Old 02-16-2014, 05:10 PM   #1
bayank
Drives: 2014 BRZ Limited
Bump start in a manual trans?
Is it possible to bump start the MT BRZ with the push to start ignition? I always thought that was one of the advantages with MT if your battery dies, but how does that work with the push to start ignition?
bayank is offline   Reply With Quote
Old 02-16-2014, 05:15 PM   #2
fistpoint
Drives: Supercharged Golf Cart
I would like to think it works the same way...if it doesn't, then there is yet another reason to not have this useless and most likely future problematic feature.
fistpoint is offline   Reply With Quote
Old 02-16-2014, 05:18 PM   #3
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
It's hardly useless or problematic. It's just a different way of doing the same thing a chipped key does.
^GT5 Replay Photo Mode^
Old 02-16-2014, 05:23 PM   #4
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
It will have the same issue most modern cars do; you need enough power to get the ECU running before popping the clutch will do any good. 100% dead battery is a no go. If you have enough to turn the ignition on, you should be able to. This goes for key or keyless models. Couldn't even pushstart on my 96 miata when the battery couldn't run the ECU. Car has no idea what to do to run the engine.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-16-2014, 05:36 PM   #5
bayank
Say you have enough juice to unlock, power lights etc but not the starter... Would you press the start button twice to get in ACC mode, and start rolling down a hill and pop the clutch in 2nd or 3rd?
Old 02-16-2014, 05:41 PM   #6
993Fan
993Fan's Avatar
Drives: 2014 DGM BRZ MT
Not that this should matter to anyone, but the FM says this vehicle shouldn't be push started...
993Fan is offline   Reply With Quote
Old 02-16-2014, 05:43 PM   #7
SirBrass
SirBrass's Avatar
That'd work, as all the pushbutton start does is the same thing that holding the key in start mode does: crank the starter motor till the engine turns over, it's just that all you need to do is press the button once while holding the clutch in, instead of holding the key in start while holding the clutch in.
Old 02-16-2014, 05:49 PM   #8
Ozzman
Drives: old
Every owners manual I've ever seen says that.
Ozzman is offline   Reply With Quote
Old 02-16-2014, 05:50 PM   #9
bayank
good to know, wise guy
Old 02-16-2014, 05:54 PM   #10
bayank
I'm pretty sure engaging the clutch will disable the starter though. I don't see how holding the start button will help while rolling
Old 02-16-2014, 05:59 PM   #11
SirBrass
SirBrass's Avatar
kind of. but if you're already rolling that may not be the case
Old 02-16-2014, 06:47 PM   #12
fstlane
fstlane's Avatar
Drives: BRZ Limited
This is exactly how it works. I had to push start my car at the last autocross because I killed my little lightweight battery by leaving the radio on (stupid move). I just popped the clutch in 2nd gear with a couple of people pushing and it fired right up.
fstlane is offline   Reply With Quote
FRS/BRZ Manual Trans Fluid shellslinger Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 131 11-02-2017 10:44 AM
Auto trans manual shift question.... Tromatic Engine, Exhaust, Transmission 18 05-24-2015 10:00 PM
fs: Perrin trans mount and whiteline trans bushing RWD_FR-S Transmission and Driveline 1 01-02-2014 05:34 PM
FS: 1st 86 DGM/Asphalt Scion FR-S (Manual Trans) Neurytic Cars for Sale/Trade 3 05-22-2013 11:54 PM
Got a line on two unclaimed BRZs (manual trans) Tainen BRZ First-Gen (2012+) — General Topics 0 07-05-2012 10:40 PM
