Old 02-08-2014, 06:55 AM   #1
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
Unhappy Engine Check Light..HELP
So, yesterday i was on the highway, and suddenly my check engine light comes on. When i put it in manual and downshifted it wouldn't raise the rpm's like always. When i got home let it cool down, and disconnected the battery for 20 minutes when i turned back on everything went back to normal. Is there anything i should be looking for?
AZOOZ_95 is offline   Reply With Quote
Old 02-08-2014, 07:02 AM   #2
Silent_Dan
Drives: 2013 Scion FRS
You needed to have the code checked at autozone before you cleared it because we can't tell you otherwise man.
Silent_Dan is offline   Reply With Quote
Old 02-08-2014, 07:07 AM   #3
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
So should i take it to the dealer?
Old 02-08-2014, 07:08 AM   #4
steve99
Drives: FT86
The code may still be in the stored code memory, as above best to take it to dealer or at least read the error code before you cleared it.
Probably worth runnning obd scan toll on ot or taking it to dealer to see if code still in memory
sounds like it went into limp home mode, not good.
Old 02-08-2014, 09:24 AM   #5
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
Just came back from the dealer. He checked the ECU, and got nothing. He said if it happens again just take it back.
Thanks for the reply
Old 02-09-2014, 12:20 PM   #6
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
The check light came again so i went to the dealer and they guy, said it was throttle coil or something like that, im not sure if its serious or not. He said it was only on the right side.
Old 02-09-2014, 01:30 PM   #7
Silent_Dan
Did he say what the code was?
It would look something like this. P0xxx
I'm assuming he was talking about the coil pack which fires the spark plug.
If I assumed wrong please fill free to correct me because I've never heard of a throttle coil.
Old 02-09-2014, 01:57 PM   #8
stugray
Drives: 2013 GBS BRZ Limited
Actually there IS a coil in the throttle position sensors.
Both in the pedal and the throttle body butterfly position sensor.
If he stated that "it was on one side", then it probably is one of the COP packs.
Old 02-09-2014, 02:28 PM   #9
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
I think it was 53 or 35
Old 02-09-2014, 02:29 PM   #10
AZOOZ_95
Middle Eastern 86
AZOOZ_95's Avatar
Drives: RED GT86
What is the COP packs? and is it serious ?
Old 02-09-2014, 03:20 PM   #11
stugray
"coil on plug" it can be replaced in about 3 minutes.
The Following User Says Thank You to stugray For This Useful Post:
AZOOZ_95 (02-11-2014)
Check engine light on but no codes!?!? midnight23 Engine, Exhaust, Transmission 9 08-01-2014 11:20 AM
Check engine light. Help!!!!! sf86 Issues | Warranty | Recalls / TSB 2 06-05-2013 03:51 AM
Check engine light? czar07 AUSTRALIA 0 09-01-2012 02:50 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 09:50 PM
