Old 02-10-2014, 09:20 AM   #3487
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
Originally Posted by Target70 View Post
could you list the specifics on the second dyno you posted? I mean the different setups between the red and the green? I thought that the blue from shiv's was the TQ300 with header and your red/blue is at or above his peak numbers, so are you running the 300 or e85?.. or am I just lost
If you look at shiv's post it's direct comparison of my car (91 octane, catless front pipe, and catback exhaust) and his car stock everything with the open flash header. Both cars running the phantom.
If you look at my pictures first picture is his car with the tq250 and tq 300.
The second picture is my car and setup running 91 at the lower end and e85 on the top. With two runs of both stacked on top of each other. Red: e85 and green: 91 octance
Installed Mods:
Old 02-10-2014, 10:04 AM   #3488
sprintamx
At 159 pages, there's a bit much to sift through. Has there been discussion / testing of this approach under track conditions: prolonged boost, higher temps, etc? I'm primarily thinking of HPDE type events, rather than competitive.
I recognize this is primarily a street application--and a terrific one at that, on many levels--but it's inevitable that it will see track duty . . .
Thanks.
sprintamx is offline   Reply With Quote
Old 02-10-2014, 10:22 AM   #3489
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Aw snap. Out for Delivery.
Old 02-10-2014, 10:30 AM   #3490
raven1231
Nice! Mines still in customs... At least It's in my country now lol!
Old 02-10-2014, 10:35 AM   #3491
Robftss
Drives: VW
Originally Posted by VR46 View Post
Update - got the OFT tune sorted out for 93 octane/ESC. I got in contact with Shiv, who asked me to send him my stock tune off of the OFT - he got back to me with a .DEV file that I could load onto the OFT and apply to my car. Flashed the tune and went for a spin. I have to admit that my expectations for this kit have been completely blown out of the water. I can't wait to see what's in store once I can get back on the corn juice.
Took some more pics, which you can see here - http://imgur.com/a/0fnLV - I think I will go back and clean up the routing of the wires in the engine bay.
Thanks and congrats to @Robftss on releasing this excellent product, and great thanks to @shiv@vishnu for his help.
Thanks guys!
Good to hear it is working with your AT.
Robftss is offline   Reply With Quote
Old 02-10-2014, 10:35 AM   #3492
SloS14
SloS14's Avatar
I'm on the East coast and mine said it was in customs 3 hours ago, then it instantly went to 'out for delivery'
Old 02-10-2014, 10:40 AM   #3493
raven1231
Maybe mine will do the same ! Thanks
Old 02-10-2014, 10:44 AM   #3494
Robftss
Drives: VW
Thanks.
- DD
- Auto-X
- 'Friday night' @ the drag strip
- hooning
- more hooning
Development continues to increase the duty cycle, so presently 'no' to track duty, a proper FI set up for track use is well over 5K for any car.... this is a different price point.
Thks, Rob
Old 02-10-2014, 10:49 AM   #3495
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by Robftss View Post
-Development continues to increase the duty cycle, so presently 'no' to track duty, a proper FI set up for track use is well over 5K for any car.... this is a different price point.
Thks, Rob
As a followup question, is there a failsafe that will default to DR mode (and not engage at WOT) once the current becomes insufficient through sustained use? This is more a curiosity than anything else, as it appears that nobody has run the dump packs down entirely.
It has priests in it?
Old 02-10-2014, 11:01 AM   #3496
SloS14
SloS14's Avatar
From the manual:
Fail safes
- 26.X volts peak. Thermal charger protection. Boost can be used but is slightly reduced.
* Resets 5-10min depending on engine bay temps.
- 24.X – 28.X volts and throttle switch activated but no boost. Thermal motor control protection.
* Resets in 2-10 seconds *let unit recharge and cool.
- 17.0 volts, no boost, low voltage cut-off. Tripped if batteries are poor quality.
- Triggering fail safes is normal, position box away from direct heat and expose all surfaces to air.
- Intermittent use times: Duty cycle, up to 20%. Continuous, up to 60 secs. (30 seconds recommended).
- Adding the optional clamp-on fan will increase duty cycle for higher heat exposure applications.
Old 02-10-2014, 11:04 AM   #3497
Robftss
Drives: VW
Website FRS/BRZ download has fail safes described.
A low voltage or thermal situation has a 'soft' de-rate boost, and you will go into N/A, it resets in a couple seconds and has a large safety margin.
The voltage display will also indicate excessive charging time by showing ~ 2 volt drop.
Thks Rob.
Old 02-10-2014, 01:31 PM   #3498
sprintamx
- DD
- Auto-X
- hooning
- more hooning
Thks, Rob
Got it; thanks.
Old 02-10-2014, 01:59 PM   #3499
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Originally Posted by nlowell View Post
Question. I have a 5 channel audio amp hooked up to my battery as well as my HID kit. Will the new starter battery support that? Right now the amp is just supporting my JL enclosed 10 inch so I'm only powering ~200 watts rms. It a good alpine amp so I'm hoping its not drawing too much power. Thoughts?
Im running a 500W Mono Block powering a 10" Type S and its fine, no dimming of light or anything even when defroster and heat is on, just would recommend using the audio system when the engine is off, thats all!
Bu-Tang is offline   Reply With Quote
Old 02-10-2014, 09:10 PM   #3500
SloS14
SloS14's Avatar
OFT running good but I got something goofy happening with my OFT (most likely my fault). Ran it on a non-ESC map for a few seconds. Felt great. I am exhausted (working on house). Installed smooth in about 1.25hrs. Im my haste I left out one part of the battery thing (plastic sheet). I'll fix that and look into a relay tomorrow
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
