#365 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
I could be wrong but I believe it's Aero. The smoother you can make the front end of the car with less "openings", the less drag it'll create at speed.
#366 |
Drives: 2010 MS3
#368 |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Anthonytpt (02-06-2014), JS + BRZ (02-06-2014) |
#369 |
Drives: 2010 MS3
#370 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
Have you seen any signs of OEM components beginning to crack or that are likely to require reinforcement for significant track work - with or without the addition of:
– increased power – R-comps – cage/rollbar – stiff springs and/or bars – hard/solid motor/transmission mounts, suspension bushings/bearings – tracks where the line requires significant use of med-to-high curbs, and – anything else that contributes to placing serious stress on the chassis? In that context, how many track days are on the car(s) whose chassis you've had eyes on that lead to your observations? I'm considering this car as an occasional DD/track toy, and would be coming from a professionally-built and maintained early-00s Grand-Am racecar that I've been using for open lapping, time trials, and occasional instruction. At present, I'm in the process of determining what the running costs will be to prep and maintain one of the twins, and have found your posts to be a wealth of useful information. Thanks! |
#371 |
Drives: 135i
is changing front sway bar only good for the FRS and BRZ? I see alot of s2000 only change the front one.
#372 |
Drives: Satin White BRZ Limited
I plan on buying a set of either Bilstein B14 or KW V1's. I plan on doing 1-3 track events a year. Do these coilovers handle better than OEM? Also, at what ride height can you lower the car before handling diminishes?
#373 |
They will perform better than OEM, but don't slam the car. The lower you go, the less compression travel you have. Drop based on the spring rate you choose.
#374 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | shattered_memory (02-17-2014) |
#375 | |
Either our car or Robispec's car has seen the most seat time, and neither have the failures you are concerned about, yet. We've only run tires up to 100TW, but Robi's car has seen Hoosier A6. The AutoX cars I follow have also ran Hoosiers, and have not had weld failures. Replacing rubber with delrin/sphericals/poly is always good though
#376 |
Drives: Toyota 86 RED!
Hi Mike, I've got a track day on Friday: what hot temperature should I run my tyres at? 205/55 16" Michellin Pilot Sport 3's
#377 |
| The Following User Says Thank You to CSG Mike For This Useful Post: | JouMaSeHoes (02-18-2014) |
#378 |
Drives: Avensis 2.2 diesel
Which is better track car for newbie, mkIV n/a Supra or GT86/FRS/BRZ?
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
