Old 02-07-2014, 12:04 PM   #43
Racecomp Engineering
Brake duct testing is a good simple experiment. We did it a few years ago when we developed our kit for STI. Get some temp strips to make life easy.
I'm surprised no one has asked you to test the Whiteline roll center kit!
- Andy
normancw (02-07-2014)
Old 02-07-2014, 12:18 PM   #44
troek
troek's Avatar
Drives: 2012 Toyota 86
Originally Posted by mtsui View Post
final drive on NA set up
I second that. i havnt seen any hard data on final drive improvement. although, almost every 86 doing time attack on tsukuba has 4.55-4.8, so that is proof enough that its faster. the question is, how much faster?
troek is offline   Reply With Quote
Old 02-07-2014, 12:24 PM   #45
normancw
normancw's Avatar
Drives: 128i
- Andy
This kit?
http://www.whiteline.com.au/product_..._number=KCA313
KCA313 is designed to raise the front roll-centre geometry by using specially engineered ball-joints & tie rod ends while still maintaining original steering geometry. Front roll geometry actually encourages roll the lower you go. Testing proves that raising the front roll-centre resulted in a substantial increase to front roll resistance & a significant reduction in suspension compression of the outside front wheel during cornering (less roll). This improves weight distribution & maintains a better camber angle which ultimately improves front grip. The overall outcome is significantly reduced understeer through reduced front wheel compression as well as improved steering precision & vehicle stability.
http://www.racecompengineering.com/i...ction-kit.html
Your description states it's essential for lowered cars - if minimally lowered (i.e., with RCE Tarmac 2s), is this still beneficial?
normancw is offline   Reply With Quote
Old 02-07-2014, 12:28 PM   #46
CSG Mike
CSG Mike's Avatar
Originally Posted by SeanRTR View Post
I'd like to see 3-4 different brake pad compounds tested to see which has the best feel/bite after several laps of use. Comparison between race compounds of Hawk, Carbotech, Ferrodo, etc etc... I'd be curious to get feedback from an experienced driver from back to back sessions as far as which pad provided the best feel, and if it could withstand the heat for a prolonged session.
I'd also like to see some data of differnt tire sizes (same compound), which you may already have. I've heard you constantly say that wider tires rob you of straight away speed in a low powered n/a car. I'm surprised that cornering speeds don't make up for these negative effects you've found on the straights.
I might have done that before personally...
Anthonytpt (02-07-2014), normancw (02-07-2014)
Old 02-07-2014, 12:29 PM   #47
CSG Mike
CSG Mike's Avatar
That is proof that it's faster at Tsukuba.
fatoni (02-07-2014)
Old 02-07-2014, 12:36 PM   #48
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
http://www.ft86club.com/forums/showthread.php?t=27647
The Following User Says Thank You to 7thgear For This Useful Post:
Old 02-07-2014, 02:35 PM   #49
Originally Posted by normancw View Post
This kit?
That's the one. It will especially help a more drastically lowered car but you should still be able to feel it with a 1 inch drop. I like to think I have a decent butt dyno and I could feel it pretty well on Imprezas with lowering springs. Less noticeable on firmer coilovers.
But...I'd love to see some testing on a BRZ.
- Andy
Old 02-07-2014, 02:44 PM   #50
CSG Mike
CSG Mike's Avatar
I suspect we'll explore RC correction at some point... we're squaring away horsepower at the moment, but looking for avenues to explore next, because we're almost done.
Racecomp Engineering (02-07-2014)
Old 02-07-2014, 03:24 PM   #51
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
aero tests that apr splitter looks too small to be any use
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 02-07-2014, 04:57 PM   #52
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
I will be testing the 4.556 final gear this year and give feedback how much faster, im guessing 3 seconds
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following User Says Thank You to RehabJeff86 For This Useful Post:
Old 02-07-2014, 06:20 PM   #53
donutfilling
donutfilling's Avatar
Drives: frs
Mechanical LSDs?
Different gearing?
Better flywheel/clutch combo? either NA or FI
donutfilling is offline   Reply With Quote
Old 02-07-2014, 06:36 PM   #54
donutfilling
Drives: frs
They generally like to test to socal tracks and I feel ideal gearing is track specific. A shorter gear will give it slightly better acceleration in straights overall but I know many people who prefer the AP1 tranny at buttonwillow vs AP2 despite having "slower" gearing because it saves them a shift to 5th on certain corners.
Old 02-07-2014, 06:55 PM   #55
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
- Andy
This kit?
I have the Whiteline roll centre kit on my car. I'm about 20mm lower on coilovers. Works as advertised - I was getting a whole bunch of bump steer before which is now almost gone, and the steering turns in sharper now too.
Definitely happy with this mod. I'd recommend it to anybody.
A 3rd party test would be great though.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
The Following User Says Thank You to ultra For This Useful Post:
Old 02-07-2014, 07:03 PM   #56
ultra
Curious cat.
ultra's Avatar
This. I'd love to see the final drive gears tested but I suspect that the benefits might end up being very track specific.
I'd love to see somebody test out various wheel and tire combos on this car, scientifically. It'd be great to know how different rims widths, tire sizes, pressures, compounds and tire models affect performance.
Tires, or aero.
Hot Version Vol.115 Featuring a track test of the GT86 and more demby123 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 37 07-31-2013 05:05 PM
Product testing. What would you guys like to see CSG test? CSG Mike Tracking / Autocross / HPDE / Drifting 94 05-21-2013 06:27 PM
RCE needs a test car from a track day enthusiast! Racecomp Engineering Northwest 0 10-19-2012 10:37 PM
Got to test a FR-S on the Race Track on Saturday gbhstrat Scion FR-S / Toyota 86 GT86 General Forum 5 09-24-2012 08:16 PM
Revspeed Track Test video ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 05-10-2012 01:19 AM
