Old 02-15-2014, 10:02 PM   #15
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by whitefrs View Post
has anyone done this at home?
how hard is it?
im thinking about getting this
http://www.turboboostleaktesters.com...%22/Categories
but not sure if its easy to do it
We did this quite often in the old DSM days.
It's pretty easy actually if you have the know how for mechanics.
Basically just take the hot side IC piping off the compressor housing. Go to your local auto parts store and buy an engine block freeze plug, or metal cap that is the size of the IC piping. Also buy a rubber tire valve stem. Drill a hole in the cap in the center the size of the valve stem, clean the burrs, and pull the valve stem through it so that it sticks out away from the side you're going to connect/clamp into the IC piping.
Then just pressure the system like filling a tire, but make sure you have a gauge of some sort either on the air valve or showing from the car so you dont go above like 20 psi.
Then check for audible leaks, use soap for pinholes, re-clamp anything loose, etc. Common issues, PCV leaks, loose IC piping, vacuum line cracks or pops off, ziptie stuff, you get the idea.
Oh and throttle body seals, those are pesky too sometimes.
Ironsquid is offline   Reply With Quote
The Following User Says Thank You to Ironsquid For This Useful Post:
jamesm (02-15-2014)
Old 02-15-2014, 11:04 PM   #16
mrk1
Drives: Sterling BRZ Ltd
I've welded up various sized plugs. Some have small barbs and some have tire full valves. I can pressurize the system through the valve and then I plug in a boost gauge on the barn to see what pressure it is at. The just soapy water to and look for bubbles.
It's a MUST before going to the dyno, don't want to burn time finding a leak
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-17-2014, 11:21 PM   #17
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Gonna build one this weekend with @jamesm that little fkr vacuum hose under the TB and manifold popped off on both ends.
Cant wait for the FBM manifold, will give me an excuse to triple ziptie e'erthang
jamesm (02-17-2014)
Old 02-18-2014, 07:26 AM   #18
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Make me one please n thank u lol
I love boost!!!!!!
Old 02-18-2014, 08:16 AM   #19
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
pm address I'll send you one
Old 02-18-2014, 08:18 AM   #20
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Really bro?
Thank you so much
FBM brothers for life haha
I love boost!!!!!!
Old 02-18-2014, 08:54 AM   #21
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
PSA: Clamping EVAP hoses under Intake Manifold, the easy way..
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Ironsquid (02-18-2014)
Old 02-18-2014, 08:59 AM   #22
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Yeah I just moved the ac comp out of the way and ziptied them. I'm not comfortable with it because it's pretty tight quarters under there and hard to cinch the ziptie.
It held this morning when I went to work though. All 13.5 PSI and no traction through 3rd.
Sportsguy83 (02-18-2014)
Old 02-18-2014, 09:02 AM   #23
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Boost Pressure Leak Tester
I did clamps cuz at 13 psi that zip tie didnt work
I love boost!!!!!!
Old 02-18-2014, 09:05 AM   #24
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
I love boost!!!!!!
How in the world did you clamp that? It's underneath and behind the TB, only a midget.. hey wait a minute, are you a midget?
Old 02-18-2014, 09:06 AM   #25
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
When i had my intake manifold out.
Thats the only way lol
And trust me not even a midget cant do it with just the AC compressor out buy maybe a fairy can
I love boost!!!!!!
Old 02-18-2014, 09:10 AM   #26
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
@Sportsguy83
David do you know any fairies?
Old 02-18-2014, 09:13 AM   #27
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
I love boost!!!!!!
Isnt u the one that lives close to mickey mouse lmao
I love boost!!!!!!
The Following 2 Users Say Thank You to whitefrs For This Useful Post:
Ironsquid (02-18-2014), Sportsguy83 (02-18-2014)
Old 02-18-2014, 09:23 AM   #28
Sportsguy83
Drives: Limited BRZ
@Sportsguy83
I know a very pretty fairy that goes by the name of @KAB-FRS :belly roll:
Need an Innovate Tester- Very Special Deal Pure Automotive Mid-Atlantic 19 06-29-2013 08:02 PM
Need a tester in Philadelphia Area Uniquedetail NY / NJ / CT / PA 3 02-08-2013 09:36 PM
Visconti Tuning Stage 1 Tester #3 (I think) ruskymx Engine, Exhaust, Transmission 46 09-15-2012 04:29 AM
Toyota’s chief tester? The boss Axel Other Vehicles & General Automotive Discussions 7 12-30-2009 09:44 PM
