Old 02-06-2014, 02:08 AM   #43
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
The army blessed me with fort drum my as my first duty station so I've been battling lake effect snow for two winters now. I'm still on the stock summers which for most is nuts but I'm managing it pretty well actually. Everyone says don't drive rwd cars up here yet I keep seeing all fwd cars and trucks winding up in ditches. What I'm doing is insane but I guess I'm proving the point that it can be done. As mentioned earlier turn you TCS completely off. If it kicks in your wheels won't spin fast enough and you will be done. Whenever I'm parked and setting off I start in 2nd with a light roll off. If I'm going up hill I often put it in 5th or 6th and rev to about 4-5k wheels will be spinning fast as he'll but you'll be crawling. You'll also get a good lesson in counter steering as you'll be sideways up the hill and pretty much any turn. There are times when the snow gets just too high though so I have a set of chains that I use to "unstuck" myself. All I do is whip out the jack, slip the chain on drop it and churn myself out. Even works on ice. I've found that I works best if it put on just one wheel with TCS on. The wheels will spin inside the chains with two. I only use the chain in the city never on the highway as max speed with them is 30mph. You can go a little faster but the vibrations will annoy/ scare the shit out of you and the band's will break. I got the chain set from Walmart for about $35.
http://www.scc-chain.com/tire-chain-.../radial-chain/
glorydays is offline   Reply With Quote
Old 02-06-2014, 11:47 AM   #44
b rawr z
b rawr z's Avatar
Drives: 2014 BRZ, 2008 Impreza
Damn. Ur a brave man. Thanks for the tip. Hopefully snow season will be over this february.
b rawr z is offline   Reply With Quote
Old 02-06-2014, 12:16 PM   #45
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I just read the thread title and ROFL! They are summer compound tires what did you expect?
Don't think I saw this on the stock tires.
krayzie is offline   Reply With Quote
Old 02-06-2014, 12:18 PM   #46
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
I have a tow cable in my trunk specifically for this time of year's shitty weather.
supramkivtt2jz is offline   Reply With Quote
Old 02-06-2014, 12:28 PM   #47
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Thumbs up
OP lives in Eastern PA and doesn't know that you shouldn't use 1st gear when trying to get unstuck?
I feel like there's a common sense issue at play here
FYI when you put an automatic transmission into "winter" mode (if it has one) it usually starts in 3rd gear...to give you an idea of what works best...
Old 02-06-2014, 12:38 PM   #48
b rawr z
b rawr z's Avatar
Just to clarify. Everywhere else was plowed and I was on my way to garage it. I have a second car which is awd to use for snow/rain. So I dont really need snow tires on the car. Im just asking what people do if its the only car they have and have no choice but to drive it in snow.
Old 02-06-2014, 12:49 PM   #49
b rawr z
b rawr z's Avatar
Ive only been living here in the east for 5 years. and during those 5 years ive had a rav4. so u could say ive been spoiled by awd. so u can take ur east coast rudeness somewhere else.
Old 02-06-2014, 01:07 PM   #50
WolfpackS2k
Not rude to point out something everyone should know.
Old 02-06-2014, 01:11 PM   #51
b rawr z
b rawr z's Avatar
I wouldnt know since my rav4 doesnt display gears nor does it have a button for snow. Maybe the newer ones. Im not sure.
Old 02-06-2014, 01:15 PM   #52
bobaab
Drives: 13 Subaru BRZ Limited
You proved a point, then went out of the way to make fun of him. I'd say that's pretty rude. Let's refrain from that to avoid devaluing the knowledge base here.
To sum up the thread here:
1) Get proper tires for the condition
2) IF you get stuck, try to use a higher gear like 2nd or 3rd gear
3) Have a small shovel and de-icer/salt/kitty litter in your trunk
4) Bonus: live in an area that doesn't snow :P
bobaab is offline   Reply With Quote
Old 02-06-2014, 01:18 PM   #53
b rawr z
b rawr z's Avatar
Thanks a lot. Also, she* but no biggie. Id love to move back to cali or somewhere else with no snow lol.
The Following User Says Thank You to b rawr z For This Useful Post:
bobaab (02-06-2014)
Old 02-06-2014, 03:27 PM   #54
krayzie
Drive From Home
krayzie's Avatar
Why are you even starting this thread to begin with then? I think the choice is to NOT DRIVE IT because you are endangering the lives of other drivers by running improper tires for the road condition and temperature that you are in.
Dude it's summer compound you need to take into account the drop in temperature (below freezing that's why there's snow on the ground)?
I'm running Ultra High Performance All Season Tires on mine (Michelin Pilot Sport A/S 3) and they specifically address below freezing adhersion with sunflower oil compound. I don't even drive it in the snow due to safety reasons. Good luck with your stock Primacys going up snowy / icy driveways. You can try dipping the clutch and turn off traction control and just spin your way up.
I hope you have proper winter tires on your AWD car. You can get away with all seasons on a FWD car but light weight AWD car again good luck.
Old 02-06-2014, 03:31 PM   #55
b rawr z
b rawr z's Avatar
I'm running Ultra High Performance All Season Tires on mine (Michelin Pilot Sport A/S 3) and they specifically address below freezing adhersion with sunflower oil compound. Good luck with your stock Primacys.
If you have an AWD car you should even know better about the need for snow tires in winter, first thing in the ditch on a snowy day without snow tires while everybody drives by and look at you with FWD cars that could get away with all seasons.
I believe my rav4 has all seasons and its fine with them. Ive been considering getting snow tires but then Idk for which car lol
Old 02-06-2014, 03:34 PM   #56
AtlasMick
Drives: FR-S 2013 Asphalt
Driving on snow/ice in the stock wheels is a blast... as long as you are careful. I find it fun to practice my ice/snow driving ability.
BUT, it did take me 25 minutes to get the FR-S into my driveway after winter storm Nika nailed central kentucky... It's only 15 or so feet.
Cheers, and enjoy every moment of it! You don't often get to drift so hardcore!
AtlasMick is offline   Reply With Quote
Got stuck in the snow DoopaTroopa Mid-Atlantic 40 03-06-2014 06:16 AM
Snow tires...wow... Brahsbrah Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 112 02-18-2014 06:31 PM
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires stockysnail Northwest 36 12-19-2013 01:12 PM
Snow Tires Enemies CANADA 289 11-25-2013 10:35 AM
Snow tires? smbrm CANADA 12 05-27-2012 01:20 AM
