go_a_way1
Old 02-17-2014, 12:02 AM   #3683
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
As the 300 on e85 seems to be the highest performance this system can currently deliver, I eagerly await the results. From shiv's 250 vs 300 dyno on same dump pack(I believe), the 300's curve is smoother, and makes a consistently larger amount of power above ~3500 rpms. The motor may cost more, but the compressor should be similar price(material/labor), of course that's not considering market adjustment.
The only benefit I can see to the 250 is that since the 300 uses more power, it might deplete the dump batteries quicker. I think the 250 is supposed to last 2 min of continuous use before it needs a recharge.. so maybe the 300 would last for 1.30? I have nowhere to use it for that long without letting off, so as long as the price is comparable I have wait for the 300.
The dual dump packs seem to be worth between 5/10hp through the whole range and cost is what; (extra dump pack/new batt tray/relocation cables/inline fuse: ~$150) best value of power vs $ of any other mod out there IMO.
E85 should be worth between 10 to 20hp. According to Sojhinns dyno of 91 vs E85 it's an increase of ~16hp/15tq, also through the entire rpm range, probably less compared to 93. But from what I understand, if you have the OFT, the cost is a tank of gas and 5minutes to reflash your maps
Put it all together: Shiv's dyno showed the tq300 on single dump pack making 216hp/192tq, so dual dump pack and e85 should add between 15 to 30hp. So I would estimate 238hp/210tq. vs stock of est: 178hp/142tq (91oct pulled from page 1)
so +60hp/68tq
the cost:
panel filter $40
Phantom $1550 + TQ300 upgrade ??
Batteries/relocation $280
OFT/OFH combo $1015
auto on/off relay $5
estimated total: $2890 + shipping/tq300 upgrade price.
$3000 / 60hp = $50 per horse.
Though I am still curious to see a dyno of this setup with and without OFH
Target70 is offline   Reply With Quote
Old 02-17-2014, 12:48 AM   #3684
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by fenton View Post
Shiv has dual dump packs with battery relocate to trunk.
He also has the tq300 and I think is testing with e85
Sent from my HTC One using Tapatalk
Engine bay:
4 batteries!
Aux charger!
Yep! Just finished installing the trunk mount (stock) starter battery, secondary dump packs and aux charger. Much thanks to Rob for getting those goodies out to me for testing. Did some driving with the new electronics (and the TQ300) and I can immediately see the difference in both charging/recovery time and voltage under boost. Before, with the TQ300, voltage would drop to 19.0 during long 4th gear pulls to redline. Now it doesn't drop below 21v. Top end power seems stronger but we will now for sure when I visit the dyno later this week. That should give the new batteries more time to break in. Regardless, it feels pretty darn good.
Tomorrow morning I'm off to Vortech engineering to pick up the test car that I dropped off there last week. I'll be spending the day on their dyno, dialing it in with their calibration engineer. Should be driving home later in the nigh or the next day. Then it will get an OpenFlash header installed and retuned. So perhaps next week we should be able to do some good SC vs SC comparison test. I don't think there will necessarily be a "winner" since they are so different in just about every way. But comparing them will likely bright to light their relative strengths.
Cheers,
Shiv
Shiv@Openflash is offline   Reply With Quote
The Following 8 Users Say Thank You to Shiv@Openflash For This Useful Post:
8686 (02-17-2014), BRAWL (02-17-2014), DAEMANO (02-17-2014), fenton (02-17-2014), Gums (02-18-2014), nlowell (02-17-2014), radroach (02-17-2014), Robftss (02-18-2014)
Old 02-17-2014, 01:26 AM   #3685
Thatruth2001
Drives: Raven FR-S
This ESC experiment has just entered into a new phase.... Man I gotta say the refinement of the system and install has gone to a whole new level since if got the kit last August. In the last 5 months Rob has refined the control unit, created the aux booster, refined the heat management system (x2), developed a drag reduction system, created the battery holder and has a new compressor in testing.... Additionally, people have home brewed other solutions (pug's oled monitor and jpit's dual dump pack). What the hell is next?
Who wants to crowd fund Rob $10k to design an intake for a dual ESC system?
Thatruth2001 is offline   Reply With Quote
The Following 3 Users Say Thank You to Thatruth2001 For This Useful Post:
DAEMANO (02-17-2014), radroach (02-17-2014), Robftss (02-18-2014)
Old 02-17-2014, 02:31 AM   #3686
Target70
Target70's Avatar
Thatruth2001:Who wants to crowd fund Rob $10k to design an intake for a dual ESC system?
not a bad idea, but it would take away from one of the key features, dual system would probably require new clutch, axles, fuel, and cooling upgrades... not necessary a bad thing, but not the simple ~1-2 hour bolt-on anymore. On the other hand, it would be nice to have a level to upgrade to if you "outgrew" the base system, vs scrapping the whole thing and going the more conventional route.
also, everyone seems to relocate battery to trunk. (I would like to see Shiv's new setup). Has anyone just removed the bottom seat cushion from the back seat, behind the driver and mounted one there? I think a slim battery would fit on the floor behind my seat (I'm 5'10''). But a stock sized optima should fit in the seat bottom. You could even make a nice cubby/box to cover that whole side of the back seat. and let's face it, if you are going to have 1 passenger in the back, they won't be sitting behind the driver... if you need to drive 3 passengers, then maybe someone will have to ride in the trunk.
The Following User Says Thank You to Target70 For This Useful Post:
clintavo (02-17-2014)
Old 02-17-2014, 02:55 AM   #3687
DAEMANO
Time Traveller
Finally completed my TQ250 24V install today. @Robftss kit with @shiv@vishnu 's tune with help from @WRB5titch, and @Sojhinn. I had a bit of an ordeal mostly due to my own rusty wrenching chops. I'll write that whole thing up manana.
For now, I will say this. After properly installing the kit, blasting all over So Cal for hours, and coming home and checking the logs everything written in this thread by Phantom ESC owners/testers, Rob and Shiv themselves are true.
1. The whole system installed in 2 hours.
2. Done properly the hardware install is EASY
3. Done properly the software install is EASY
4. The car is instantly transformed. This is no exaggeration.
5. The car gets even better (quicker, and faster) as the batteries condition, warm up and the ECU learns.
6. Rob and Shiv's customer service has been second to none on this board. I don't know how they do it. GMTA or something.
7. Can't wait to add back e85+ a header for 20-30whp cause I'm greedy and not afraid to say it.
8. For the performance, price and ease of installation, nothing touches the Phantom ESC + Open Flash Tablet tune. Nothing even comes close.
That's about it for now. Plenty more pics and impressions coming up. Oh and thanks @VR46 for generously providing relays to us new Phantom Supercharger owners. What a dood!
The Following 8 Users Say Thank You to DAEMANO For This Useful Post:
Blu-by-U (02-18-2014), Bu-Tang (02-18-2014), fenton (02-17-2014), Gary in NJ (02-17-2014), normancw (02-17-2014), Robftss (02-18-2014), SloS14 (02-17-2014), WRB5titch (02-17-2014)
Old 02-17-2014, 02:57 AM   #3688
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
After blowing the tube you were good?
Installed Mods:
Old 02-17-2014, 03:21 AM   #3689
DAEMANO
Time Traveller
Haha actually it needed a little more than a blowjob.
I dun goofed!
Lesson 1. Always dress and secure your wires before driving the car.
All is better now
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 02-17-2014, 03:21 AM   #3690
Sojhinn
Sojhinn's Avatar
Ouch .
Installed Mods:
Old 02-17-2014, 03:25 AM   #3691
DAEMANO
Time Traveller
Ouch .
IKR - Let's just call it ring rust.
Notice all of the lovely zip ties and wire loom in the final installation.
Never again.
Old 02-17-2014, 03:27 AM   #3692
Sojhinn
Sojhinn's Avatar
Never again.
Btw- there are two holes on the passenger side that can help hold the looms. Check out my install picture for the locations.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Old 02-17-2014, 03:32 AM   #3693
DAEMANO
Time Traveller
Attachment 67398
Thanks!
Tomorrow morning, it's YAZTA! (yet another zip tie attack) I don't think this will catch on.
Old 02-17-2014, 07:36 PM   #3694
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Took a cue from @Sojhinn and cleaned things up under the hood today.
Also removed the front bumper and shortened the intake snorkel as suggested by @shiv@vishnu
VR46 is offline   Reply With Quote
The Following 3 Users Say Thank You to VR46 For This Useful Post:
DAEMANO (02-17-2014), SloS14 (02-17-2014), Sojhinn (02-17-2014)
Old 02-17-2014, 08:10 PM   #3695
fenton
That looks great! I need to do cleanup in spring
fenton is offline   Reply With Quote
Old 02-18-2014, 09:38 AM   #3696
VR46
are you Jeff Vader?
VR46's Avatar
Thanks!
Is this some kind of zip tie-based board game?
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
