Old 02-10-2014, 03:53 PM   #29
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Akari View Post
No offense to anyone in here but a good set of shoes doesn't solve the issue here. The issue is when shifting quickly, especially 1st to 2nd, you have to delay how quickly you get back on the accelerator, otherwise your clutch will not be fully engaged yet even though the pedal is fully released. Yes this is easy to avoid but it's not a behavior that is constructive towards spirited driving or track use.
I said live with, not solve.
I am rarely (ie once per session) in first gear on the track. Just shift slightly slower. I never notice it in the other gears.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-10-2014, 05:05 PM   #30
Porsche
Drives: 2013 BRZ Ltd. MT
I'm not concerned about this CDV. I wasn't concerned about the one in my S2K either. It's very easy to learn to live with it.
Do we know, absolutely and unequivocally, that the Subaru BRZ does in fact have a clutch delay valve?
I don't drive in such a way that it would be readily apparent; like you, Dave, I don't notice it on my S2000 (parked for the winter).
Has anyone posted or linked to, say, an exploded parts diagram that proves the Subaru has such a valve? Although, if you've disassembled yours and held the valve in your hand, Dave, I'd be inclined to believe you. I'm not denying it exists, I have no idea either way, merely asking for convincing evidence. If proof has been posted, could someone direct me to it, please? Until I see something like that, I'm skeptical.
Thanks.
Porsche is offline   Reply With Quote
Old 02-10-2014, 09:41 PM   #31
trd87t
Drives: Supra, BRZ
Thanks.
x2
I do notice it myself but I learned quickly to drive around it. I have noticed that it not as noticeable since i took delivery of her. Never had that "feeling" with my other manual cars (supras, wife's miata and z24).
If there is no valve to speak of, then could it be the fact that our clutch does not directly drive the master cylinder? Could even be that there is a banjo setup on the slave cylinder (but I very highly doubt this is a cause). These two things I have never seen/experienced on a car before so I'm only speculating here.
my .02 fwiw
1997 Toyota Supra TT 6MT - RR
2014 Subaru BRZ Limited 6MT - WRB
trd87t is offline   Reply With Quote
Old 02-11-2014, 05:13 PM   #32
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Thanks.
Hmm good call. I notice that 1-2 and 2-1 shifts suck ass but that could be trans design more than anything else. It feels like a CDV because the symptom is similar to the clutch not being fully disengaged. I haven't tried to locate a CDV which is reportedly in the BMC. Subaru and many others are using these days so it just made sense but I certainly never confirmed it.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-11-2014, 08:47 PM   #33
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
We need an informed and competent automotive drivetrain engineer in this thread.
BRZfan is offline   Reply With Quote
Old 02-11-2014, 09:32 PM   #34
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Lowering the grab point of the clutch helps, and a smooth let out of the clutch (not a dump) works.
That, and a good heel-toe blip while clutching out, makes for some good spirited shifts.
If there's a CDV there, then I'm not yet good enough or fast enough to notice it yet.
@chrisl, do you go for Puma motorsport shoes, or just Puma shoes in general?
^GT5 Replay Photo Mode^
Old 02-11-2014, 10:12 PM   #35
trd87t
Drives: Supra, BRZ
When it warms up in the next day or two, i'm going to check out the engine bay and look for things that are similar to a link that was reference earlier in this thread.
http://www.iwsti.com/forums/how-inst...post-pics.html
From what I remember I don't remember seeing a type of "container" or "proportioning valve" on the clutch system but again, I don't exactly remember and rather go check again.
Old 02-12-2014, 01:02 AM   #36
Porsche
Wink
DISengaged?
You meant not fully "ENgaged," right? A feeling as though the clutch isn't "biting" as crisply as it should? So, it might be difficult to abruptly break away the rear tires, for instance?
Otherwise, I'm confused ... which is a frequent state for me in my old age.
Old 02-12-2014, 01:20 AM   #37
Porsche
Originally Posted by trd87t View Post
When it warms up in the next day or two, i'm going to check out the engine bay...
I don't recall seeing anything topside. If the BRZ employs a clutch delay valve it might be located down around the bellhousing/clutch assembly. IIRC that's where the CDV is found on my S2000, and isn't that where the CDV is located on the STi?
I recall the S2000 needed one, not to protect the clutch, but because the differential was prone to breaking, so Honda employed a clutch delay valve to soften the driveline shock resulting from abrupt clutch engagement as drivers sought to deliberately break the rear tires loose.
It is 1.1* F here right now. Oi!
It'll be months before we experience warmth again.
Old 02-12-2014, 01:31 AM   #38
Porsche
My thought is that a well-timed, well-executed, smooth shift would MASK the presence of a clutch delay valve.
That's why I have not noticed any such valve ... 'cuz I'm so GOOD, don't ya know.
(I'm sorry; I'm weak and couldn't resist...)
Old 02-12-2014, 01:55 AM   #39
Porsche
Originally Posted by FRSKEV View Post
Glad Im reading this because I thought I was going crazy not being able to figure out how to shift smooth 1-2.
You're not going crazy.
Oddly, this BRZ is one of THE most difficult cars to shift smoothly that we've ever driven.
You have a low post count, so I'm guessing you're new to this car. Smoothness will come in time, as it did for me. But, I'm still hard-pressed to define exactly what the issues are here.
I'm thinking the "awkwardness" of shifting, especially the 1-2 shift, is attributable to an odd clutch take-up and an awkward drive-by-wire throttle pickup. The throttle (as I recall) is sort of nothing-nothing-BAM more than I wanted sort of thing producing jerky shifts, rather than the smooth, SEAMLESS shifts that I strive for. I try to shift so that as a passenger you cannot tell that I've shifted, smoother than any automatic transmission. Quickly, too, but not faster than it "likes."
Now that I can shift seamlessly (after some time), all I can say is that I just "squeeeeze" the throttle and properly coordinate the clutch engagement such that my shifts are smooooth. I wish I could be more specific for you, but my body just "does it," now, and I cannot say exactly how. Kind of like walking on a tightrope; I don't fall off anymore, but I can't exactly describe WHY except to say that I kept practicing until I got it.
I realize this hasn't been much help, apart from reassuring you that you're not crazy. Keep working at it, and it will come in time.
Just do not slip your clutch too much; you'll wear it out prematurely.
Old 02-12-2014, 09:14 AM   #40
BRZfan
BRZfan's Avatar
Old 02-12-2014, 09:28 AM   #41
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
DISengaged?
Depends on the shift. Sometimes it doesn't feel like it's disengaged (mine has ground gears on slow shifts with the pedal on the floor) and sometimes it feels like there's a delay in engagement. I only notice it in 2-1 and 1-2 shifts though so maybe it's just trans design.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2014, 09:46 AM   #42
IronSean
Drives: 2006 Toyota Camry
... an awkward drive-by-wire throttle pickup. The throttle (as I recall) is sort of nothing-nothing-BAM more than I wanted sort of thing...
This is completely true. I wasn't sure if I was just crazy, but every time I test drove a BRZ I would be surprised how far I had to push the pedal to get any throttle at all. It was quite the shock coming from my 06 Camry (which is also Drive-by-wire) where you can ease onto the pedal and start getting controlled throttle.
IronSean is offline   Reply With Quote
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Name that valve cover!!!! FA20???? ESBjiujitsu Engine, Exhaust, Transmission 3 06-05-2012 09:42 PM
Will adding options at the port delay delivery? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 6 05-20-2012 06:34 PM
Clutch wear? Pakjk89 Engine, Exhaust, Transmission 102 04-12-2012 07:21 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
