Old 02-11-2014, 12:24 PM   #15
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Yeah, will be basically the same that was needed for the AM Failsafe.
this kit install just keeps getting more complicated lol. buying a turbo is def like taking the red pill
lbroskee is offline   Reply With Quote
Old 02-11-2014, 12:26 PM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
LOL, wait till you start installing it..
The Following User Says Thank You to Sportsguy83 For This Useful Post:
IBill4You (05-02-2015)
Old 02-11-2014, 12:28 PM   #17
lbroskee
lbroskee's Avatar
i still need wide band, EBCS, injectors, fuel pump, MAP sensor, and i feel like I'm forgetting something else
Old 02-11-2014, 01:03 PM   #18
stugray
Drives: 2013 GBS BRZ Limited
This is only capable in Ecutek RaceRom 7.
Once this is wired in, cant you log it using any CAN logging application?
You would just tell the logger to log 02 using the standard PID, and use the new conversions for the AFR gauge.
Curious.
The Following User Says Thank You to stugray For This Useful Post:
Sportsguy83 (02-11-2014)
Old 02-11-2014, 01:20 PM   #19
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
I've got a Grimmspeed ebcs 3 port I'll sell you for $80. Good condition, never installed.
^GT5 Replay Photo Mode^
Old 02-11-2014, 01:23 PM   #20
Sportsguy83
Drives: Limited BRZ
Curious.
Good question....
Old 02-11-2014, 02:02 PM   #21
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@DAMotorsports check this out
Old 02-11-2014, 02:12 PM   #22
jamesm
Curious.
you'd have to use a 0-1v narrowband simulation, then hope that the stock scaling on that channel is linear. on the bright side you could still retain all of the custom maps functionality... just make your custom map scaler 0-1v instead of 0-5. innovate lc-1/2 can do this.
Old 02-11-2014, 02:30 PM   #23
lbroskee
lbroskee's Avatar
why selling it?
Old 02-11-2014, 02:44 PM   #24
jamesm
damnit i just bought one of those... hasn't even come in the mail yet. i suck.
The Following User Says Thank You to jamesm For This Useful Post:
Old 02-11-2014, 03:46 PM   #25
SirBrass
SirBrass's Avatar
why selling it?
Because I'm not turbo'd, and I had bought it when I had my STI, fully intended to use it when I went stage 2 (which I never did before trading in for the BRZ). So, I have no use for it now.
Old 02-11-2014, 03:48 PM   #26
lbroskee
lbroskee's Avatar
just curious, but is the STI model the same 1 u bought @jamesm? i see they have dif ones and dif options for subie one.
and if that is the case then we shall talk @SirBrass
Old 02-11-2014, 03:50 PM   #27
SirBrass
SirBrass's Avatar
The STI I had is listed in my sig: 2013 STI
The Following User Says Thank You to SirBrass For This Useful Post:
Old 02-11-2014, 04:03 PM   #28
jamesm
I got the wrx one, non-sti. The only difference is the included bracket I believe.
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 08:51 AM
Aftermarket Rear Diffuser Realm Cosmetic Modification (Interior/Exterior/Lighting) 8 05-09-2013 12:23 AM
FS: BNIB Concept Three LED Amber/White signal bulbs Front and Rear with Relay xxscaxx Exterior Parts (Aero, Lighting, Etc.) 10 03-27-2013 11:17 AM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 10:53 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 01:42 PM
