Old 06-26-2013, 06:52 PM   #1
horrorbiz
horrorbiz's Avatar
Drives: ‘22 BRZ Limited
WRX swaybar
I remember reading somewhere that the WRX rear swaybar fits on the BRZ but can't seem to find it again. I am assuming it's the current generation WRX? I wasn't really planning on changing the swaybars on my BRZ, but I do have a stock swaybar from my 2011 WRX sitting in the garage. If this is a worthwhile upgrade, I was thinking I may as well throw it on.
Has anyone here done this? I'm not looking to make the car into a snap-oversteer mess, but if it's a subtle increase in rigidity I'd be into that.
horrorbiz is offline   Reply With Quote
Old 06-26-2013, 10:44 PM   #2
Racecomp Engineering
I wouldn't do it without a larger front bar. We did experiment with the 16mm rear wrx bar.
- andy
Old 06-26-2013, 11:58 PM   #3
horrorbiz
horrorbiz's Avatar
Okay thanks! I don't think the car really needs bigger swaybars anyway given it's low center of gravity. It already feels like it has less body roll than my WRX with big sway bars.
Old 06-27-2013, 12:11 AM   #4
OrbitalEllipses
Drives: Attitude
2008+ WRX is plug and play. @Scooby South currently has a 16mm WRX bar on his.
Scooby South (06-27-2013)
Old 06-27-2013, 12:35 AM   #5
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
I do....as @OrbitalEllipses mentioned... STi rear bars from 08 plus also work.. 18mm/19mm depending on the year.. the Coveat is I also run a Whiteline Front Adj 20mm... with my setup, it seems to like the stock Frt/rear Split of 2mm.. any More rear bar.. it would just be too loose IMO... unless you match it with the corresponding front bar..
Bill
Scooby South is offline   Reply With Quote
Old 02-05-2014, 07:38 PM   #6
Aznsky
Drives: Nissan 350Z (sold) 13' Whiteout FRS
bumping an old thread, what exact year WRX rear bar would fit on our cars?
2008-2014?
Aznsky is offline   Reply With Quote
Old 02-05-2014, 07:51 PM   #7
Scooby South
Conedancer
2008-2014?
yes either in a WRX flavor or STi flavor.
Bill
Old 02-05-2014, 08:03 PM   #8
Aznsky
Thanks Bill, after searching I found the same answer.
Old 03-12-2016, 03:30 AM   #9
Blucifer
Blucifer's Avatar
Drives: 2013 Ultramarine FR-S
Reviving this thread, but can anyone recommend some good front combinations with the STI rear?
Blucifer is offline   Reply With Quote
Old 03-14-2016, 10:00 AM   #10
makinen
makinen's Avatar
Drives: Toyota 86
I'm using Strano FSB with STI 18mm rear.
Plus RCE Tarmac + Koni Yellow.
makinen is offline   Reply With Quote
The Following 2 Users Say Thank You to makinen For This Useful Post:
Hyper4mance2k (03-14-2016), Racecomp Engineering (03-14-2016)
Old 03-14-2016, 04:48 PM   #11
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Almost the same here. I run the Strano front bar, WRX rear bar, Swift Spec R springs on Bilstein B6s with modified bump-stops. I fricking love it.
The car is perfectly neutral. It has the world's smallest amount of push that easily rotates when asked to do so. The car pushes, I lift off, the car rotates, I reapply throttle, then 88MPH and I'm back in the 50s.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following 2 Users Say Thank You to Hyper4mance2k For This Useful Post:
finch1750 (03-14-2016), Racecomp Engineering (03-14-2016)
DIY - Rear Swaybar and Endlinks - Perrin F1point4 DIY (Do-It-Yourself) Guides 11 07-26-2018 03:27 PM
RCE Yellow Spring and RCE Swaybar package $599 shipped!!! Racecomp Engineering Brakes, Suspension, Chassis 76 08-27-2013 05:21 PM
FS (Mid-Atlantic); OE '12 WRX Rear Swaybar hinge Brakes, Suspension, Chassis 2 06-23-2013 11:15 PM
Hotchkis swaybar set *new* dori. Brakes, Suspension, Chassis 0 03-13-2013 05:03 AM
Ground Control Swaybar Endlinks GC_Adam Brakes, Suspension, Chassis 6 01-02-2013 01:08 PM
