Old 02-14-2014, 07:56 AM   #71
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
It is not the ECU. I have a retina Mac (SSD, usb 3.0, i5 proccesor) and I flash between 3-4 minutes on VMware, Parallels or Bootcamp.
@nelsmar flashes with his 8.1 tablet in 1 minute and 35 seconds.
On ecuflash?
AdrianG is offline   Reply With Quote
Old 02-14-2014, 07:57 AM   #72
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by AdrianG View Post
On ecuflash?
On Ecutek, but my point is, it doesn't matter if its Ecuflash or Ecutek,
IF the ECU was the limiting factor, then my flash time and nelsmar time would be the same
Old 02-14-2014, 08:00 AM   #73
AdrianG
I don't have any Ecutek experience so I won't speak to that. I believe Ecutek is able to do partial writes though, whereas EcuFlash does a full erase and full write with every flash. Ecutek uses their own bootloader whereas Ecuflash uses the factory loader. I believe that's why differences would appear.
If you were flashing from exactly the same map, making exactly the same changes, and the write times were so significantly different I would believe it.
Old 02-14-2014, 08:15 AM   #74
Sportsguy83
Drives: Limited BRZ
No, Ecutek does not do a partial flash. Ecutek flashes a full map everytime and all their flasher are of exactly the same size.
Old 02-14-2014, 08:36 AM   #75
AdrianG
Then I stand corrected. I only have experience with EcuFlash as I said earlier.
The Following User Says Thank You to AdrianG For This Useful Post:
Sportsguy83 (02-14-2014)
Old 02-14-2014, 09:55 AM   #76
jamesm
We should compile a list of laptops that are known to have good flashing times.. since they seem to vary quite a bit by model. I wouldn't mind picking one up if I knew that it would flash like lightning .
The Following 2 Users Say Thank You to jamesm For This Useful Post:
Draco_PR23 (02-14-2014), Sportsguy83 (02-14-2014)
Old 02-14-2014, 10:13 AM   #77
Sportsguy83
Drives: Limited BRZ
I'll make a thread right now
(Give me a call when possible).
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Draco_PR23 (02-14-2014), jamesm (02-14-2014)
Old 02-14-2014, 10:47 AM   #78
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
I'm speaking ONLY on theory here but I'd say the biggest factor off speed when it comes to flashing a ROM is probably your machines storage device (SSD, HDD)
I say this because @Sportsguy83 said his friends tablet flashes pretty quick. I'm sure the tablet is running a very decent SSD. Since the ROM that is being flashed is coming from the main storage device, this makes sense. Unless, the ROM that is being flashed is cached in the RAM. Then this is a different story.
I'm just thinking aloud. I could be completely wrong. I just upgraded the SSD in my Macbook recently to a much faster one, so I'll have to see if I notice a difference when I flash next. That won't be for awhile though.
Bg8780 is offline   Reply With Quote
The Following User Says Thank You to Bg8780 For This Useful Post:
Old 02-14-2014, 11:02 AM   #79
Sportsguy83
Drives: Limited BRZ
I definitely agree the SSD plays a huge part (but not all). I went from a regular HDD old laptop and that flash was ridiculously slow....
Then I went to a Mac with SSD and lowered it to 3-4 minutes.
But now I want the cake and keep it at about 1 minute with a SSD modern Windows device.
Old 02-14-2014, 11:10 AM   #80
DJCarbine
Thupercharged
DJCarbine's Avatar
FWIW I had a thinkpad twist with an i5 and standard harddrive. Flash times did not improve/change when I switched to a 120gb Samsung EVO 840 SSD. Everything else was faster, but flash times felt the exact same
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
Old 02-14-2014, 11:13 AM   #81
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I have a MBP and I was thinking to upgrade to a SSD with Bootcamp to improve the flash times.
If not I might consider a cheap Windows laptop.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 02-14-2014, 11:17 AM   #82
Sportsguy83
Drives: Limited BRZ
I think its a combination where a regular drive and slow processor will be way slower than SSD and fast/new processor.
I'm not too happy of my MBP performance, but it will honestly depend on how much do you plan on flashing. If you want to flash say once a week, it's not a big deal at all. But I am flashing 4-5 times a night right now fine tuning driveability and then dyno time and for that its a PITA to wait inside the car 3-4 minutes everytime.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 02-14-2014, 12:06 PM   #83
olorin
olorin's Avatar
Drives: GBS Premium
Originally Posted by SirBrass View Post
And it takes forever to flash with windows on a Mac. Ask @nelsmar
Nope, about a minute and a half. Its no different than running windows on a pc. Its also pretty easy to create a windows partition on an existing OS X partition.
olorin is offline   Reply With Quote
Old 02-14-2014, 12:10 PM   #84
olorin
olorin's Avatar
Drives: GBS Premium
Not so sure an SSD would really make a difference. Its not doing a lot of disk activity to flash the ECU. CPU and bus speed are more important.
Laptop + Tactrix cable + BRZEdit personal - $400 Dodzilla Engine, Exhaust, Bolt-Ons 5 02-14-2014 04:30 PM
SOLD: Toshiba C855D Laptop swift996 Miscellaneous 0 01-10-2014 06:06 PM
Carbon Fiber Laptop Sleeves - Introducing DFWcomposites to ft86club DFWcomposites Announcements, Contests, Giveaways 4 08-12-2013 02:42 AM
Carbon Fiber Laptop Sleeves - DFWcomposites DFWcomposites Miscellaneous 3 08-12-2013 02:42 AM
ALIENWARE LAPTOP brichard0625 Off-Topic Lounge [WARNING: NO POLITICS] 68 11-06-2012 01:01 PM
