Old 02-12-2014, 12:07 PM   #3347
xxscaxx
Drives: 2013 SWP BRZ
I think i'm going to go baller status and replace mine with ARP hardware. lol
xxscaxx is offline   Reply With Quote
Old 02-12-2014, 12:47 PM   #3348
xjohnx
Grip>Slip
xjohnx's Avatar
haha. turns out i have to pull my blower again to verify those two strip seals between the IC and the supercharger are seated correctly. I figured that i may as well replace them with quality replacements while i've got it out.
Also going to pull the manifold when I do it this time to see if that method is any easier.
Old 02-12-2014, 12:50 PM   #3349
xxscaxx
Damn really? Is that what Bill said to do?
Those strip seals stayed in there perfect for me when I applied some dielectric grease on them. I had to pull the sc off after i placed it down the first time, and they were stuck on there nice. Never moved.
It may be easier, but I didn't want to go through the trouble of disconnecting all the fuel lines, then the injector covers, etc. But, it probably would have been faster seeing as those 2-3 bolts gave me a huge problem getting them off since they were in there tight, and you only have so much room with an allen key.
Old 02-12-2014, 12:54 PM   #3350
OrbitalEllipses
Drives: Attitude
Originally Posted by Ryan86 View Post
After majority of people saying a OCC does nothing and is just a bling in the engine bay,
A mate sent me this, thought worthwhile sharing. Sorry for pic format was sent to me like this.
Who said catch cans do nothing? A properly designed (read: good baffle plate or media) can will absolutely help raise effective octane due to less oil blow by making its way into the combustion chamber...as your mate very thoroughly explains.
Old 02-12-2014, 01:53 PM   #3351
xjohnx
Grip>Slip
xjohnx's Avatar
After switching back to the stock injectors from the DW700's, to verifying the stock injectors were seated properly, i've gotten pretty comfortable with removing the covers, disconnecting the fuel lines and rails, etc. something tells me after that it'll be much easier to verify everything is situated properly.
Do you have pictures of the replacement clamps they sent you?
Old 02-12-2014, 01:54 PM   #3352
evan
Drives: fr-s
Why did you switch back from the DWs?
evan is offline   Reply With Quote
Old 02-12-2014, 01:56 PM   #3353
xjohnx
Grip>Slip
xjohnx's Avatar
My tuner preferred them, the car runs much better on them and i've got quite a bit of headroom before i need more volume (i should be a good bit under the 350whp the stock injectors are good for)
Old 02-12-2014, 02:00 PM   #3354
xxscaxx
good point, having the complete unit off is always the best way to it anyway. I actually at one point almost pulled it off but I was so far into it that I refused to haha.
I don't have a pic but I can take one later if you really want. But they just look like the standard worm drive clamp like this:
Old 02-12-2014, 02:00 PM   #3355
evan
Drives: fr-s
I'm going to E85 soon. I'm planning on using the DW700s and a DW pump. I'm thinking I'll need mine. I'm currently pushing 277hp at the wheels on the 70mm pulley non-intercooled and spraying meth. My tuner uses BRZedit though.
Was the drivability that much worse? I'm guessing you're using ECUtek?
Evan
Old 02-12-2014, 02:04 PM   #3356
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Do yourself a favor and put a hose clamp on the tube that goes to the PCV/crankcase vent.. its almost impossible to get to it with the blower on.. Mine didn't have one originally and I had a small vacuum leak from it.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 02-12-2014, 02:06 PM   #3357
xxscaxx
You know I accidentally pulled that line up and almost off when working on putting my IC on. I was thinking of how to get a clamp on there, but then said F it because I couldn't reach in there.
Old 02-12-2014, 02:10 PM   #3358
calispec
calispec's Avatar
Yeah I pulled mine off when installing my catch can.. then I said F@#K when I realized where it had to go..
www.GT86Mounts.com
Old 02-12-2014, 02:12 PM   #3359
xxscaxx
I will probably spend 3 hours trying to fish a clamp on there and somehow tighten it instead of just taking the supercharger off.. lol
Old 02-12-2014, 02:32 PM   #3360
xjohnx
Grip>Slip
xjohnx's Avatar
Evan
Even e85 of the 70mm you should be fine, that's what I run. It just depends on your tuner. Drivability wasn't BAD on the DW's, just felt a lot more like a factory tune with the stock injectors. Look at some of @DeliciousTuning's old posts about injector needs.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
