Old 02-09-2014, 06:29 PM   #757
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by WiebTech Performance View Post
Its about a 1000 mile round trip for me, but if I had a decent base tune to get me down there, I'd definitely be for it.
For a proper Dyno tune its worth it. Just don't get into boost on the way.. (I know its going to be hard..) but it will be well worth it.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
The Racers Line (02-10-2014)
Old 02-09-2014, 07:25 PM   #758
mike the snake
I think FLI will give me a tune that doesn't blow up, but this is their first 86, so I don't know exactly what I'm going to get. I've been told Tuesday or Wednesday it should be done.
I know that with the Hydra, full 3" catless exhaust, GTX28R turbo, 550cc injectors and DW65 fuel pump I should be able to get well above 300whp with the methanol injection.
I believe they are going to simply tune with the 7lb wastegate spring. I know they haven't installed a boost controller (which I think I want) and they installed a wideband sensor at my request.
Element Tuning has offered to help with tuning with the Hydra when or if the time comes.
I plan to get the car all ready, with everything I need installed, to get the power I've been shooting for, either with FLI or another tuner.
This whole thing, with problems, parts swaps, delays, has taken 2.5 months and will probably be North of $17 grand. I will not be happy with 280whp that's for sure!
I still have the crash bar to install, fix the squished intercooler pipe, fab up the ducting for the radiator and oil cooler, gauges to install, still have a ways to go.
I'm in too deep to pull the plug now, but if I'd known it would be over 6 months (waiting on parts mostly) and this much money, I probably would have made a different decision.
I hope it's worth it!
The Following User Says Thank You to mike the snake For This Useful Post:
Old 02-09-2014, 07:46 PM   #759
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
How about LJ.
He can tune it?
Old 02-09-2014, 07:58 PM   #760
mike the snake
I don't know anything about tuning. I know the Hydra is a standalone, and very different than Ecutek, so I don't know if someone who isn't familiar with Hydra can just hop in and tune.
Element Tuning has offered to fly in and help tune if necessary. Everyone wants my car to make good numbers. I think the Hydra is far superior to Ekutek, it's going to come down to the tune/tuner.
I've been promised I won't be left hanging.
Old 02-09-2014, 08:07 PM   #761
jamesm
Yeah it's really not, unless you're swapping motors. If you're going standalone, motec is where it's at, but even then to come close to the functionality of custom maps you'd need a $5500 build ecu/license and a computer science degree.
Fast logging and live tuning are nice, though.
Old 02-09-2014, 08:19 PM   #762
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Check out Mann Engineering in San Jose. Delicious Tuning travels up there on a fairly regular basis for custom dyno tuning on their state of the art Maha dyno and pressurized cell. Next trip is the end of February.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Sportsguy83 (02-10-2014)
Old 02-10-2014, 10:53 AM   #763
RickyB
Drives: Mazdaspeed 3
What functionality is missing from the Hydra or standard Motec setup that requires an extra $5500 license and CS degree to run the FA20?
RickyB is offline   Reply With Quote
Old 02-10-2014, 11:04 AM   #764
jamesm
the ability to program custom control logic... i.e. new routines not yet imagined by the original developers... similar to custom maps in racerom only even more powerful since you can use literally any inputs and modify any outputs, and do your own calculations directly.
an example is differential wheel speed traction control. with ecutek you'd make a few separate custom maps, two each comparing wheel speed front and rear (front left vs front right, rear left vs rear right) and pick the highest, then another map to compare the output of each of those (so comparing highest front with highest rear), then use the output from that in another map to make whatever torque control adjustments you'd like to accomplish traction control. it works, but it takes up a lot of valuable custom map real estate and isn't very straightforward.
to use this with motec requires a special ecu (build ecu) and licensing, which isn't geared toward the end user and is more or less for shops to implement custom features for their customers. all of the comparison logic would just be written into the routine in whatever language they implement those things in using their api. so it's much harder (i.e. requires significant programming knowledge) but ultimately cleaner and more powerful (the routines run much faster than custom maps do).
i'm not aware that the hydra offers anything like this at all.
Old 02-10-2014, 11:05 AM   #765
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Cheers,
William Knose
Very cool! I appreciate the info
The Racers Line is offline   Reply With Quote
Old 02-10-2014, 11:40 AM   #766
RickyB
Cool, but why do you need this capability to control the FA20? What is missing from the current map sets provided by the Hydra and basic Motec that will prevent you from running the engine properly?
Old 02-10-2014, 11:41 AM   #767
jamesm
I use custom maps and logic for everything from properly controlling di/port fuel quantity to traction control, boost by gear, etc.
Really it's not about 'what problem can this not solve'. It's about the ability to solve problems you don't know you have yet.
Old 02-10-2014, 12:41 PM   #768
RickyB
I would argue that the folks who developed these systems have already thought about the most effective way to handle the problems that street and race cars will run into and incorporated those features into the standard mapset.
I have taught tuning classes and have personally met very few tuners that have the skillset or background to define and use a feature as advanced as custom maps. For example, the Hydra lets you build very complex, advanced expressions to control the outputs (about a step below the level of difficulty of custom maps) and yet I know of only a couple tuners that have ever managed to build a new, useful output function without my help even though everything is fully documented in the help panels.
You do have a point, though, if you ever think you will need custom map programming features, you may have to pay a lot to get these in stand alone systems.
The Following User Says Thank You to RickyB For This Useful Post:
jamesm (02-10-2014)
Old 02-10-2014, 01:42 PM   #769
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Most of the custom maps @jamesm is refrencing are to get around limitations of the Subaru BRZ ECU logic or to add features to the ECU that it was not intended to do such as FlexFuel, boost control, and wideband O2 readings. I would expect Hydra to be able to do all those things very easily.
jamesm (02-10-2014)
Old 02-10-2014, 01:51 PM   #770
DeliciousTuning
We are using the EcuTeK with custom features on the forced induction vehicles to resolve small problems that can not be resolved within the OEM functionality. Some of those items include boost control (with added safety margins), fueling control and knock control between shifts.
With a Hydra or Motec you would not have these problems and should be able to create whatever maps you need to tune the vehicle.
Cheers,
William Knose
jamesm (02-10-2014)
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
