Old 03-09-2012, 05:12 PM   #141
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Originally Posted by quik1987 View Post
The Cayman R runs on 19", I don't see it having problems with handling/performance/ride quality. Does it cost more? Sure.
Greddy FR-S with 19"
I'll probably go with 18" in the end though.
Now just change out the cheap looking headlights with some HIDS and this is the perfect FR-S!
I will probably go with 18" too though but some nice Volk TE37SL in 18X9.5
tripjammer is offline   Reply With Quote
Old 03-09-2012, 05:15 PM   #142
slaxx
Drives: '13BRZl, '14FiestaST2, '10Insight2
Would there be any performance improvement beyond potential handling in the lowered springs and lower profile rubber? Wouldn't the body kit and heavier (?) wheels hurt agility?
Looks like Heavyweight Stage 1 to me..
slaxx is offline   Reply With Quote
Old 03-09-2012, 06:37 PM   #143
bneale
bneale's Avatar
Drives: Scion FR-S
Coming from an Autocrosser perspective, lowering the car has 2 effects. On one hand, it does lower your center of gravity minimizing weight transfer and body roll through corners. But you have to keep in mind, by lowering the car, you're also changing the geometry of the suspension. So it may or may not help with handling depending on what you've done to the car.
Your also correct about weight. Any more weight on the car and you'll decrease your power to weight ratio and hurt acceleration overall. But it totally depends on where the weight is. In my opinion, heaver wheels are worse then a body kit. The reason why is because the wheels will add more to "unsprung weight" and the weight will be at the corners of the car. The body kit adds to "sprung weight" meaning that its weight carried by the suspension. The wheels are not carried by the suspension and effect the car more in terms of balance.
But, that being said, a larger wheel diameter allows for a wider rim. In autocross or any form of road racing, you typically want the widest rims you can get because the wider the rim, the wider the contact patch is on the road. IE, you can put a 225 tire onto a 7 inch rim. But it would work better on a 7.5 inch rim simply because that extra half inch makes the contact patch bigger.
EDIT: I should also mention that by increasing the size of the wheel, you will decrease your final drive ratio of your transmission. This is not really a good thing because it takes more effort from the engine to move the car forward from a stand still. In reality, the best wheel to choose for racing is the smallest diameter wheel which clears your brakes and the largest width. For me, this would be something in the 16inch range with hopefully 7.5 inchs of width or larger.
A lower profile tire simply reduces "flex" in the sidewall of the tire. Overall this won't really do much except for make the ride a little more harsh. Most people I've seen who Autocross never use low profile tires. The 2 common tires I've seen people run are the Hankook RS-3's or Toyo R1R's. Everyone says the Toyo's are the best.
Also, compare a Toyo R1R in 205 size to a RS-3 in 225 size and they are almost exactly the same. I don't understand how but the Toyo's seem large compared to others.
bneale
bneale is offline   Reply With Quote
The Following User Says Thank You to bneale For This Useful Post:
q335r49 (02-21-2019)
Old 03-09-2012, 07:20 PM   #144
Dragonitti
Really? Who the hell cares if someone else puts 19's on their FR-S. It's available for them to do that, quit whining already..geesh!
I will be curious to see how many fusing over it, are actually going to be tracking their FR-S since they keep screaming about the weight of the wheels.
And the 19 on a 200hp car? Makes since..IF you plan on leaving it at 200hp, which most will not.
Old 03-09-2012, 07:23 PM   #145
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
I like "18's.. Idk, they just feel like the right size imho
Snoopyalien24 is offline   Reply With Quote
Old 03-09-2012, 07:28 PM   #146
bneale
bneale's Avatar
Drives: Scion FR-S
Really? Did you even read the guys post?
He asked what sort of performance benefits lowering springs would have and if larger wheels will hurt agility. I answered him in the best way I know how.
And yet you somehow think I told him not to put 19inch wheels on his car? Did I specifically say this? No.
If he wants to put 19 inch wheels on his car, I don't care. But he asked a question about performance and I answered it.
For the record, you can have 4 17inch wheels which way the same as 5 15inch wheels. In terms of racing, you tell me which size is better for weight purposes! I know this because I've done a pile of reseach for wheels and Autocrossing. For the longest time I was going to Autocross a new Ford Fiesta.
bneale
Old 03-09-2012, 11:19 PM   #147
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
^ hey man are you Rhythmnsmoke? Im Fancy from CStC...
anyway.... I didnt even read much in this thread.... but all i gotta say is let people do what they want to the car... ALREADY people are saying what you can or cannot do to the car...
are we all supposed to have the same exact car because thats how someone said were supposed to build it?
Kuzuri is offline   Reply With Quote
Old 03-09-2012, 11:23 PM   #148
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Drop it fellas, whatever argument your having just stop. If it isn't relevant or debatable to the topic, stop. or i will make you stop. Iv deleted related party posts. Keep it clean, watch your cool.
THANKS!
WingsofWar is offline   Reply With Quote
Old 03-10-2012, 08:34 AM   #149
Dragonitti
bneale
In case you missed what I wrote, I said I wasn't talking to him because I didn't quote him.
shhh....don't tell no one.. lol...but yea +1 on your comment. It's their car, leave them be. Parts are available for those who want 19....and YES someone WILL want 19's.
Old 03-10-2012, 08:35 AM   #150
SeaWall
Drives: Eclipse 2002, Honda Civic 2005
i do not think the headlights are coming with the five axis package. maybe a scion option. i wish i could swap those base headlight with some BRZ dlr headlights.
SeaWall is offline   Reply With Quote
Old 03-10-2012, 08:44 AM   #151
MiguelAE86
Drives: NB Miata
Those wheels: Must. Have. Now.
MiguelAE86 is offline   Reply With Quote
Old 03-10-2012, 08:52 AM   #152
Kuzuri
__(X)__
Kuzuri's Avatar
well i thought it was your car in your sig but wasnt sure.... could tell if the fenders WERE CF or not from that small of a pic... and didnt remember if you had the big Ptuning decal on the side
Old 03-10-2012, 09:06 AM   #153
Dragonitti
Yep, CF fenders and the PTuning decal is semi-new, but not around here anymore. Going to get my dated carbon re-clear coated, and then she will be pic worthy of some close ups
Old 03-10-2012, 09:47 AM   #154
Kuzuri
__(X)__
Kuzuri's Avatar
i have a shot of your car from exposed but I never ended up eploading any of those photos... maybe ill get to work on em and upload them someday... i remember your car was super dirty though... lmao
five axis edition fr-s, five axis edition frs, five axis fr-s, five axis frs, five axis scion fr-s, five axis scion frs, fr-s forum, fr-s forums, frs forums, scion fr-s forum, scion fr-s forums, scion frs forum
Scion FR-S OFFICIALLY REVEALED (Details, Specs + Live and Press Photos) Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 857 05-30-2012 03:57 PM
FR-S Officially Listed on the Scion Site goshamrocks13 Scion FR-S / Toyota 86 GT86 General Forum 32 10-07-2011 11:52 AM
Gurnade / Tjin Edition Scion FRS-GT feldy FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 08-30-2011 08:05 PM
Amazing Redbull Scion FR-S Soapbox Car by Five:Axis / Import Tuner Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 34 06-15-2011 12:37 PM
TRD edition of FT-86 scion FRS photoshop - HMD HMD FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 05-31-2011 09:51 PM
