Old 02-12-2014, 09:43 AM   #3361
Wepeel
Drives: '13 BRZ Ltd
Originally Posted by FR-S Matt View Post
Ecutek will squeeze out a bit more as long as its custom tuned. Probably not a drastic difference, but not every car is the same like the OFT maps work. If anything, a few horses here and there and torque.
Heat should not be a concern with it wrapping up front. There's tons of room in this engine bay. The only time I've seen it get extremely hot was in the 100 degree summers, or a turbocharged engine. I'd recommend the ceramic thermal coating if heat is a concern. It really helps a lot.
Ah, I just relooked at the dyno and it looks like they have a MOTEC and ECUTek tune on there and they are basically identical. I initially thought they only showed a MOTEC tune dyno.
Oof. This + ceramic coating makes this one $$$ piece. But torque comes along 1000 RPM sooner than the competition... this seems like it would be a fun and controllable/predictable car to drive at the limit.
Decisions, decisions.
Wepeel is offline   Reply With Quote
Old 02-12-2014, 10:00 AM   #3362
tennisfreak
Drives: 2018 BMW M240i
Originally Posted by Ryan@Nameless View Post
The header is headed out today for some additional testing. Will have dyno results for both untuned and tuned (via Motec M1) available at the end of this week/early next week.
EcuTek Tune information to follow shortly after.
-Ryan @ Nameless
@Ryan@Nameless do you still plan on giving us untuned results?
Thanks!
Old 02-12-2014, 11:57 AM   #3363
MysteryMachine
MysteryMachine's Avatar
Drives: 2014 SWP BRZ, 2002 Bugeye OBS
Originally Posted by cdrazic93 View Post
What is the fine for having no cat in WA? Im contimplating the PTuning kit and everyone keeps telling me to not even run at cat in the header...
#WashingtonProblems
Would you be going catless? Our cars have 2 cats, only one is in the header so if you go nameless header you would still have a cat. I had aftermarket header + high flow cat + exhaust for over 10 yrs in Washington. As long as your ECU checks they pass you (which I would argue is stupid but that's another topic).
BUT if you show up for emissions testing with no cat they might smell it etc and then proceed to a visual inspection. You might be in trouble at that point if you can't show them something that at least looks like a cat. I don't know if they fine you if you don't have one - but if you DO have one and they think its not regulation (or your ECU throws a code) they give you a paper which says you have to go to a shop and have them certified they fixed it OR have spent a certain amount of money attempting to get it fixed. That said - I never followed the instructions just went home and either reset the ECU and drove it long enough for the sensors to be ready and tried at a different testing facility or I put the stock back on and did he same reset + test at different facility. I haven't lived there for 4 yrs but I haven't heard of them changing any rules in that regard.
MysteryMachine is offline   Reply With Quote
Old 02-12-2014, 12:17 PM   #3364
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
In the low mount PTuning kit, I would run a no cat header. Don't want any debris sucking into the turbo. Is there a hi flow cat I can shove somewhere after the turbo? In essence would it be like a (catted) turbo back exhaust?
Old 02-12-2014, 12:19 PM   #3365
w00t692
Drives: 2008 Civic Si
wut? What the heck are you talking about debris getting sucked into the turbo?
Ah, talking about running an exhaust manifold that has a cat on it, yeah that would be silly with a turbo, though i don't see why you wouldn't be running a manifold that doesn't have one that comes with the kit...
w00t692 is offline   Reply With Quote
Old 02-12-2014, 12:22 PM   #3366
mad_sb
Drives: 2013 Asphalt FR-S
Gotta pay attention to the cam sensor harness on the passenger side, the cat my fa20 header melted part of the harness before i caught it. Clearance can be tight where the pipes dip under the head to run back to the over pipe, not saying this will be an issue with the nameless, but it's something to keep an eye on.
Old 02-12-2014, 12:23 PM   #3367
mad_sb
kit does not come with one, it is designed to bolt to the stock manifold IIRC.
Old 02-12-2014, 12:36 PM   #3368
FR-S Matt
I may need to look in my own bay again just to see where it comes close. I was considering a long tube at one point. Even when I happen to go turbo, that is something I will have to consider as well. JDL has a very similar design on their EL version 3. Nameless parts have always had pretty awesome fitment. Rarely does something go back to them warped.
Old 02-12-2014, 01:18 PM   #3369
w00t692
Wow, that's quite awesome. Must have a decent flange on the stock header then.
Old 02-12-2014, 01:29 PM   #3370
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The kit I'm referring to is the PTuning kit. They use the stock header. But cats are known to degrade, rather not risk having particles be sucked into the turbo when I can remove that cat and put one behind the turbo instead.
Old 02-12-2014, 01:37 PM   #3371
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Is the first batch getting ready to ship soon? Anymore assembly porn?
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 02-12-2014, 02:04 PM   #3372
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
It's generally a bad idea to have a cat in the up pipe. Subaru used to have them in the uppipe till I think MY 2005, when they moved both cats to the downpipe.
^GT5 Replay Photo Mode^
Old 02-12-2014, 02:14 PM   #3373
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Thanks!
This.
Old 02-12-2014, 02:20 PM   #3374
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Where would I stick this cat then? I'd rather not have it be in front of the turbo risking the possibility to suck in debris from the cat after it degrades.
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
