#15 |
Drives: Ultramarine FR-S
#17 | |
Drives: 2019 BMW ///M4
#18 |
Drives: Ultramarine Scion FR-S
Well you probably already looked inside it, but i know of someone who had a small coin fall inside it and fry the thing, since the damn cap sux at staying closed.
#19 |
Drives: 2013 Subaru Brz Sport-Tech SWP
Yep, it's all the way in the back. That's where I plug in my iPod or iPhone to play off the Pioneer head unit if I don't want to use bluetooth to sync it
Mods: 2013 Subaru Outback fog lights, HID fog lights, LED vanity lights, LED dome light, LED trunk light, LED license plate lights, LED door courtesy lights, LED side markers, HID headlights, J2 Engineering test pipe, HKS Drop-In air filter, Window Visors, De-badged, and Diode Dynamics LED side mirrorsSide Chick: 93' 240sx Convertible |
#20 |
Drives: Raven Manual FRS
#21 |
Drives: 2006 Toyota Camry
Canadian models have the USB port installed in the Glove box instead of the bottom right of the center Dash. I think it has to do with USDM stereos being installed in factory and CDM stereos being installed at port?
#22 | ||
#23 |
Drives: Scion Fr-s 2013
Took it to the dealership they said there was power in the outlets, but it still didnt work. So i tried the charger in my mom's benz, and it worked. I am so confused.
#24 |
Drives: Silver Ignition Gundam
I'm trying to fuse tap my fog light switch into either the ignition or cigarette lighter fuse. Do you know which one it is? Cause I can't figure it out..neither could the guy at autozone.
#25 | |
![]() Cigarette lighter fuse is the one I circled. You can use a mini fuse tap (autozone sells them) and tap into the cigarette lighter source that way. Ignition fuse I'm not sure where that is, but my foglights are wired directly to the factory harness (I'm using the AUDM turn signal stalk) |
| The Following 2 Users Say Thank You to jonzhuxD For This Useful Post: | Asian Delight (04-28-2014), IgnitionGundam (04-28-2014) |
#26 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Thank you!
#27 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Mine just died too. Was fuse n. 2.
#28 |
Drives: Scion FRS/Whiteout/OEM spoiler
This happened to me today. The 12v outlet by the cup holders blew and wasn't sure which fuse was which. In my 2013 FRS P/point No2 was in the glove box and P/point No1 was the cup holder outlet.
No2 was fine so I swapped fuses and the cup holder outlet started working again. Bought new fuses to replace No1. Somehow lost the No1 fuse when pulling it so I couldnt see if it was blown, obviously it was haha.
Whiteout 2013 FRS/ OEM Spoiler/ Clear side markers/TRD Intake/ Shark fin antenna/Rex speed blue wide mirrors/DD fog lights/Grimmspeed Strut bar/
| Toyota Parts Outlet | Gen | User/Vendor/Sponsor Reviews, Feedback, Comments | 13 | 09-22-2013 12:16 PM |
| Power outlet fuse | Kev01 | AFRICA | 5 | 03-04-2013 11:41 PM |
| USB Outlet?? | Ben_G | CANADA | 16 | 01-30-2013 02:13 AM |
| Glove compartment power outlet | Trojan_SC | Electronics | Audio | NAV | Infotainment | 7 | 08-02-2012 09:47 PM |
