#29 | |
Site Moderator
Drives: Stuff
![]() I am rarely (ie once per session) in first gear on the track. Just shift slightly slower. I never notice it in the other gears.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#30 | |
Drives: 2013 BRZ Ltd. MT
I don't drive in such a way that it would be readily apparent; like you, Dave, I don't notice it on my S2000 (parked for the winter). Has anyone posted or linked to, say, an exploded parts diagram that proves the Subaru has such a valve? Although, if you've disassembled yours and held the valve in your hand, Dave, I'd be inclined to believe you. I'm not denying it exists, I have no idea either way, merely asking for convincing evidence. If proof has been posted, could someone direct me to it, please? Until I see something like that, I'm skeptical. Thanks. |
| The Following User Says Thank You to Porsche For This Useful Post: | BRZfan (02-10-2014) |
#31 | |
Drives: Supra, BRZ
I do notice it myself but I learned quickly to drive around it. I have noticed that it not as noticeable since i took delivery of her. Never had that "feeling" with my other manual cars (supras, wife's miata and z24). If there is no valve to speak of, then could it be the fact that our clutch does not directly drive the master cylinder? Could even be that there is a banjo setup on the slave cylinder (but I very highly doubt this is a cause). These two things I have never seen/experienced on a car before so I'm only speculating here. my .02 fwiw
1997 Toyota Supra TT 6MT - RR
2014 Subaru BRZ Limited 6MT - WRB |
#32 | |
Site Moderator
Drives: Stuff
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | Porsche (02-12-2014) |
#33 |
Drives: 2013BRZ Premium St Silver Metallic
We need an informed and competent automotive drivetrain engineer in this thread.
| The Following User Says Thank You to BRZfan For This Useful Post: | SirBrass (02-11-2014) |
#34 |
Trust me, I'm the Doctor
Lowering the grab point of the clutch helps, and a smooth let out of the clutch (not a dump) works.
That, and a good heel-toe blip while clutching out, makes for some good spirited shifts. If there's a CDV there, then I'm not yet good enough or fast enough to notice it yet. @chrisl, do you go for Puma motorsport shoes, or just Puma shoes in general?
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#35 |
Drives: Supra, BRZ
When it warms up in the next day or two, i'm going to check out the engine bay and look for things that are similar to a link that was reference earlier in this thread.
http://www.iwsti.com/forums/how-inst...post-pics.html From what I remember I don't remember seeing a type of "container" or "proportioning valve" on the clutch system but again, I don't exactly remember and rather go check again.
#36 | |
You meant not fully "ENgaged," right? A feeling as though the clutch isn't "biting" as crisply as it should? So, it might be difficult to abruptly break away the rear tires, for instance? Otherwise, I'm confused ... which is a frequent state for me in my old age.
#37 | |
I recall the S2000 needed one, not to protect the clutch, but because the differential was prone to breaking, so Honda employed a clutch delay valve to soften the driveline shock resulting from abrupt clutch engagement as drivers sought to deliberately break the rear tires loose. It is 1.1* F here right now. Oi! It'll be months before we experience warmth again.
#38 | |
That's why I have not noticed any such valve ... 'cuz I'm so GOOD, don't ya know. ![]() (I'm sorry; I'm weak and couldn't resist...) |
#39 | |
You're not going crazy. Oddly, this BRZ is one of THE most difficult cars to shift smoothly that we've ever driven. You have a low post count, so I'm guessing you're new to this car. Smoothness will come in time, as it did for me. But, I'm still hard-pressed to define exactly what the issues are here. I'm thinking the "awkwardness" of shifting, especially the 1-2 shift, is attributable to an odd clutch take-up and an awkward drive-by-wire throttle pickup. The throttle (as I recall) is sort of nothing-nothing-BAM more than I wanted sort of thing producing jerky shifts, rather than the smooth, SEAMLESS shifts that I strive for. I try to shift so that as a passenger you cannot tell that I've shifted, smoother than any automatic transmission. Quickly, too, but not faster than it "likes." Now that I can shift seamlessly (after some time), all I can say is that I just "squeeeeze" the throttle and properly coordinate the clutch engagement such that my shifts are smooooth. I wish I could be more specific for you, but my body just "does it," now, and I cannot say exactly how. Kind of like walking on a tightrope; I don't fall off anymore, but I can't exactly describe WHY except to say that I kept practicing until I got it. I realize this hasn't been much help, apart from reassuring you that you're not crazy. Keep working at it, and it will come in time. Just do not slip your clutch too much; you'll wear it out prematurely. |
| The Following User Says Thank You to Porsche For This Useful Post: | jcw99 (05-30-2016) |
#40 |
#41 | |
Site Moderator
Drives: Stuff
-Dave
#42 |
Drives: 2006 Toyota Camry
This is completely true. I wasn't sure if I was just crazy, but every time I test drove a BRZ I would be surprised how far I had to push the pedal to get any throttle at all. It was quite the shock coming from my 06 Camry (which is also Drive-by-wire) where you can ease onto the pedal and start getting controlled throttle.
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 01:22 PM |
| Name that valve cover!!!! FA20???? | ESBjiujitsu | Engine, Exhaust, Transmission | 3 | 06-05-2012 10:42 PM |
| Will adding options at the port delay delivery? | Liquidsnake | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 05-20-2012 07:34 PM |
| Clutch wear? | Pakjk89 | Engine, Exhaust, Transmission | 102 | 04-12-2012 08:21 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 04:48 PM |
