Old 02-11-2014, 10:30 AM   #71
Suko
Drives: 2014 subaru brz
I seen a lot of people mention the "stage 1.5" kit is this just the stage 1 kit with an exhaust setup?
Suko is offline   Reply With Quote
Old 02-11-2014, 10:53 AM   #72
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Basically yes, it is a full exhaust (2.5" front to back) and the BOV, etc etc.
The Following User Says Thank You to SkAsphalt For This Useful Post:
Venator (02-11-2014)
Old 02-11-2014, 11:46 AM   #73
Venator
Venator's Avatar
Drives: Asphalt FR-S
So am I reading this right, with a stage 1 AVO and exhaust I can put down 270whp on 93 octane?
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
Venator is offline   Reply With Quote
The Following User Says Thank You to Venator For This Useful Post:
SkAsphalt (02-11-2014)
Old 02-11-2014, 12:03 PM   #74
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Drift-Office View Post
If VE doesn't change because of the spool, it's still pretty much the same right? Like the FBM kit, starts to spool at 3500 / 4000 RPM, what do you have to do below that? Granted timing and fueling strategies isn't 100% the same but it's not that drastic either... Sure, putting anything on like an exhaust and manifold will change the VE somewhat, it's less to do in that RPM range...
Cheers!
Bob @ Drift-Office, LLC
The FBM kit with the GT2871R spools well before 3500 RPM:
It is already at 5 psi by 3500 RPM.
Old 02-11-2014, 12:15 PM   #75
buditjoenawan
Drives: Very very slowly
Bob is not so good at communicating. I believe he meant this "kit"
I would *love* to see the boost plot for that particular run.....
-budi
buditjoenawan is offline   Reply With Quote
The Following User Says Thank You to buditjoenawan For This Useful Post:
Drift-Office (02-11-2014)
Old 02-11-2014, 12:25 PM   #76
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Similar with GTX30 (3-4 psi) by 3500 RPM
Old 02-11-2014, 03:49 PM   #77
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Originally Posted by OICU812 View Post
@Mr.Jay that sounds fantastic! I have Avo Over pipe and Avo Catted front pipe so which Tomei exhaust package is that exactly? Asking as all other Tomei setups I've hear I haven't liked a bunch. Any drone in cabin? Sorry bit off topic ...
I got the AVO kit, AVO FP & OP and a Tomei Type 80. With this I and no one else so far has had any complaints about drone. It is deff loud however I came from a SRT headerback which was much louder. I'm going to sound deaden the trunk a bit and I think it will be prefect.
Depends on how good your 93 actually is. Stuff around here isn't stellar.
But tune is going to be the deciding factor. So get a good tuner.
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 02-11-2014, 08:03 PM   #78
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
The FBM kit with the GT2871R spools well before 3500 RPM: It is already at 5 psi by 3500 RPM.
-budi
Thank you gents. My bad - when people ask me about the FBM kit, it's usually in relation to that one with the >600WHP run. I should have specified. Thanks for the clarification!
Cheers!
Drift-Office is offline   Reply With Quote
Old 02-11-2014, 08:08 PM   #79
Drift-Office
Sorta. Aside from the OP / FP / CBE combination, the hardware includes the 8 PSI actuator and the 3 bar Map sensor (and a BOV) to boot.
That's a Stage 1.5 setup running 8 PSI with 91 octane (right @Mr. Jay?) and a 3 INCH Cat-Back Exhaust. A clutch was required too since we exceed the stock OEM limitations. But yeah, the DO Stage 1.5 is usually in the 260WHP range for both MTs and ATs.
The Following User Says Thank You to Drift-Office For This Useful Post:
Old 02-11-2014, 08:19 PM   #80
Touge_ninja
Sending rods to their doo
Touge_ninja's Avatar
Drives: 700HP STi
2 months in to owning my AVO Kit, and its seen alot of DD. no problems at all. This kit is super responsive(granted you are at the correct gear). So glad i went this route.
Touge_ninja is offline   Reply With Quote
The Following 4 Users Say Thank You to Touge_ninja For This Useful Post:
Drift-Office (02-11-2014), gdrider77 (02-11-2014), Pete156 (02-11-2014), SkAsphalt (02-11-2014)
Old 03-02-2014, 03:40 PM   #81
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Sorry to bring up a relatively old thread but...
Im having a bit of a tough time choosing (in my opinion) the best of both worlds turbo kit. Best of both worlds to me means a DD 92 (WA gas) That makes the car what it should have felt like from the factory. The other world is changing to an E85 tune and reminding myself its anything but factory
Im leaning towards the AVO stage 1.5, a few questions though, as im seeing it most people have multiple types of exhaust running on a AVO kit, so im assuming the exhaust flanges are universal? (Plan to run a 3") as far as a E85 tune, what kind of power would I be expecting? i.e. I would be traveling to @Drift-Office for my tune and such.
p.s. another relatively off topic question, how long do these AVO stage 1/1.5 kits take to tune?
Old 03-02-2014, 03:52 PM   #82
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@cdrazic93 why the avo thou ?
Sent from my IBrick
Old 03-02-2014, 03:58 PM   #83
AVOturboworld
The exhaust flange on the turbo discharge pipe is a 2.5" two-bolt pattern, slotted so that it can fit a stock exhaust or a slightly larger than 2.5". A 3" may fit post turbo discharge, but that depends on the exhaust maker's design. When we designed the 3" turbo back parts, we had to discard using the exact same flange points as stock for the cross-over and front pipe so we could redesign the bends in the crossover so that 3" diameter fits through the crossmember hole without touching it or the stabilizer bar bracket.
E85 would depend on supporting mods - the turbo can push out 380whp on e85, but the exhaust and fueling will need to support that as well (and clutch).
Old 03-02-2014, 04:02 PM   #84
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
If I might ask - where are you planning to get E85? There are zero stations between Marysville and JBLM. E85 is not feasible for us in the PNW. Bob will probably tell you as well that E85 is not the way to go here.
My kit was installed and tuned by Drift Office. I think my car was down for 4 business days?
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following 2 Users Say Thank You to deucethemoose For This Useful Post:
Drift-Office (03-02-2014), Pete156 (03-02-2014)
FI worth it? Gt86_nick Forced Induction 62 01-28-2014 01:55 AM
gt 86 worth 40k!!!??? 12345qwerty Scion FR-S / Toyota 86 GT86 General Forum 29 04-13-2013 11:56 PM
Is it worth it? Greaser Scion FR-S / Toyota 86 GT86 General Forum 45 08-10-2012 11:15 AM
is this worth doing denverizzles Engine, Exhaust, Transmission 7 08-03-2012 12:35 PM
What's this worth? Sport-Tech Other Vehicles & General Automotive Discussions 5 04-12-2012 11:21 AM
