Old 02-17-2014, 01:41 AM   #21435
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Nice find, I tightened it by hand while under there just to be sure I would say it's very close to that. Now we know for the next one as that's basically really close to the motor mounts. (Torque Spec wise )
Sent from Spaceball 1
Excellent.
Btw, I'm noticing the difference the springs & rear bushing bring (the mount bushing I'm told isn't a noticeable improvement except where the mount would otherwise flex under hard conditions).
The rear bushing brings a firmer gate "lock" feel, and the springs tighten up the side to side play.
Worth it for the effort put into each item installed.
Easiest was the transmission mount bushing, by far, after we realized we didn't need to unbolt the 4 collar bolts. Then rear bushing, and then springs.
Springs wouldn't have been so bad if it wasn't for the tight space the bolts were.
Whoever said the spring install was easy (*cough* @Ninjin *cough* ), was wrong. Putting the driver's side spring was easy. Wedging a 10mm hex wrench in there & tightening the bolt down was just tedious. The passenger side with the detent & needing a 27mm deep socket... That was the most frustrating part of the whole install process.
I'm on my phone so if I make mistakes, blame Sportsguy83
^GT5 Replay Photo Mode^
Old 02-17-2014, 09:15 AM   #21436
EZWood
BAMF
EZWood's Avatar
Originally Posted by SirBrass View Post
Excellent.
Brent seems pretty mechanically inclined and he's probably done the install a few times. Get a couple more under your belt and you'll probably be telling people that it is an easy install.
Old 02-17-2014, 10:10 AM   #21437
jeffsides
AZ FRS 86
jeffsides's Avatar
I'm pretty sure he installed it on Randwells car at my house on a tech day. I think it was the same day Randwell spilled transmission fluid all over my garage floor. Took a while to get the smell out
Sent from ARIZONA86 HQ
@AZFRS86
Old 02-17-2014, 10:17 AM   #21438
Cross
It's the Mad Cow
Cross's Avatar
The main problem with the install was that the one requiring the 27mm Deepwell liked to fall back in and even wiped down it had enough in just the right stop to make it fall back out after starting it. So it kept falling back into the socket until we put something in there to keep it from falling back. After that it went in without issue. Which reminds me I think I left that rubber piece in the socket
Old 02-17-2014, 10:23 AM   #21439
SirBrass
SirBrass's Avatar
The main problem with the install was that the one requiring the 27mm Deep well liked to fall back in and even whipped down it had enough in just the right stop to make it fall back out after starting it. So it kept falling back into the socket until we put something in there to keep it from falling back. After that it went in without issue. Which reminds me I think I left that rubber piece in the socket
Yeah. And also notice the fairly humorous way I put it about Brent being "wrong". It was mainly a bitch to put back in as @Cross said.
Just like the oem rear bushing was easy to remove, but putting the kb one in was a bit tedious (though "there's always time for lubricant!" lulz)
It was all worth it, though. Now just waiting on my anarchy motive shift knob to come in.
Old 02-17-2014, 10:29 AM   #21440
Cross
It's the Mad Cow
Cross's Avatar
Old 02-17-2014, 04:26 PM   #21441
EZWood
BAMF
EZWood's Avatar
So I noticed I've had a little more consumption with mobile one over Toyota oil
Old 02-17-2014, 04:58 PM   #21442
Cross
It's the Mad Cow
Cross's Avatar
Saw a Silver BRZ I believe it was on the way into work today.
Old 02-17-2014, 06:26 PM   #21443
Bonks86
Drives: Gt-86
Hey guys I have a few things for sale
PW JDM tri-strut bar (red) $250
stock wheels and tires 7k on them $450
Injen intake (polished) $200
Racer X Adjustable Lower Control Arms (powdercoated red) $350
pm me if you are interested
Bonks86 is offline   Reply With Quote
Old 02-17-2014, 06:28 PM   #21444
Shad0ez
Shad0ez's Avatar
Drives: 2013 Raven Black
Damn you! You know why I'm mad
Shad0ez is offline   Reply With Quote
Old 02-17-2014, 06:39 PM   #21445
Bonks86
Drives: Gt-86
lol
Old 02-17-2014, 06:53 PM   #21446
jack43
jack43's Avatar
Drives: Sterling Silver BRZ Limited MT
On broadway going west? Maybe me
jack43 is offline   Reply With Quote
Old 02-17-2014, 07:05 PM   #21447
Cross
It's the Mad Cow
Cross's Avatar
I forgot all about looking up a price to offer you, that seems like a good price though for them. I am coming to the Pav's on Saturday if someone else doesn't beat me to them then I want them!
Yes I believe so, I work on Broadway just before Swan.
Old 02-17-2014, 07:08 PM   #21448
Bonks86
Drives: Gt-86
sounds good, I will make sure I am there
