#3249 |
Drives: GBS Premium
Looks great, I'm going to do mine tomorrow.
#3250 |
Drives: Frs
Hey guys I got some question.. I'll be getting my kit soon (intercooled)and I want to run e85(deliciuos tunning flex fuel kit) but just wanna know what u guys opinion on. E85 is? Is it safe? It's my dd n I'm thinking I'll be running e85 all the time should I run pump91once in a while? Do I run a risk catching the engine on fire? (I know Visconti had a problem with his flex fuel kit n idk what was the cause that's y I ask..Does it really rust the internal parts in the fuel lines/engine?...I know deliciuos tuning is one of/or the best at tuning this kit (and many others) so I'm not worried bout his tune just wondering what the cons of e85 are
Thanks for the help |
#3251 |
Grip>Slip
i'd run E85 every day if it were available closer to my home.
#3252 |
@xjohnx
Was it too hard to reach the nozzle on the crankcase? Looks like you just inserted the hose into the existing hose?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#3253 | |
Grip>Slip
#3254 | |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | DriftEm (02-07-2014) |
#3255 | |
EDIT - I think the PCV line.
#3256 | |
#3257 | |
Drives: 2016 Subaru WRX
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
#3258 |
@Powersfrs I run e85 about 10-15% of the time just because it's about 20 miles from me. So I get it when I can. I'd run it more if it was closer. I still like to cycle a tank or two of regular 93 pump through just in case. e85 hasn't been around long enough to know of all the effects. It can be linked to corroding lines over time. It's extremely knock resistant (comparable to 105/106 octane). There's not a lot of evidence to it's long-term effects but I suspect with 10% of gas now being ethanol, it's already in the system enough to cause any effects.
Bottom line for me is I'm a little conservative with using it but it's super simple. Just pull up, fill up, switch maps, and you're good to go. It's crazy easy to live with.
#3259 |
Grip>Slip
Oh that one, not hard at all, you pull it hose off the middle fitting, insert the coupler, attach the supplied hose to the other end of the coupler and run it to the can, then you run the can to the the now vacant middle port.
#3260 |
Yeah, my bad, my terms are all off. So the radium supplied hose just inserts to the factory hose? I guess my question is can you remove the OEM hose so you don't have hoses disconnecting.
#3261 |
Grip>Slip
you might be able to, i didn't want to try. the connections using the coupler seemed plenty secure.
| The Following User Says Thank You to xjohnx For This Useful Post: | swift996 (02-07-2014) |
#3262 | |
-2016 Subaru WRX
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
