#617 |
Drives: 2013 FR-S AT Argento
I am sorry if this question has been completely vetted. I realize the first post and many thereafter indicate that OEM Camber "Crash" Bolts are allowed in C Street. I have them and wouldn't want to lose them. However, as I resesrch, I still find ambiguous comments about requirements to maintain alignment within stock tolerances for Street Stock which would preclude the negative camber gains from crash bolts. Are the rules specific enough to remove doubt about whether or not crash bolts and 1.x negative camber gains are definitely allowed?
#618 |
You can run as much negative camber as you want allowed by the modifications stated in the rules. There is no requirement to stay within factory spec, although with our cars you will be, the crash bolts don't buy you much.
| The Following User Says Thank You to xwd For This Useful Post: | Ocala FR-S (02-05-2014) |
#619 | |
Detroit Region, MI
Drives: 13 BRZ, 13 Volt, 02 WRX
I think your question is related to the last statement, but that is specific to OE allowances for slotting the strut hole ONLY when a max slot size is not specified. In that instance, you are not allowed to adjust outside OE tolerance range in that scenario. In the previous sentences shims and specialty bolts as specified by the manufacturer are legal, even outside of the normal tolerance range. It's explicitly defined as legal.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop 2007-08: #54 STX 05 WRX Sedan 2009-12: #92 BSP/ASP 07 Solstice GXP 2013-14 : #192 CS 13 Subaru BRZ |
| The Following User Says Thank You to Sccabrz192 For This Useful Post: | Ocala FR-S (02-05-2014) |
#620 | |
#621 |
Drives: 2013 FR-S, hot lava
not that weekend. i have some from dec but i can't find a place to host them.
i went to nationals last year in a friend's FRS. got middle of the pack in RTR. i'd only driven an FRS with good tires twice when i went to nat's. |
#622 |
Drives: Ultramarine
I'm looking to get a sway bar, thinking whiteline simply because it seems to be the middle ground bar. I am looking at the 20 or 22 mm both adjustable. Everything I find says that they are both 118 on soft and 174% stiffer on hard. Am I missing something, how can two bars with different diameters have the same stiffness? If this has already been covered I apologize.
#623 | |
Detroit Region, MI
http://www.ft86club.com/forums/showthread.php?t=49659 Whiteline Solid Front : 20mm, 22mm 20mm Fixed or 2 position in option, Soft Setting - 118.5% Hard Setting - 174% 22mm 2 position Soft Setting - 212% Hard Setting - 288% But to answer your more general question... there are a few things that influence the bar rate... 1) Solid versus hollow (OD and ID both play a large role) 2) Material 3) link attachment distance from pivot point (this is how the "adjustable" bars work.) So depending on the combination of the above, you can have different OD bars with same or similar rates... although that is not the case for the Whiteline options.
#624 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
On a BRZ, I'd definitely go Strano for your bar. The whiteline may work alright on FR-S, with it's softer front springs needing more help (though I'd still go for Strano likely)
#625 | |
Detroit Region, MI
#626 |
Pawn in game of life
Drives: 19 STX BRZzz
2nd event done. First event with a Strano front bar installed (thanks DWX). The car drove much better with the bar on. Finished 13th of 149 in PAX - https://axwaresystems.com/axorm/file...eb2014_pax.htm. Still a bit disappointed with the pace, as I'm getting stomped in X class (in which I have won the championship for the last 2 years).
The course was big power. I was rev limiting at the end of each fast section. Please feel free to critique anything you see. The biggest issue mentioned so far is that I could have went a little wider in the last sweeper and entered the final slalom faster. I was rev limiting for a good bit through the finish. [ame="http://www.youtube.com/watch?v=8Rx5qI6mEHE"]CS BRZ at SASCA 2/9/14 - YouTube[/ame]
Autocross nut
#627 |
i'm sorry, what?
Drives: Canada
it would be nice to see hand movements, but otherwise my only advice is to work on your course memorization and planning
pretty much the entire run you're stuttering in your inputs, unsure of what to do next. which leads to slightly missed apexes, which leads to less full throttle and less comitment to corners.
#628 |
Senior Citizen
Drives: Scion FR-S
#629 |
True, I need to find a better location to mount the camera. The car does have a significant tendency to grip/slip/grip through corners which looks really janky on the vids. While I am making minor course corrections, I'm not sawing on the wheel like the vid suggests
Autocross nut
#630 |
Looks terrific! You'll get a lot more comfortable now that the bar is on -- enough to push it like your STi eventually.
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
