#3529 |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#3530 | |
Time Traveller
+1 for nice guy and Sugru user (the DIY mix at home stuff works pretty well too)
#3531 |
Nameless header dyno is out. Now we need @Thatruth2001 to see how it does for all of us running a ecs!
I'm excited to see Sent from my HTC One using Tapatalk |
#3532 |
Location of that dyno?
#3533 | |
Drives: SWP BRZ
#3534 |
#3535 |
Just got the ESC today!
It's one thing to see it develop over 160+ worth of forum pages, but it's another thing entirely to see it and hold it in person... I plan to install it tonight! Question: Is the compressor supposed to have a cut out at that spindle region? |
#3536 | |
#3537 | |
Drives: 2013 FR-S whiteout
#3538 | |
Drives: VW
Material removed for balancing the rotor. Good luck! Take your time and follow the install & wiring schematic downloads. Rob. |
#3539 | ||
![]() And although I've already heard that this thing isn't really meant for track use, I plan to use it for a few laps on SoW and Buttonwillow... just to see what happens. Looking forward to that boost in torque! Thanks again @Robftss for an excellent execution of a ridiculously innovative product! |
#3540 | |
Thathruth used it on his local track and he found that using it just on the straights worked perfect. Sent from my HTC One using Tapatalk |
#3541 |
One thing that I do want all you new people to know is that you should NEVER arm the ecs when already full throttle. It would be extremely hard on the components.
Another quick reminder is that you can arm the system while the car is in vacuum however if you happen to be accelerating the drag reduction may get zero'd in wrong causing it to not work correctly. DR voltage drop should not happen while cruising at a steady speed.... If it is it may be set to low. Sent from my Nexus 10 using Tapatalk |
#3542 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
