Sam Strano
Old 02-05-2014, 04:35 PM   #617
Ocala FR-S
Ocala FR-S's Avatar
Drives: 2013 FR-S AT Argento
I am sorry if this question has been completely vetted. I realize the first post and many thereafter indicate that OEM Camber "Crash" Bolts are allowed in C Street. I have them and wouldn't want to lose them. However, as I resesrch, I still find ambiguous comments about requirements to maintain alignment within stock tolerances for Street Stock which would preclude the negative camber gains from crash bolts. Are the rules specific enough to remove doubt about whether or not crash bolts and 1.x negative camber gains are definitely allowed?
Ocala FR-S is offline   Reply With Quote
Old 02-05-2014, 04:38 PM   #618
xwd
You can run as much negative camber as you want allowed by the modifications stated in the rules. There is no requirement to stay within factory spec, although with our cars you will be, the crash bolts don't buy you much.
The Following User Says Thank You to xwd For This Useful Post:
Ocala FR-S (02-05-2014)
Old 02-05-2014, 06:49 PM   #619
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
13.8 Section E
I think your question is related to the last statement, but that is specific to OE allowances for slotting the strut hole ONLY when a max slot size is not specified. In that instance, you are not allowed to adjust outside OE tolerance range in that scenario.
In the previous sentences shims and specialty bolts as specified by the manufacturer are legal, even outside of the normal tolerance range. It's explicitly defined as legal.
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
The Following User Says Thank You to Sccabrz192 For This Useful Post:
Old 02-05-2014, 06:59 PM   #620
Ocala FR-S
Ocala FR-S's Avatar
Originally Posted by Sccabrz192 View Post
13.8 Section E
That makes sense. Thanks. (and also to dwx).
Old 02-08-2014, 02:53 PM   #621
jam0o0
Drives: 2013 FR-S, hot lava
Originally Posted by u/Josh View Post
Any videos? That's a damn good performance on stock tires.
not that weekend. i have some from dec but i can't find a place to host them.
i went to nationals last year in a friend's FRS. got middle of the pack in RTR. i'd only driven an FRS with good tires twice when i went to nat's.
jam0o0 is offline   Reply With Quote
Old 02-09-2014, 08:24 AM   #622
Nm86
Drives: Ultramarine
I'm looking to get a sway bar, thinking whiteline simply because it seems to be the middle ground bar. I am looking at the 20 or 22 mm both adjustable. Everything I find says that they are both 118 on soft and 174% stiffer on hard. Am I missing something, how can two bars with different diameters have the same stiffness? If this has already been covered I apologize.
Nm86 is offline   Reply With Quote
Old 02-09-2014, 08:31 AM   #623
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
I can't comment as to the 100% accuracy of the list, but the most definitive one available is here... this is based on individual conversations with the manufacturers and/or published information.:
http://www.ft86club.com/forums/showthread.php?t=49659
Whiteline
Solid
Front : 20mm, 22mm
20mm Fixed or 2 position in option,
Soft Setting - 118.5%
Hard Setting - 174%
22mm 2 position
Soft Setting - 212%
Hard Setting - 288%
But to answer your more general question... there are a few things that influence the bar rate...
1) Solid versus hollow (OD and ID both play a large role)
2) Material
3) link attachment distance from pivot point (this is how the "adjustable" bars work.)
So depending on the combination of the above, you can have different OD bars with same or similar rates... although that is not the case for the Whiteline options.
The Following 2 Users Say Thank You to Sccabrz192 For This Useful Post:
Kido1986 (02-09-2014), Nm86 (02-09-2014)
Old 02-09-2014, 07:25 PM   #624
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
On a BRZ, I'd definitely go Strano for your bar. The whiteline may work alright on FR-S, with it's softer front springs needing more help (though I'd still go for Strano likely)
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-10-2014, 11:54 AM   #625
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
I agree, in fact, I ordered my Strano bar yesterday
Old 02-10-2014, 12:05 PM   #626
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
2nd event done. First event with a Strano front bar installed (thanks DWX). The car drove much better with the bar on. Finished 13th of 149 in PAX - https://axwaresystems.com/axorm/file...eb2014_pax.htm. Still a bit disappointed with the pace, as I'm getting stomped in X class (in which I have won the championship for the last 2 years).
The course was big power. I was rev limiting at the end of each fast section. Please feel free to critique anything you see. The biggest issue mentioned so far is that I could have went a little wider in the last sweeper and entered the final slalom faster. I was rev limiting for a good bit through the finish.
[ame="http://www.youtube.com/watch?v=8Rx5qI6mEHE"]CS BRZ at SASCA 2/9/14 - YouTube[/ame]
Autocross nut
AustinTX is offline   Reply With Quote
Old 02-10-2014, 12:17 PM   #627
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
it would be nice to see hand movements, but otherwise my only advice is to work on your course memorization and planning
pretty much the entire run you're stuttering in your inputs, unsure of what to do next.
which leads to slightly missed apexes, which leads to less full throttle and less comitment to corners.
Old 02-10-2014, 12:26 PM   #628
simpleisbest
Senior Citizen
Drives: Scion FR-S
I am preferring the Tanabe bar now. Almost same as Strano, but is a hair stiffer, has a more stock shape (no lower arm contact issues), and comes with welded locator collars. (Yes, I have tried both)
simpleisbest is offline   Reply With Quote
Old 02-10-2014, 12:27 PM   #629
AustinTX
AustinTX's Avatar
True, I need to find a better location to mount the camera. The car does have a significant tendency to grip/slip/grip through corners which looks really janky on the vids. While I am making minor course corrections, I'm not sawing on the wheel like the vid suggests
Autocross nut
Old 02-10-2014, 12:35 PM   #630
des
des's Avatar
Looks terrific! You'll get a lot more comfortable now that the bar is on -- enough to push it like your STi eventually.
des is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
