Old 02-07-2014, 04:38 AM   #29
pnig
pnig's Avatar
Drives: 2013 Whiteout Scion FR-S
the new corvette is pretty close... starts at $51k, curb weight is a bit higher at 3300 but its got the power to start and has room for more, looks great, and has RWD
pnig is offline   Reply With Quote
Old 02-07-2014, 04:54 AM   #30
h4nh
h4nh's Avatar
Drives: Turbo BRZ & Supercharged E90 M3
Even if it's close.. there's still not very many choices still in that price range.
Besides it's over 500lbs weight difference and that's a base model vette. If you start with an FRS it would be less. Anyways, it's the fun factor of a having a custom build which isn't easy.
h4nh is offline   Reply With Quote
Old 02-07-2014, 05:10 PM   #31
Moe23
Drives: 2014 Scion FRS MT
Originally Posted by enderr View Post
...wouldn't a 2JZ swap be harder to do? Unless I'm thinking about this wrong an In-line 6 should be longer than the LS based V8. The FA20 with only two cylinders on a side is a really short motor and frankly I'm surprised an LS will fit.
Hell, of a 2JZ fits into an FT86 I'm going to shoehorn one of these into mine...
A S54B32 motor in an FT86 would be an amazing swap
Moe23 is offline   Reply With Quote
The Following User Says Thank You to Moe23 For This Useful Post:
canu_50 (03-04-2014)
Old 02-25-2014, 02:27 PM   #32
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
Originally Posted by JK21 View Post
Hi guys. So I have been doing research and I am in talks with my shop and I will be doing a 2jz swap with my FRS.
My plan and goal is to have this build done by the time January gets here as I will be in school for my master's and have to space out everything. I have enough to get decently started as I was offered a good deal on my GTR and have plenty of cash left over but school is my main priority. I will keep everybody updated.
Any updates on your build? Seems like there are only a handful out there.
Originally Posted by h4nh View Post
The swap with a Limited BRZ would be around $55k including the car.
What car is 2700 lbs, RWD, looks good, has the power output capabilities of a 2JZ-GTE, and in this price range with a completed swap?
You can always get both. lol That's what I plan to do once the C7s drop a little in price.
Drift&Drag is offline   Reply With Quote
Old 02-25-2014, 02:54 PM   #33
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by civdaddy View Post
I believe supra motors weigh ~400lbs
Ls1 motors are ~400lbs as well
I think the pushrod v8 would be better for keeping the weight distribution closer to stock when compared to an inline 6. Just saying.
What about weight balance? Wouldn't the longer (longitudinally) 2jz push the weight further out front? That is, unless one can mount it even farther back than the FA20.
Also, OP, I take it you've also sourced the transmission as well?
Originally Posted by DAN_BRZ View Post
why would you swap this motor in, for the cost why didnt u just buy a faster car to begin with?
Because this way is MUCH more personally satisfying?
^GT5 Replay Photo Mode^
Old 02-25-2014, 03:00 PM   #34
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Full interior, Ac , all electronics working and also abs/ traction
Sent from my IBrick
The Following 3 Users Say Thank You to SmsAlSuwaidi For This Useful Post:
Ravenna (08-07-2017), SirBrass (02-25-2014), Stealth Gt86 (09-02-2014)
Old 02-25-2014, 03:04 PM   #35
SirBrass
SirBrass's Avatar
Not bad. Still unbalances more than stock (stock distribution is closer to 53/47, iirc), but that's not too bad.
I guess if you get too much front dive, you can put in stiffer springs, or if you begin to lose the rear traction at higher power and speeds, you can always add aero to plant its ass back down onto the road .
The Following User Says Thank You to SirBrass For This Useful Post:
SmsAlSuwaidi (02-25-2014)
Old 02-25-2014, 03:05 PM   #36
OrbitalEllipses
Drives: Attitude
Originally Posted by SmsAlSuwaidi View Post
Full interior, Ac and all electronics working and also abs/ traction
Sent from my IBrick
Horse.
A loaded 2JZ (longblock, accessories, turbos) without flywheel is over 500lbs wet.
Old 03-03-2014, 01:04 AM   #37
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
I guess if you get too much front dive, you can put in stiffer springs, or if you begin to lose the rear traction at higher power and speeds, you can always add aero to plant its ass back down onto the road.
That is exactly what I ordered for my race suspension last week. Stiffer spring upfront and softer spring in the rear; rates 11(f) and 7(r) respectfully.
Horse.
I am curious to find out the final weight for my car (2JZ BRZ). I will definitely keep everyone posted once we wrap up on the project and I get her to a weight station. Got a feeling I'm going to love this plump SOB.
The Following User Says Thank You to Drift&Drag For This Useful Post:
SmsAlSuwaidi (03-03-2014)
Old 03-03-2014, 01:07 AM   #38
h4nh
h4nh's Avatar
what suspension did you end up with?
Old 03-03-2014, 01:22 AM   #39
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Stance Pro Comp 2 w/ Swift Springs
More info on the coilovers can be found here
Old 03-03-2014, 01:34 AM   #40
h4nh
h4nh's Avatar
sick! I heard good things about their race suspension.
The Following User Says Thank You to h4nh For This Useful Post:
Drift&Drag (03-03-2014)
Old 03-03-2014, 01:36 AM   #41
Black86
Black86's Avatar
Drives: 2013 Raven Black FR-S
In for updates guys I love the idea. I have a 2j mk3 supra I've debated on swapping to the frs.
-Raven Black 13 FR-S : The daily driver
-88 supra turbo : 2jz 66mm single on E85 in the process
Black86 is offline   Reply With Quote
Old 03-03-2014, 01:43 AM   #42
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
Now if I was focused on just straight-line speed I would look at the LS swap but even then I would've just kept my GTR if that were the case. I want this car to be well balance through all disciplines (auto x, road race, drift, drag) and that is the main goal I want to achieve with this build.
I've spent a ton of time on the S30 Z forums and this kind of swap is regular place in a similarly weighted Z car. (just sold my Z for money for the FR-S lol). For the Z's, swapping to a V8 always puts weight more towards the center making the weight distribution better.
I imagine that swapping an aluminum V8 would net better weight distribution than any inline 6 in the FR-S/BR-Z. weight distribution would probably come in real close to stock with the aluminium V8 while adding a straight 6 of any kind will throw weight way out towards the front. My guess is the split would come to 54.5F/45.5R ish.
Oh and also for a jack of all trades like you said you want a V8 would probably be better anyway. they typically have better torque curves for multipurpose setups. 500-600hp 2jz might have a bit more turbo lag than you would want for something like autox unless you go with a sequential setup which i dont know if you could fit that in the twins engine bay. would be sweet though haha
Dont get me wrong though. I dig the idea of a 2jz swap . they make a ton of power and i dig straight 6's thanks to my love for S30 Z's. Good luck with the swap.
Sypher is offline   Reply With Quote
The Following User Says Thank You to Sypher For This Useful Post:
SirBrass (03-03-2014)
What's happening at TF-Works... Touge Factory Great Lakes 93 04-24-2015 02:44 PM
What's happening in August? jimmillion Off-Topic Lounge [WARNING: NO POLITICS] 0 06-02-2013 12:22 AM
What's Happening this Weekend? (Nov 1st-4th) TyperRspec789 Mid-Atlantic 27 11-03-2012 12:11 AM
well, its finally happening... carbonBLUE Scion FR-S / Toyota 86 GT86 General Forum 46 10-16-2012 08:39 AM
any UT happening? Celica00 Southwest 6 09-11-2012 11:03 AM
