Old 01-28-2014, 10:56 AM   #43
charged86
charged86's Avatar
Awesome. Fits my needs.
That's what I'm screamin
Old 01-28-2014, 11:13 AM   #44
jamesm
second that. this can't come soon enough . well that, and the money to pay for it when it does lol.
Old 02-07-2014, 07:45 PM   #45
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
updates @Dustin@Dynosty
slicktop is offline   Reply With Quote
Old 02-11-2014, 01:16 PM   #46
Dustin@Dynosty
Sorry for the delay guys, we have been covered up in the shop trying to get projects out for TX2K14. We will be offering the system in two ways:
$679- Walbro 485 fuel pump with Dynosty Billet in tank fuel pieces and Billet rails. (you build the rest of the kit)
$1499- Full system with Walbro 485 fuel pump, Billet in tank fuel pieces, all required AN fittings, Aeroquip Star lite hose, Fuelab regulator with gauge, Fuelab filter, Dynosty Billet rails and hardware.
both options will be plus shipping. We are working to have this ready to start shipping in the weeks following TX2K14. Thanks for your patience.
Dustin@Dynosty is offline   Reply With Quote
Old 02-11-2014, 01:30 PM   #47
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
How has the testing gone? Curious about uptake from over the hump and also fuel starvation around corners. Thanks, guys!
cobrabyte is offline   Reply With Quote
Old 02-11-2014, 02:29 PM   #48
Dustin@Dynosty
I am not following the first part of your question.
As far as around corners, I believe someone else asked about this question as well, there is no better fuel solution than a properly designed surge tank for a track car. If you are on a competitive level then most will be willing to go that route. This fuel solution is for those looking to increase fuel flow for boosted applications under normal street driving conditions. It will still be using the factory basket assembly so you will be limited to the same gas tank design as factory as far as fuel sloshing around on turns. For the track guy not willing to run a surge tank, we can work with those guys over time to adjust the venturi setup to best suit their needs but that doesn't prevent fuel from sloshing, it will only allow more fuel to return to the driver side of the tank, which yes should aid in fuel starvation if we can always keep it full. But the immediate release will not be focused on a road racing application.
*** just a final note on that, if we were able to make adjustments to further improve on fuel starvation around corners, it wouldn't be a whole system redesign so would be minor cost effective change for those early adopters to be able to upgrade.
Old 10-08-2018, 05:27 PM   #49
smudge
Drives: Supercharged GT86
Has anyone got one of these installed?
smudge is offline   Reply With Quote
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
Dynosty Presents MXP Exhaust System for FR-S/BRZ Dustin@Dynosty Engine, Exhaust, Bolt-Ons 12 11-08-2012 09:15 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
Dynosty Pushing the Limits... Fuel Pump and Clutch Dustin@Dynosty Engine, Exhaust, Transmission 29 08-15-2012 06:53 PM
