Old 02-08-2014, 05:22 PM   #113
jeebus
Hey @shiv@vishnu, I really like the way the car feels with the VVT intake and exhaust changes that you did to the 1.55b gas maps. However, I noticed that the e85 maps don't have any differences to VVT vs the 1.42 maps. Do you plan on applying similar changes to the e85 maps in those areas?
jeebus is offline   Reply With Quote
Old 02-09-2014, 11:48 AM   #114
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Originally Posted by Ondreiko View Post
And i have one more doubt with my ROMs definitions - they are MILES and FAHRENHEITS in accordance with RomRaider tables - please confirm if it should work correctly with my metric car and ECU?
Or is it just RR.xml definitions feature?
Sorry for mistyping, i meant RR.xdf file of course
Ondreiko is offline   Reply With Quote
Old 02-09-2014, 12:28 PM   #115
aero.kit
Drives: GT86
Hi Shiv,
http://datazap.me/u/aero/155-rom?log=0&data=1-9
3rd gear pull with 1.55b
Mods - only Injen Intake
aero.kit is offline   Reply With Quote
Old 02-09-2014, 02:46 PM   #116
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by aero.kit View Post
Hi Shiv,
Looks solid. Good timing, AFR is fine. Although I do expect it to richen up slightly as LTFT climb slightly (with more driving). Russia must be cold!
Shiv@Openflash is offline   Reply With Quote
Old 02-09-2014, 05:43 PM   #117
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
1.55b Stage 2 EL Header Gas Custom 1
2000-7300 rpm 3rd gear automatic transmission
3 back to back
http://datazap.me/u/tonystewart/3-pu...1?log=0&data=1
Modifications in signature
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 02-09-2014, 05:50 PM   #118
Shiv@Openflash
Drives: 2013 FRS
3 back to back
We're getting there. Another custom tune file was emailed to you a minute ago.
For those wondering, tonystewart and I are doing an e-tuning job for his aftermarket FA20.club intake which make the car run quite rich. So we are taking small steps to get it to where it needs to be
Cheers
Shiv
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
fstlane (02-09-2014), troek (02-09-2014)
Old 02-09-2014, 07:39 PM   #119
Darkrune
Darkrune's Avatar
Drives: 2017 86
Will someone please PM a link of which map goes to what bolt-ons etc? I am having trouble searching for this with this awesome forum search we have here. Thanks!!
Darkrune is offline   Reply With Quote
Old 02-09-2014, 07:42 PM   #120
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Cheers
Shiv
thats amazing.. I will be right in a few months with you Shiv. I'll have the OFH and Namelss OP/Downpipe which I am sure will allow me to crank out a few more horses with custom tune!
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 02-09-2014, 08:10 PM   #121
steve99
Drives: FT86
If you download the tune files from the openflash web site and have a look in the "release notes" it will tell you
Stage 1- For vehicles equipped with original header. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel only.
Stage 2- For vehicles equipped with aftermarket cat-less headers. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel only.
If it labeled E85 then you must run E85 fuel
Use Equal length (EL) or Un-equal length (UEL) tunes depending on your header type if you have changed to catless headers
If you using an aftermarket intake (CAI) then you will most likely need to opt for the "e-tune" package to get it running correctly as the MAF (mass air flow) sensor will likely need re-calibrating (re-scalling) to suit intake unless you can scale your own MAF and edit the tune appropriately.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Darkrune (02-09-2014), Shiv@Openflash (02-09-2014)
Old 02-09-2014, 08:37 PM   #122
jamesm
Scaling the maf is super easy. Everyone should do it, regardless of their intake setup. OFT makes it possible, no reason not to do it.
The Following User Says Thank You to jamesm For This Useful Post:
TIE Pilot (02-09-2014)
Old 02-09-2014, 09:08 PM   #123
Darkrune
Darkrune's Avatar
Drives: 2017 86
Thanks! Looking forward to this since I am having idle dip issues that have been exacerbated by my revoworks header installed.
Old 02-09-2014, 09:25 PM   #124
tonystewart
Thank you
Old 02-09-2014, 10:08 PM   #125
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Why do you say everyone should scale the MAF? Are you talking EVERYONE with an aftermarket tune (and really everyone since everyone should have a tune) or do you mean everyone with a non-stock airbox?
Luckrider is offline   Reply With Quote
Old 02-09-2014, 10:10 PM   #126
jamesm
Everyone with an 86. @mad_sb did some testing a while back and found his completely stock car to have significant fueling error (~15% in some spots iirc).
If you have an OFT it's free, so there's no reason not to. If you don't have an OFT or ecutek, well, you should .
The Following 2 Users Say Thank You to jamesm For This Useful Post:
Sonolin (02-10-2014), troek (02-09-2014)
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
