Old 02-04-2014, 11:19 PM   #1
914_WHITE_FRS
914_WHITE_FRS's Avatar
Drives: White 2013 Scion FR-S
Red inside door handle grips how to install?
how the heck do you install these? anyone have a clue?
914_WHITE_FRS is offline   Reply With Quote
Old 02-04-2014, 11:28 PM   #2
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
You have to take the entire door panel off and get to it from the back side...
See aluminum bar with the two screws holding in the handle piece in the picture below (which I borrowed from this thread: http://www.ft86club.com/forums/showthread.php?t=32694)
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 02-05-2014, 12:11 AM   #3
Coreyviper
Coreyviper's Avatar
Drives: 2014 Scion FR-S
Man those are nice! I'm not trying to take off the whole door panel though. Scary!
Coreyviper is offline   Reply With Quote
Old 02-05-2014, 08:04 PM   #4
914_WHITE_FRS
ahhh shittt.... well it's not that bad right you just have to unscrew all the screws around the door and the door panel comes out right?
Old 02-05-2014, 08:16 PM   #5
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
All those little white circles on the picture you quoted are plastic clips you will have to carefully pull on to remove the panel. Count on a couple breaking if you haven't done this before.
Old 02-05-2014, 08:45 PM   #6
aSaki
Do it when its warmer, like all plastic, these white clips are harder to work with in the cold and can easily snap. But even if they do they are extremely cheap to replace so just be careful and not break the place it holds the white clip. You can break every single clip there is and it'll be less than $10 to replace all of them. Also remember that there will be ALWAYS screws or bolts thats holding the panel and not just the white clips, so don't start pulling the panel unless you know the screws and bolts are all off.
aSaki is offline   Reply With Quote
Old 02-05-2014, 09:10 PM   #7
Scion F ARE S
Drives: Toy car
Where would you purchase those white clips?
Scion F ARE S is offline   Reply With Quote
Old 02-05-2014, 09:31 PM   #8
Khazzy
Khazzy's Avatar
Drives: SWP Subaru BRZ
dealership and online OEM supplier.
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below.
Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty.
Old 02-05-2014, 09:32 PM   #9
aSaki
Dealer has them for like no more than a dollar each
Sent from my SGH-T889 using Tapatalk
Old 02-05-2014, 09:40 PM   #10
Scion F ARE S
Drives: Toy car
Do you have the part number or know what it's called?
The Following User Says Thank You to Scion F ARE S For This Useful Post:
APS86 (03-24-2014)
Old 02-05-2014, 09:43 PM   #11
aSaki
Nope, just go into the dealer and tell them I need the white clips that holds the door panels. They have been using the same style for almost every car for centuries so unless they are stupid, they should know what you are talking about lol
The Following User Says Thank You to aSaki For This Useful Post:
Scion F ARE S (02-05-2014)
Old 03-23-2014, 01:37 PM   #12
914_WHITE_FRS
its getting warmer and i'm going to do this next week when my JDM Speaker grill and ring comes in so i can also install my jdm red stiching speaker pads.
Old 03-23-2014, 11:31 PM   #13
mashal
DADA
mashal's Avatar
Drives: 2013
they call pop rivets, there is 2 sizes that i found they used in panels. I bought 50 each and bill came to like 14$ lol
mashal is offline   Reply With Quote
Old 03-24-2014, 12:21 AM   #14
Khazzy
Khazzy's Avatar
do yourself a favor too and get the pop rivet removal tool for those pesky ones that do not pop out. Will save the pop rivet from prying damage and money replacing them. Agreed on cold weather removal. Do not forget about the electronic door locks and for the limited guys, the wire for the door vanity lights. It is more than just pulling the door panel off. It is easy, just watch what you are doing.
red door handle inserts abutterman Cosmetic Modification (Interior/Exterior/Lighting) 4 08-04-2015 08:10 PM
Interior Door Handle Help effty_ac DIY (Do-It-Yourself) Guides 4 12-28-2013 09:04 PM
Door handle replacement cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 5 07-18-2013 03:07 PM
Door handle replacement cslntuee DIY (Do-It-Yourself) Guides 1 07-17-2013 09:52 PM
Door Handle cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 11 03-24-2013 02:49 AM
