Old 02-11-2014, 11:41 AM   #15
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by cdrazic93 View Post
Well damn. I figured expensive complicated turbo - you need an expensive complicated ECU to control the beast.
Hey EcuTEK is expensive
Ironsquid is offline   Reply With Quote
Old 02-11-2014, 11:43 AM   #16
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by jamesm View Post
it it runs on duty cycle ecutek can
IN for screencast of adding VGT maps to EcuTek.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
cdrazic93 (02-11-2014), jamesm (02-11-2014), SmsAlSuwaidi (02-11-2014)
Old 02-11-2014, 11:57 AM   #17
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Not compaired to motec.
Edit: sorry, when scrolling if you see a ton of cows lol
Old 02-11-2014, 01:02 PM   #18
Lee@JDLAutoDesign
Lee@JDLAutoDesign's Avatar
Drives: Corrado
We did a one-off compound turbo setup for a friend's TDI a few years back with a VNT high pressure turbine. There are definitely tangible gains to be had using this technology, especially in a single turbo setup, but it's obviously a trade off with complexity and cost. (Sorry for the blurry pic)
In this case the VNT turbine with the external high pressure bypass gate and the internal low pressure wastegate made controlling the total boost very difficult. In the end I had to build a spreadsheet model of turbine system so we could determine the optimal VNT schedule and communicate that to the tuner, who was controlling the vanes through the factory VW ecu. In a single turbo configuration I think the control/optimization issue becomes much, much simpler.
If you pursue this and need some suggestions/guidance, I'd be happy to help. My first suggestion is to see what information you can find out about the turbine maps for the turbo you intend on using.
Lee@JDLAutoDesign is offline   Reply With Quote
The Following 3 Users Say Thank You to Lee@JDLAutoDesign For This Useful Post:
diss7 (02-12-2014), Hanni_0176 (02-11-2014), Rosticles (04-03-2014)
Old 02-11-2014, 06:12 PM   #19
cmcauley
cmcauley's Avatar
Drives: 2013 Scion FR-S Asphalt 6MT
If I remember correctly, one of the major issues Porsche had with applying this tech to gas engines was the amount of heat created. From one owner I talked to with a 911 turbo early on, he had to get his turbos replaced under warranty because of failure from excessive heat.
cmcauley is offline   Reply With Quote
Old 02-11-2014, 06:54 PM   #20
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
Twin Scroll VGT turbo kits? That just made my day right there, even if it never comes to pass. Maybe once I'm ready to go turbo, this will be a possibility? I'll keep my fingers crossed.
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
Hanni_0176 is offline   Reply With Quote
Old 02-11-2014, 07:38 PM   #21
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
I just realized how badly geometry was spelled in the title lol
The Following User Says Thank You to Ironsquid For This Useful Post:
Old 02-11-2014, 07:46 PM   #22
scraejtp
Drives: 2013 Subaru BRZ
Originally Posted by mid_life_crisis View Post
Direct injection was in diesels for decades and now it's everywhere.
Give it time.
It isn't that VGT is that new. The EGT of a gasoline engine is much higher than diesel. The current materials used really can't last in a gasoline application.
scraejtp is offline   Reply With Quote
Old 02-11-2014, 09:02 PM   #23
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I noticed it 2 seconds after I posted it...
Didn't you know? Gemoetry is the cool way of spelling it now
Ya I got nothin...wait wait, it's hard to type on an iPod screen with my fat fingers? Yeah that covers it lol
Old 02-12-2014, 12:06 AM   #24
EZWood
BAMF
EZWood's Avatar
I have a turbo from a 6.0 powerstroke sitting in my room that I would be willing to "donate" for research in exchange for either a discount in the future, or maybe even an awesome discount on a uel header that would be compatible with a turbo kit in the future. I was thinking with the size heat and emp would be greatly reduced and I heard of a ford tech putting one of these on a 1.8 Mazda motor making 15 psi @ 3500 rpm. Imagine the possibilities.
Old 02-12-2014, 02:56 AM   #25
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Another idea would be for someone get a hold of the new boxer diesel in Europe, drop it into the 86, convert it into biodiesel, then place a VGT turbo on it. Gobs n gobs of torque way down low. And a meaty powerband.
Old 02-12-2014, 03:26 AM   #26
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
My 997tt has stock VGT turbos and they are ridiculous compared to traditional fixed vain turbos. Full boost comes on like a light switch. Almost too abruptly. There is still lag (delay between throttle application and boost onset). But the rate of boost rise once boost is achieved is nearly vertical. Yikes!
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
diss7 (02-12-2014)
Old 02-12-2014, 09:35 AM   #27
EZWood
BAMF
EZWood's Avatar
I havent heard one good thing about the diesel boxer.
Old 02-12-2014, 10:28 AM   #28
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Well shit. I figured subaru would be good enough to build a decent diesel. Apparently their experience lends themselves to only gas engines...
What kind of problems does it have? Or a better question, what kind of problems doesn't it have?
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 06:21 PM
Continuously Variable Transmission Lexicon101 Other Vehicles & General Automotive Discussions 79 06-26-2015 03:18 AM
Dealership Accuses Variable Valve Timing (VVT) Ajustment shiro Issues | Warranty | Recalls / TSB 48 12-20-2013 10:03 AM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
Rotrak variable supercharger madfast Other Vehicles & General Automotive Discussions 10 01-28-2012 11:14 PM
