Old 02-08-2014, 11:31 AM   #29
samfrs
Custom User Title
Drives: FRS
Originally Posted by FT-86 SpeedFactory View Post
Sorry, Spyder does not offer those for sale without purchasing the whole kit.
Damn! I was going to ask the same thing.
samfrs is offline
Old 02-08-2014, 12:08 PM   #30
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
Originally Posted by raytrix View Post
Does this kit come with the panel for Series 10 and Monogram guys with JDM headlight leveler? Been looking for ages for someone to release a kit for us neglected guys.
Is it just me or does the pics they provided have a bezel that would fit 10 Series and the headlight leveler? There is 4 slots which are needed for the 10 Series. Dimmer, Headlight Leveler, Trunk Release, and Fog Light ON/OFF.
This kit comes with an actual fog light button, rather than others I've seen where the button goes where the foglight leveler switch would go.
FiRStsc10n is offline
Old 02-08-2014, 12:36 PM   #31
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
I really like these because they have the button to turn off, but I also like the Diode Dynamics ones as well. what should I do. ?
MotegiRacing - TRD Racing -OemAudio++- Michellin Pilot SuperSports- Greddy -FiveAxis - SparksScion - BlueBat Overlays -Pioneer -SWIFT Engineering Sports- Evasive Motorsports-
SoCAL
rikdrt1 is offline
Old 02-08-2014, 12:37 PM   #32
OURO3OROS
Drives: 2013 Asphalt FR-S
**New Product** Spyder Fog Light Kits for FR-S!
Buy both and let us know!
OURO3OROS is offline
Old 02-09-2014, 03:58 AM   #33
VacantSky
The Angry Brit
VacantSky's Avatar
Drives: 1991 E30 318iS
for $20 more you could get the fog light kit from nigel which comes with the factory stalk with fog light button. Then instead of using the harness just use the wiring that's already in the car form factory.
The plug that the turn signal plug goes to has an extra wire which is unused. And it gets power to it when the factory fog light stalk is installed and fogs turned on.
All I did was put a female connector in my plug to hit that unused pin and tap into the ground for the turn signal. The relay and fuse for front fogs are installed in the fr-s from factory.... so much easier than running a new harness and relay/fuse/etc... completely oem. And all factory parts - bezels, stalk, and lights... just disregard the harness. cut off and use the H11 plugs to tap into the car
just my 2 cents
VacantSky is offline
Old 02-17-2014, 12:39 AM   #34
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
Does anyone have pics of these post-install yet?
Ammunition is offline
Old 02-17-2014, 07:23 PM   #35
PNW FRS
PNW FRS's Avatar
Originally Posted by immaculate View Post
Given that these are glass, hopefully the quality has improved. Non-OEM is always a risk with these types of products, usually winds up costing more through replacements in the long run.
The description from OP is that lenses are polycarbonate...
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline
Old 02-17-2014, 07:39 PM   #36
immaculate
immaculate's Avatar
Drives: 2017 Audi S3
That post has been edited...Pretty sure it said glass at one point in time, or I'm just going crazy, which is well within the realm of possibility.
immaculate is offline
Old 02-17-2014, 07:45 PM   #37
junior_reyez
Drives: 2014 Scion Fr-s FireStrom
Check these out guys! Just in from Spyder are their new Scion FR-S Fog Light Kits available in clear, smoked, and yellow housings!
Spyder Auto's fog lights use high quality materials and are designed with contemporary aesthetics in mind. Not only are they an upgrade over the stale look of the OEM lights, they are also more functional. They are guaranteed to catch the eyes not only automobiles enthusiasts but casual lookers as well.
The new OEM-quality foglights have a polycarbonate lens, for high clarity and overall quality. They are H11 size. The installation is nearly plug-and-play: just install the H11 Foglight Wiring Harness, pop off the old turn signal bezel, and install your new fog lights and bezel! Simple as that. Installation will take 30-60 minutes, on average.
This is the only kit that includes a separate button and bezel to activate your fog lights. Giving you the option to run the fog lights whenever you want them, not just when you have the headlights activated. Plus, you get that OEM-like feel with the kit, just like the fogs were installed from the factory.
Includes:
- Two H11 polycarbonate-lens foglight assemblies, (interchangeable left and right), with 55w H11 halogen bulbs
- Two OEM-style fog light bezels
- One H11 foglight harness with connectors
- One connector harness for fog light activation button - One bezel for fog light activation button
- One stainless steel mounting hardware set
Clear Housing
Smoked Housing
Yellow Housing
Button and Interior Bezel
I Want to thank ya speed factory ! i got my evo3 and greddy intake and i love it ! very fast shipping and amazing products! keep up the amazing work ! i will be ordering these on payday
junior_reyez is offline
The Following User Says Thank You to junior_reyez For This Useful Post:
FT-86 SpeedFactory (02-17-2014)
Old 02-17-2014, 08:00 PM   #38
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
You guys are correct. We originally thought these were glass, as the general description stated so. After closer examination and a heads up from a customer of ours, we found that they were not glass.
We apologize for the confusion....
FT-86 SpeedFactory is offline
Old 02-17-2014, 08:10 PM   #39
stueck9356
Drives: 2015 VW GTI SE
Random question, if you leave the fogs turned on 24/7, will they follow control of the headlight stalk? so I can leave the fog switch on, and they will only be on when the headlights come on, but off when I turn the headlights off?
stueck9356 is offline
The Following User Says Thank You to stueck9356 For This Useful Post:
souleffecx (02-18-2014)
Old 02-18-2014, 11:10 AM   #40
FR-Slide
Drives: 13 Whiteout 6MT
A bit confused; why the 4th cut-out on the bezel? I've only got 2 currently (dimmer and trunk), and with the switch it'd be 3.
Considering these, since price is good and they come with yellow housings, but I don't want extra holes in the dash.
FR-Slide is offline
Old 02-18-2014, 11:28 AM   #41
FT-86 SpeedFactory
You would just need to wire directly into the headlight power signal wire with the large harness to do that. You wouldn't even need the switch and bezel at that point.
From the factory, that hole next to the dimmer switch has a factory blank on it. You would remove that from your OEM bezel and install on the new bezel. The Spyder fog light button would then pop into the spot next to the trunk release.
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
FR-Slide (02-18-2014)
Old 02-18-2014, 12:00 PM   #42
FR-Slide
Thanks, at my desk right now and not able to check.
Does the switch supplied light up with the rest of the dash equipment, like the dimmer does? Or only the indicator LED when it's on? And, as asked earlier, does/can this setup trigger the OEM fog light indicator bulb in the dash?
FR-Slide is offline
Fr-s Spyder tail light wiring. ettorres15 Southern California 4 04-17-2017 12:31 PM
Sonar/Spyder Tail Light Issues Mr.Jay Cosmetic Modification (Interior/Exterior/Lighting) 5 11-10-2015 07:29 PM
Sonar (Spyder) Tail Light Unboxing and Review Yruyur Cosmetic Modification (Interior/Exterior/Lighting) 28 10-20-2013 03:42 PM
Spyder Pink Light Issue? iJason Cosmetic Modification (Interior/Exterior/Lighting) 3 09-08-2013 09:55 PM
New Product Release: StopTech Big Brake Kits for Scion FR-S and Subaru BRZ !!! PRO Import Tuners Brakes, Suspension, Chassis 16 08-24-2012 07:59 PM
