#43 | |
Drives: 2017 Camaro 1SS
I'm gonna be looking at mine Friday when I'm off work |
#44 | |
Drives: Subaru BRZ Limited
but, If you do test please let us know. It would be greatly appreciated.
#45 | |
Any issues like this? |
#46 | |
#47 |
Drives: 13 BRZ Limited 6MT GBS
I've disconnected the seat airbags and reconnected them without adverse effects (I did have the battery disconnected the whole time however) but cannot speak for the steering wheel airbag.
#48 |
I didn't replace the airbag I just took my seats out to do sound deadening. Friday I'm just going to be checking the wiring under the airbag... good idea - I don't have to actually disconnect the airbag just get behind it. Thanks
#49 |
Drives: 2013 WR Blue Limited Manual BRZ
#50 | |
They exit near the key hole (whatever) under the steering column cover. The cover comes off without taking your steering wheel off: it's actually split in two, a top half and a bottom half. There are two black screws holding it on. You have to turn your steering wheel left and right to get to them. Once those come out, pull on the steering column cover from the bottom and downwards while at the same time pressing against the hairline crack you see down the length of it. The clips should undo when you press and pull, there are about 4 of them. Cover will drop down. The connector on the steering column looks exactly like the one under the airbag, it's white with 3 pins with wires being used.
#51 |
#52 | |
Drives: 2013 SWP BRZ
![]() I was messing around the other day on the way home with places to mount the buttons, and I honestly don't think theres a great spot for the buttons on our current wheel setup right now. I haven't taken the buttons and looked for a mounting location yet in my car though. |
#53 | |
The second connector on the column actually has 12 pins, not sure where the other 2 go |
#54 | |
I'm not sure what type of pins those connectors take but I have a few lying around. Maybe I'll try to mount it up to there. Just need to figure out a location for the buttons. I still think I may hard mount it somewhere outside the steering wheel though. |
#55 |
Drives: 2013 Black Brz Premium 6sp
thanks to NALC and Dave (the rear cam harness) guy I was able to do this. you are no longer the only radio button guy and I topped your installation with a more factory look.
#56 |
heres a pic
| TRD Steering Wheel | DSOmegaX | Cosmetic Modification (Interior/Exterior/Lighting) | 26 | 04-30-2016 06:15 PM |
| WTB: Stock steering wheel (wheel not airbag) | mobybrz | Interior Parts (Incl. Lighting) | 2 | 09-11-2014 02:23 PM |
| steering wheel help | ft86me | DIY (Do-It-Yourself) Guides | 3 | 04-22-2013 04:26 AM |
| Different Steering Wheel?- NOT? | BRZfan | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 03-07-2013 09:01 PM |
| Volume control with Bluetooth audio | finch1750 | Electronics | Audio | NAV | Infotainment | 5 | 02-17-2013 04:48 AM |
