Old 02-13-2014, 11:35 PM   #21337
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Originally Posted by evo4g63 View Post
Whelp, time to go a different route with the car as the mod bug has bitten me. The Innovate Supercharger is going to be for sale along with injectors, pump and a few other things. I would rather sell locally so I don't have to ship. If anyone is interested pm me for details.
Whats next?
FR-Shadow is offline   Reply With Quote
Old 02-13-2014, 11:35 PM   #21338
BobbyBlue86
BobbyBlue86's Avatar
Drives: Subaru BRZ
OMG How much are you selling it for?
Edit: Haha 86th post....
BobbyBlue86 is offline   Reply With Quote
Old 02-13-2014, 11:46 PM   #21339
BRZ_Driver
BRZ_Driver's Avatar
Drives: 2013 Subaru BRZ
If you want some more in-depth reading about Mobil 1 in Subaru engines, check out the oil analysis threads on the BITOG forums. Mobil 1 generally does the "worst" (no modern oil is truly bad, it's just not as good). Motul tends to have the best reports.
Good to know. I use Mobil one in all of my cars except the Z where I use Valvoline VR-1. Time to stock up on Motul!
Christian
1977 280Z(Fidelity) L28ET powered at 10psi
2013 Subaru BRZ w/6M(Vader) BWR Turbo Kit in the works
BRZ_Driver is offline   Reply With Quote
Old 02-14-2014, 12:26 AM   #21340
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
PM me
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-14-2014, 12:28 AM   #21341
Lischynski
Weendog
Lischynski's Avatar
Drives: 2014 Scion FR-S
Ok, so I'm apparently like Cole Trickle from Days of Thunder. I can drive a car, but I'm clueless when I'm underneath the damn thing. I needed a set of tools, so I went to pick up a ratchet set. Figured that would be enough to take off the stock muffler and add an axle back. Maybe it was, for anyone that knows what they are doing, but I just felt like I wasn't getting anywhere. Would an impact wrench be a good idea?
Keep in mind that I'm seriously an idiot when it comes to this stuff. I tried to use one of those small monkey wrenches to hold the nut because the second socket wrench that came with the set I bought didn't fit beside the exhaust tube, and there wasn't an extension for the larger wrench.
Yes, that bad.
Also, where can I get the OEM 14mm exhaust bolts?
Old 02-14-2014, 12:38 AM   #21342
4azcats
4azcats's Avatar
Drives: 2013 Subaru BRZ Limited (WRB)
We can do another Saturday at my house.
Sent from Spaceball 1
Need to come by and get my OFT and update. I'll be by around noon if that works.
4azcats is offline   Reply With Quote
Old 02-14-2014, 12:44 AM   #21343
Cross
It's the Mad Cow
Cross's Avatar
Yes, that bad.
I would recommend some WD40 and a pair of Channel Locks so you can remove the Rubber Hangers. Grease them and then use the Channel Locks to pull the rubber off the mounting points.
As for needing bolts I always liked Ace Hardware because they just seem to have a great selection and you can normally take them the bolts you removed and they can help from there as you mentioned not being sure what you are doing.
I will say that most new exhaust systems come with everything you need. If not that's a little strange but either way it should not e hard to do at all.
Old 02-14-2014, 12:45 AM   #21344
Cross
It's the Mad Cow
Cross's Avatar
Come on by its ready and waiting for you.
Old 02-14-2014, 12:48 AM   #21345
Lischynski
Weendog
Lischynski's Avatar
It did come with everything I needed. I'm just struggling with the stock bolts. I'll try an extender to fit the larger socket wrench (I want to say it's a 3/4 wrench).
I've heard the hangers are the tough part. I can't even get that far.
Old 02-14-2014, 12:51 AM   #21346
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Yes, that bad.
Where you located? If you don't mind coming to surprise I can help you out (I'll gladly except tips ). I have 2 lifts (Soon to be 3 that will make quick work of your little project). PM me if interested.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 02-14-2014, 12:54 AM   #21347
Cross
It's the Mad Cow
Cross's Avatar
I would suggest before you remove all the bolts you get some of those off. With the exhaust free moving it can be harder unless you are on a lift then it can be helpful.
If you want come down Saturday and you can get all the help you like.
But yes those hangers can be a pain that's why I recommend WD40 aka Lube... lol.
Also its great to have a socket set but did you get a few standard wrenches too? (Metric in size of course) Not all nuts just spin off on exhaust and I cannot remember if the stock exhaust is just studs and nuts or bolts and nuts which would require you to hold both sides.
Old 02-14-2014, 12:56 AM   #21348
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Y'all willing to help out a Phoenix guy get some stuff under his car put in as well on Saturday? (mtec springs, rear shifter bushing, and transmission mount bushing)
^GT5 Replay Photo Mode^
Old 02-14-2014, 01:00 AM   #21349
Lischynski
Weendog
Lischynski's Avatar
@Cross It is a nut and bolt, I tried and failed at the holding both sides part.
Also, any payment will be in beer currency. Thanks for the offers guys. I'f I can't do it on my own tomorrow, I'll hit one of you guys up that are willing to help.
Thanks!
Old 02-14-2014, 01:08 AM   #21350
Cross
It's the Mad Cow
Cross's Avatar
Of course come on down, I personally would like to see the results of that bushing set on a stock shifter.
Thanks!
Beer is fine although lately I have been paid a little to often (my fridge is full of beer...) so bring soda, Dr. Pepper or Pepsi etc. Nothing Diet... lol
