower and drill into the center grille. The grille mounting works, but going into the bumper made for much tighter fitment
Old 02-19-2014, 12:39 AM   #119
FRSHunter
Drives: Asphalt FRS
Thanks for the info! Just debating on getting it and shaving it down a bit for the foglights to fit proper.
Old 02-19-2014, 12:40 AM   #120
spitfire481
Drives: 2JZ FRS
The ABS material is very easy to sand down while test fitting
Old 02-19-2014, 12:49 AM   #121
aSaki
Thx for the pictures. Looks like I've shaved to what you have there right now. And yea you can't mount it without screws. I had the same problem, tried taping but it won't close up tightly. I guess I have no choice but to screw it now lol. Btw was weather strip used at the bottom of the foglight bezels? Name:  uploadfromtaptalk1392785292721.jpg
Sent from my SGH-T889 using Tapatalk
aSaki is offline   Reply With Quote
Old 02-19-2014, 12:49 AM   #122
FRSHunter
Drives: Asphalt FRS
What would you recommend as the best method to shaving it down? Sandpaper with various grits? I plan on test fitting it before handing it to a paint shop.
Old 02-19-2014, 12:51 AM   #123
aSaki
And I guess the only problem with mine is my car is white so all the imperfections shows up instantly like you see at the bottom of the lower grille it doesn't cover up fully. Do you have that problem?
Old 02-19-2014, 01:25 AM   #124
spitfire481
Drives: 2JZ FRS
80 grit by hand will sand down the edges nicely. Then finish off with 180. Do not use either of those grits on the main surface though. Only to shave the edges down
Old 02-19-2014, 01:27 AM   #125
spitfire481
Drives: 2JZ FRS
Mine covered completely up to the oem grille/bezel. With the apr ducts one side is basically perfect, one side has maybe a 1-2mm gap. It's not enough for anyone to see once on the car since my color is dark anyway. Put a line of black vinyl or electrical tape below the bezel before installing the lip. Nobody will be able to notice a small gap since the white won't be showing
Old 02-19-2014, 10:43 AM   #126
aSaki
Yea. I was thinking either dipping it black since I have some left over
Bayson R lip kit review Cjymiller Cosmetic Modification (Interior/Exterior/Lighting) 59 07-06-2017 02:23 PM
Weather strip/Rubber seal for bodykits FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 05:34 AM
Weatherstrips for bodykits FRSHunter Exterior Parts (Aero, Lighting, Etc.) 1 12-14-2013 10:15 PM
Who has Bayson R Lip kit? Cjymiller Northern California 21 09-29-2013 10:52 AM
Bodykits....Bodykits....Bodykits.... FT-86GOD AUSTRALIA 78 08-08-2012 10:44 AM
