Old 03-06-2012, 04:30 PM   #15
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
Originally Posted by Alias View Post
It's obviously not very realistic to think this is accurate but that's what it is saying (and what the original post was asking). It sure would be nice if it was true but it's so far off all the other reported numbers I just don't see it happening.
I think we all agree something is off about those numbers, and to further add to the confusion...
Originally Posted by Fox View Post
Confirmed
Specs for German 86:
i just post the new facts because we all know the rest
weight in kg MT: 1200
weight in kg AT: 1223
Acceleration 0-100km/h in seconds: 7,6 (MT) / 8,2 (AT)
top speed in km/h: 230 (MT) / 215 (AT)
fuel consumption overall in liters: 6,9
there are also some new pics on the toyota homepage!!
Apparently it gained a few kilos and goes slower in Germany... it must be the beer and sausages.
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 03-06-2012, 04:53 PM   #16
Dragonitti
Confusion Much?
Old 03-06-2012, 04:58 PM   #17
Fox
Fox's Avatar
Drives: GT86, MR2
Confusion Much?
yes!
Fox is offline   Reply With Quote
Old 03-06-2012, 05:06 PM   #18
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
0 to 60 in the mid 6 secs range....2601 curb weight....I will go with those...hehe!
that's 0 to 62 in 6.9 secs
Fast enough...and we all know the manufacturer 0 to 60 times are always slower than actual times tested by the car mags.
tripjammer is offline   Reply With Quote
Old 03-06-2012, 06:51 PM   #19
serialk11r
Drives: '06 AM V8V Coupe
I don't think it'll hit 100kph in 2nd gear, that may be why the times look so different, since that extra shift into 3rd takes an extra fraction of a second.
And I think 1210kg curb in the brochure that they're handing out seems to be the US curb weight, which appears to be full tank of fuel + all fluids filled up. The Scion is likely a tiny bit lighter due to the missing trim bits and nav, but that's it. So 2640lb curb?
Old 03-06-2012, 07:46 PM   #20
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by SunnyD View Post
0-100km = 0-62 mph, so if its 6.9 seconds to 62 mph, it should be a couple tenths less to get to 60. In any case, isn't this what we were expecting for this car?
Listed as 8.2s 0-62 with the AT. I doubt the issue is that 3rd shift to get to 100kph. Those numbers just don't make sense and I figure it is due to testing method.
tranzformer is offline   Reply With Quote
Old 03-06-2012, 09:06 PM   #21
fistpoint
Drives: Supercharged Golf Cart
A lot of people WANTED a 6 second 0-60.
And they can still get it. The RSX-S over the years through different magazines and drivers have had posted 0-60 times between 5.9 and 7.0 depending on which magazine did the testing.
Testing methods also differ from source to source. Some do lift-throttle shifts while others don't. Some testing is done in better whether, and some testing vehicles were ragged out, some were too new and still others well broken in.
So, 6 flat is still very possible based simply on its power output and weight with regard to numerous vehicles existing today with similar specs, namely the RSX and Civic Si's, the latter of which weighs more yet still achieves mid 6 second times(not talking about the 2012).
fistpoint is offline   Reply With Quote
Old 03-06-2012, 09:59 PM   #22
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I thought we confirmed already from on of the videos that the car will hit 60mph at the top of 2nd?
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 03-06-2012, 11:05 PM   #23
Lowellrenzo
Drives: Civic Si coupe
any body notice the max torque different from scion site? lol it's even better
Originally Posted by carbonBLUE View Post
ok ive searched google and this site, but does anyone have a clear definition of the differences between us gross weight and European gross weight?
the car is 2600lbs gross in Europe, in america that means fully loaded with a couple people and some luggage, soooo...
if that similar to Europe's definition of gross weight?
i mean if thats right the car could come in around 2
4xxlbs dry right?
picture is from the Geneva thread posted recently
ridicule me if ya want as long as its a clear answer
Lowellrenzo is offline   Reply With Quote
Old 03-06-2012, 11:11 PM   #24
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
^it's Nm and Scion is in lb/ft. 205Nm = 151lb/ft
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 03-06-2012, 11:15 PM   #25
tachi1247
tachi1247's Avatar
Drives: 04 BMW 330i & 03 Mazdaspeed Protege
yeah...picked up another 11 ft lb. All these discrepancies probably have to do with the test standards used to measure them. Like when sae changed how they measure horsepower several years ago. The 200hp civic so became 195 HP under the new test procedure.
edit: no it didn't. Found an incorrect torque table on the web
tachi1247 is offline   Reply With Quote
Old 03-07-2012, 04:22 PM   #26
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
it will hit 61.5mph at the top of second = 99kmh
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 03-08-2012, 01:21 PM   #27
Gadflyii
Drives: Cleaned out the garage!
Send a message via AIM to Gadflyii
I would expect 0-60 time to be 6.7s if the 6.9s in that image is correct.
I am pretty sure Subaru has confirmed the curb weight at 2755 lbs curb weight right? The FR-S is going to be within ~50lbs of that depending on options. I would guess the difference in the weight on that info card, and Subaru's curb weight rating is based on differences in testing standards maybe? Not sure, but I am fully expecting US curb weight to be 2750-2850lbs for the manual.
Originally Posted by Scion FR-S View Post
Hey, this is ft86club! Bitchiness, snide putdowns, and one-upmanship come with the territory!
Gadflyii is offline   Reply With Quote
Old 03-08-2012, 02:09 PM   #28
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Vorshlag will have a USDM BRZ on a set of corner weight scales next week. We'll finally have some real numbers and can stop trying to make sense of marketing BS.
Errr... Hate to ask... Crash Testing?? slusoccer00 Scion FR-S / Toyota 86 GT86 General Forum 55 07-12-2015 03:03 PM
How can i shave weight? fernan2 BRZ First-Gen (2012+) — General Topics 15 11-01-2011 10:31 AM
So... the womens motocross event at the x-games? yeah we dont talk about that Sea1monkey2 Off-Topic Lounge [WARNING: NO POLITICS] 8 08-02-2011 09:03 PM
Weight of FT-86? Levi Engine, Exhaust, Transmission 38 06-14-2011 10:43 PM
