Old 02-05-2014, 06:59 PM   #3235
xxscaxx
Drives: 2013 SWP BRZ
Originally Posted by DriftEm View Post
Sorry, I think you have to log in Facebook
Sent from my SAMSUNG-SM-N900A using Tapatalk
nope, i'm logged in, still not working lol
xxscaxx is offline   Reply With Quote
Old 02-05-2014, 08:09 PM   #3236
DriftEm
DriftEm's Avatar
For cars with Innovate supercharger, the driver side can is for PCV line:
and passenger side can is for the crankcase vent:
DriftEm is offline   Reply With Quote
The Following 5 Users Say Thank You to DriftEm For This Useful Post:
1010110 (02-06-2014), Alabang 86 (02-06-2014), normancw (02-05-2014), stockysnail (02-06-2014), xxscaxx (02-05-2014)
Old 02-05-2014, 08:14 PM   #3237
swift996
swift996's Avatar
@DriftEm any chance you can draw or map out the diagram of what you ran to where? I've never ran a catch-can set up. I get the crankcase one but a little confused about the whole set up.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-05-2014, 08:36 PM   #3238
DriftEm
DriftEm's Avatar
I marked the pictures above. It's very simple, the middle hose nipple on back of the supercharger is where you are connecting to. As marked in the picture above, the hose that comes off the charger (red arrow) goes to the top nipple of catch can, use the coupling nipple that came with kit to connect the hose from kit to this hose. The middle nipple (green arrow) goes to the lower nipple on the catch can, this is where you use the supplied hose with the kit. I hope this helps.
The Following 2 Users Say Thank You to DriftEm For This Useful Post:
swift996 (02-05-2014), xxscaxx (02-05-2014)
Old 02-05-2014, 09:39 PM   #3239
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
The red one comes from the crankcase under the manifold, not the charger. Which I think is what you meant, as your pictures are titled correctly.
Lawnik is offline   Reply With Quote
Old 02-05-2014, 09:44 PM   #3240
DriftEm
DriftEm's Avatar
It is connected to the charger at that end, that's what I mean.
Old 02-05-2014, 09:55 PM   #3241
DriftEm
DriftEm's Avatar
Originally Posted by normancw View Post
So you have to switch the sides for the PVC line for Innovate cars?
yes
The Following User Says Thank You to DriftEm For This Useful Post:
Old 02-05-2014, 10:51 PM   #3242
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
@DriftEm very very neat.
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
DriftEm (02-05-2014)
Old 02-06-2014, 11:05 AM   #3243
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by olorin View Post
Here is a SS of the some logging I did, could anyone tell me if what I am seeing here is normal, I am not sure how to interpret this:
The AFR seems to stay for the most part around 14.6ish, then goes lean when the throttle closed (which I would expect). Any insight is appreciated.
I don't see anything scary there, but you never went more than 40% throttle and you never went into boost either. It looks like it remained in closed loop operation.
olorin (02-06-2014)
Old 02-06-2014, 04:12 PM   #3244
olorin
olorin's Avatar
Drives: GBS Premium
Thanks, I have few others logs, under boost/WOT the AFR dips to 12.xx. AFR seems to follow the inverse of the throttle position (and MAP) -- which makes sense to me.
The ecutek tips suggest to use the Manifold Relative Pressure vs RPM to display a boost curve, however I don't have that field in the log viewer. Can I calculate it using the Atmospheric pressure and MAP value?
olorin is offline   Reply With Quote
Old 02-06-2014, 04:14 PM   #3245
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I normally just subtract 1 BAR from the Atmospheric pressure and that gets you close. It will vary a little bit based on altitude.
olorin (02-06-2014)
Old 02-06-2014, 05:22 PM   #3246
xjohnx
Grip>Slip
xjohnx's Avatar
Installed the PCV side of the radium cans tonight (on the drivers side, like suggested in this thread.)
For the cranckcase vent side, i just use the hose that's connects to the plastic innonvate intake for the input of that catchcan and route the output back into the same port, correct?
Old 02-06-2014, 05:34 PM   #3247
olorin
olorin's Avatar
Drives: GBS Premium
Yep.
Old 02-06-2014, 10:13 PM   #3248
xjohnx
Grip>Slip
xjohnx's Avatar
Got it all installed. didn't even have to use the coupler to extend to the inlet of the crankcase catch can, the hose connected to the stock intake was long enough.
sorry for the pics, it's late and the flash isn't the best.
normancw (02-06-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
