Old 02-09-2014, 09:35 PM   #3305
swift996
swift996's Avatar
Originally Posted by Dustin View Post
I'll probably do the same. Have my shift light come on at 7k and shift shortly after that. Went ahead and ordered the 70mm pulley today. If we're only talking about the last couple hundred rpms in the rev range, I'm not gonna worry about it. @swift996 you went with the 72.5mm correct? How are you liking it?
Yeah, I went with the 72.5mm and am loving it. I just installed a cat-back and trying to figure out why it's so damn loud. Seems like I must have a leak somewhere (flowmaster cat-back with some slip fits). So more impressions and dyno to come soon.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-09-2014, 10:09 PM   #3306
DriftEm
DriftEm's Avatar
make sure the donut gasket is not damaged.
DriftEm is offline   Reply With Quote
Old 02-09-2014, 10:10 PM   #3307
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I wouldn't go as far as lowering the rev limiter. Let's first ask how some engineer came up with 15000 as the soft limit. I like to think of it as the SWAG method. Scientific Wild Ass Guess. There are a couple factors that drive this number. The gears, bearings, and balance of the screws. Bearings and gears are rated on quality and precision. Given the tolerance and variance they come up with a worst case scenario and guess at an rpm which it Should not fail. That means the bulk of the bearings should out perform this number. And why 15000 and not 14950 or 15220? Because it is an estimate.
You are supposed to replace the timing belt on a honda at 90k I think. Why? Because that's when Honda has seen the earliest failures. 98.5% will last longer. I have seen one last 180k honda isn't going to tell u that though.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 02-09-2014, 10:55 PM   #3308
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
New pulley and header going on later this week. I'll have some before and after dyno numbers for each added.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 02-09-2014, 11:15 PM   #3309
swift996
swift996's Avatar
Yeah, I replaced that. It has to be around the muffler somehow.
Old 02-10-2014, 09:51 AM   #3310
xxscaxx
Drives: 2013 SWP BRZ
looky what I installed this weekend.
Thanks @PrimeMotoring
xxscaxx is offline   Reply With Quote
Old 02-10-2014, 10:11 AM   #3311
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
Awesome!
How did the installation go?
PrimeMotoring is offline   Reply With Quote
Old 02-10-2014, 10:22 AM   #3312
Victor Draken
Drives: Toyota Gt86
What is it?
Victor Draken is offline   Reply With Quote
Old 02-10-2014, 10:23 AM   #3313
evan
Drives: fr-s
Originally Posted by Victor Draken View Post
What is it?
Flex fuel
evan is offline   Reply With Quote
Old 02-10-2014, 10:58 AM   #3314
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Originally Posted by PrimeMotoring View Post
Awesome!
Is this your own kit?
Dustin is offline   Reply With Quote
Old 02-10-2014, 11:09 AM   #3315
PrimeMotoring
Yes it is, made in house.
Our kits have been running in quite a few of the turbo vehicles we have built and used the faults /shortcomings of the other kits on the market to improve on our design.
Each kit contains a Continental sensor and all the lines and connections are AN fittings rather than rubber or plastic. The lines we use are E85 capable and we use fuel line clamps rather than worm clamps so it gives an even pressure around when slid over the stock fuel line. Every other connector is push to connect, no cutting needed and completely reversible.
Kit also includes a Zeitronix Ethanol Content Analyzer available in either Blue or Red display
Old 02-10-2014, 11:10 AM   #3316
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
I can vouch for them
Great quality n no plastic fittings
Old 02-10-2014, 11:12 AM   #3317
PrimeMotoring
What is it?
Flex fuel kit that detects ethanol content in gas. In the cars running it that we tuned, it detects the ethanol content of the gas and adjusts the tune accordingly. No map switching, everything is smartly detected by the sensor and adjusted by the tune.
Old 02-10-2014, 11:14 AM   #3318
xxscaxx
Awesome!
Very easy just as I thought. Plus that ECU wire wasn't hard to get to...just like I thought
Just took a while because I am meticulous with stuff and had to make sure all the wiring was nice and neat/loomed, plus it was FREEZING in my garage so that never helps.
I wanted to do a writeup to post. Wish I would have taken a few pics, but my hands were so cold i was just trying to finish up the install. The ECA is tucked away nicely in the glove box
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
