Old 01-05-2014, 10:43 AM   #29
bakerr6
Drives: 2013 raven black fr-s
dustin, pm me if you are looking for someone local that will be switching from na to FI in about a month or 2. I can pick the kit up from Charged86 (Ryan) if you do not prefer to ship it. I go through usually 2+ tanks of E85 per week, and will be even more soon
bakerr6 is offline   Reply With Quote
Old 01-05-2014, 01:33 PM   #30
charged86
charged86's Avatar
they are 2 hours south of me. but when I get mine they can ship to me if you really want to pick it up in the nati
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 01-05-2014, 08:37 PM   #31
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
Watching.
Cessblood is offline   Reply With Quote
Old 01-06-2014, 12:51 PM   #32
Ross
Drives: 85 corolla gts
How many tank fulls would you need feed back on? Also more info on the lines used would be appreciated, such as is it using a hard line under the car ect... I have phoned you and left a message. If you would like feel free to pm me about this as I have a few other questions as well. If I do not have to reinvent the wheel so to say for a upcoming project this could be a nice solution.
Ross is offline   Reply With Quote
Old 01-06-2014, 01:58 PM   #33
Dustin@Dynosty
Hey Ross-
I apologize, we are closed on the weekends and have been covered up in the shop this morning, the lovely -10 degree weather that showed up has been a problem for some of the cars being delivered for builds. I guess this customer forgot to bleed the air suspension systems in the winter so have a slammed car on frozen air suspension stuck on the transport services truck. But on topic...
I don't suspect it to take more than 2-3 tank fulls, we will just want the hangers on both sides pulled when the "fill up tank light" comes on so we can get a measurement of how much fuel is in each side. If tank one measures out fine and tank two confirms it, then we will just want a third check and will be good. If tank one has a balance issue we have the parts already on the shelf to modify the flow up or down. Just make take an extra tank or two.
As far as info on the lines, Aeroquip Star Lite -6AN for feed and return. We removed the gas tank vent hard line along with the factory feed hard line for our shop car and ran through the factory brake/fuel line supports that have been modified. But we can sell the system a la carte if you want to purchase just our machined items and supply your own fuel lines etc.
I am back from lunch now if you would like to call in with any other questions. We received an overwhelming amount of emails, pms, and phone calls after announcing this so we are working to get responses back to everyone. 502-384-8882
Dustin@Dynosty is offline   Reply With Quote
Old 01-06-2014, 02:18 PM   #34
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by Dustin@Dynosty View Post
Hey Ross-
I PM'd you regarding the fuel system, but am quoting you to tell your air ride customer to throw some air brake anti-freeze into his tank. 1-2 capfulls. His check valve and/or water trap if he has one is most likely frozen lol.
xxscaxx is offline   Reply With Quote
Old 01-06-2014, 02:24 PM   #35
Dustin@Dynosty
yep, I was lucky enough to stay in the office while they worked it off the truck and into the shop to let it thaw. but that is exactly what we have sitting here as soon as it does.
Old 01-22-2014, 11:38 AM   #36
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
our system will be available as a whole and a la carte but we are finishing up some final details and will revise the first post with pricing
Any word on this?
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 01-22-2014, 11:58 AM   #37
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by AZFA20 View Post
Any word on this?
They are still doing some fitment and testing afiak.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 01-27-2014, 08:59 PM   #38
Ny Brz
Hella Flush
Ny Brz's Avatar
I'll be keeping this in mind when I go bigger and new block
Ny Brz is offline   Reply With Quote
Old 01-27-2014, 09:38 PM   #39
jamesm
Any idea when this will be available? I need to ditch this dw ASAP.
Old 01-28-2014, 07:21 AM   #40
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The Dynosty 1000 Fuel System is a full feed and return system that retains the OEM venturi system (draws fuel from the other side of the saddle tank), allows for more fuel flow, and keeps everything concealed safely under the factory panels as designed by Toyota/Subaru.
There has been reports by other vendors that the OEM venturi system can suffer from starvation on hard cornering/ high HP applications and also fuel starvation issues with less than half a tank on the car if a surge tank is not used.
Is this addressed by this new fuel system?
Old 01-28-2014, 10:49 AM   #41
Dustin@Dynosty
Originally Posted by KAB-FRS View Post
Does it come with a fuel pressure regulator? I dont see it on the pictures
Yes it will include everything but injectors (which will be available in addition)
Working out the final details for testing.
How I should of worded the description is that we have designed a new venturi system that will keep both sides of the tank draining properly as designed from the factory. While it will work on a track application, we have not tested the system for road course application as of yet. If you are an avid road racer, nothing will beat a properly designed surge tank if the vehicle is a track only car. The system we have designed is going to be more for your street and drag applications that do not want a separate tank in the cabin or trunk and need to exceed the limitations of a drop in fuel pump.
Old 01-28-2014, 10:51 AM   #42
Sportsguy83
Drives: Limited BRZ
Awesome. Fits my needs.
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
Dynosty Presents MXP Exhaust System for FR-S/BRZ Dustin@Dynosty Engine, Exhaust, Bolt-Ons 12 11-08-2012 09:15 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 05:03 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
Dynosty Pushing the Limits... Fuel Pump and Clutch Dustin@Dynosty Engine, Exhaust, Transmission 29 08-15-2012 06:53 PM
