Old 02-06-2014, 08:52 PM   #1
Tiremonkey0824
Drives: 2013 Argento 6mt
Anybody else have noises after lowering?
Anybody else getting popping noises on uneven surfaces after being lowered? My car just recently starting doing this and I'm not sure where the problem lies. It's not the struts or control arms. It's definitely not ball joints or bushings. At this point I'm thinking its either the sway bar end links or the chassis itself flexing and popping. I'm lowered on h&r super sports with koni struts; also have whiteline lower control arms, and whiteline roll center/bump steer correction.
Tiremonkey0824 is offline   Reply With Quote
Old 02-07-2014, 11:24 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Yes. Its gonna make more noise after lowering. I would guess sway bar is binding as a lot of the noises go away with adjustable links it seems.
Old 02-07-2014, 11:35 AM   #3
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I have a rolling/sliding type noise like something is loose in the rear (it might be the seats actually) when I take a bumpy turn, such as a driveway. But that's it for me. RSR Superdowns and nothing else.
Old 02-07-2014, 11:58 AM   #4
sshole
I had a weird popping noise after lowering my car on RCE yellow springs. Then I found out I didn't tighten down the front sway bar end link nut to the strut.
sshole is offline   Reply With Quote
Old 02-07-2014, 01:36 PM   #5
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
did you use an impact gun to undo the center nut? most people who have basically killed their shocks, but these are on the stock ones. if you didn't, maybe the center nut isn't tightened all the way. this happened to me when I tightened the nut before lowering the car and loading the wheels. i'm on H&R super sports also.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 02-07-2014, 02:15 PM   #6
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
call me crazy, but i think i have the same situation with my rsr's installed as well
supramkivtt2jz is offline   Reply With Quote
Old 02-07-2014, 04:57 PM   #7
Tiremonkey0824
Nope, when I installed my konis I used pass through ractchets so I could hold the strut still. I'm pretty confident that my struts are fine. I'm still leaning towards sway bar end links being my issue since they are still OEM. Its only happening on uneven surfaces at low speeds when the chassis seems to be flexing.
Old 02-07-2014, 05:47 PM   #8
BlueDubbinTDI
Have you inspected them yet? I haven't done anything since mine were installed because I drive with my windows down when its warm so I rarely hear it.
Old 02-07-2014, 06:18 PM   #9
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
If everything's been tightened properly and installed correctly nothing should make noise. Unless you're past -1.5" from stock nothing should come in contact to any of the components clearance wise.
Old 02-08-2014, 10:35 AM   #10
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
My initial guys was that I preloaded the trailing arms and it might be contributing to it. My plan of action is to re torque everything back there
Old 02-08-2014, 11:32 AM   #11
BlueDubbinTDI
Let me know if that helps
Old 02-08-2014, 07:20 PM   #12
rgt
Drives:
Happened to me before too. The nut came off and the front sway bar just kept clanking around. Drove me nuts trying to figure out where the clanking was coming from.
rgt is offline   Reply With Quote
Old 02-08-2014, 08:11 PM   #13
Dave9905
Drives: 2013 Scion FR-S 10 Series #1864
im on RSR Superdowns and have not experienced any issues or noises...
Dave9905 is offline   Reply With Quote
Transmission Grinding and fuel pump noises FRSChris13 Issues | Warranty | Recalls / TSB 14 09-15-2014 05:23 PM
Pebbles and road debris noises FatFree Scion FR-S / Toyota 86 GT86 General Forum 25 12-18-2013 10:10 PM
various noises abutterman Issues | Warranty | Recalls / TSB 0 10-23-2013 12:26 AM
strange coilover install noises/ tried everything NemeGuero Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 02-26-2013 11:02 PM
