Old 01-30-2014, 10:28 AM   #169
DougW
Drives: FR-S stock for now
Originally Posted by OICU812 View Post
@DougW still alive? Any hope of this project bearing fruit??
Yep, still alive 11 degrees f 2" ice, will this winter ever end? I'm still trying to find a shop to work with to test the track setup that is near by, so far no luck. I'm retired and not looking to go back to a full time job selling shocks so finding a company to work with is the other part of the puzzle. Just a few details to work out on the shocks like bushing lengths and wiring install lengths other than that coming up with a good set of maps.
DougW
DougW is offline   Reply With Quote
The Following 3 Users Say Thank You to DougW For This Useful Post:
Anthonytpt (01-30-2014), DAEMANO (01-30-2014), waterbison777 (02-06-2014)
Old 01-30-2014, 10:35 AM   #170
DAEMANO
Time Traveller
DougW
Old 01-30-2014, 10:39 AM   #171
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
DougW
Hot Bits?
from what i know they often do side projcets with independent engineers.
Old 02-07-2014, 09:08 AM   #172
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
so looking at the newly released B6 and B8 units, how much would a retrofit of the adjustment mechanisms cost if one was to send you these things.
or are you now looking at outsourcing this to someone based on your designs\?
Old 02-07-2014, 07:14 PM   #173
DougW
Because of the 46mm piston it can't be retrofitted to the rear but I have the design complete with springs and camber plates all I lack is testing on track to get the calibrations worked out. I will be in MD next week to do more shock dyno testing and to put together a marketing plan including finishing the testing so if this winter will let up maybe I can get back on this project. I now have 9,000 miles of road testing without issues just need the same on track.
Thanks
DougW
The Following 4 Users Say Thank You to DougW For This Useful Post:
7thgear (02-07-2014), DAEMANO (02-07-2014), solidONE (02-08-2014), waterbison777 (02-08-2014)
Old 02-08-2014, 02:21 PM   #174
waterbison777
Thanks
DougW
Just... move out here to california. all your problems will be solved!
waterbison777 is offline   Reply With Quote
Old 02-08-2014, 06:31 PM   #175
DougW
I have mountains with trees and no mud slides, I can go outside and burn a tire or shoot my 22 and nobody shows up with helicopters. Winter will end soon and we can go play some more. Thanks for the offer though.
DougW
The Following User Says Thank You to DougW For This Useful Post:
Calum (02-08-2014)
Old 02-09-2014, 01:17 AM   #176
Boxer486
Drives: small
Just... move out here to california. all your problems will be worse!
FTFU
Boxer486 is offline   Reply With Quote
Old 02-09-2014, 01:25 AM   #177
waterbison777
Originally Posted by Boxer486 View Post
FTFU
Touche
Sent from my Nexus 4 using Tapatalk
Old 02-23-2014, 09:00 AM   #178
DougW
Finally got a chance to get back on the shock dyno using some special software with a travel pot. I was able to change the shock valving for bump/rebound from full soft on bump to full hard on rebound up to 8" per sec, at 20" per sec it started falling behind a little but with some tweaks I think I can catch that. As for a regressive curve, absolutely can change the valving during bump/rebound anyway it's needed, I think it would be possible to create a valve profile in software. The more I play with these is the more I want to try stuff I have got to get a shock dyno here to work with. While this isn't part of the kit for the Scion it shows how much control with more sensors you can have. I wish I had some screen shots but just didn't think about it until I was on the way home. Now that winter is maybe going away I can get some track testing done.
Thanks
DougW
The Following 5 Users Say Thank You to DougW For This Useful Post:
DAEMANO (02-23-2014), fasteddy (02-24-2014), InvalidJohnny5 (02-24-2014), solidONE (02-23-2014), Turdinator (03-27-2014)
Old 03-26-2014, 11:13 AM   #179
Boxer486
Drives: small
bump
Old 03-27-2014, 08:27 AM   #180
DougW
Thanks for the bump, hope to be testing the next revision soon.
DougW
DAEMANO (04-02-2014)
Old 04-02-2014, 03:58 AM   #181
DAEMANO
Time Traveller
DougW
Keep up the good work Doug. Won't take my eye off this thread. Way too much promise here.
Old 04-02-2014, 08:43 AM   #182
DougW
Should be at VIR Tuesday and Wednesday to test with my car with the lowered 400/450 spring setup but on stock tires so we should get some good info on balance control. In earlier shock dyno testing by adding a travel sensor I could change the bump/rebound during the stroke to the point of true regression control. I wish I could put the time into this full time to finish it up.
DougW
Calum (04-02-2014), DAEMANO (04-02-2014), FrX (04-03-2014)
Anyone ETA on Bilstein coilovers? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 01-31-2014 11:26 AM
Bilstein Damptronic on an FRS DougW Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-10-2013 12:15 AM
All Bilstein and Muteki 10% off during month of July! Infamous Performance Brakes, Suspension, Chassis 24 07-31-2013 01:52 PM
All Bilstein and Muteki 10% off during month of July! Infamous Performance Wheels and Tires 24 07-31-2013 01:51 PM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
