Old 02-05-2014, 11:21 AM   #29
HunterGreene
Hail Magnet
HunterGreene's Avatar
Originally Posted by daiheadjai View Post
Hmmm... this one is a bit unexpected - I experimented with taking my sandbags out for a couple days - after the first major snowfall/icy conditions, I promptly threw them back in.
I actually found the tail to be more lively and squirmy without them.
Probably good for traction to get uphill or away from a stoplight though (I have 60 kgs in the back now)
I guess the best thing to do is experiment (sandbags are about $5 apiece, so it isn't going to bankrupt you to try)
At the end of the day, it boils down to what you are used to. If you are used to having the sandbags in there, don't take them out. If you aren't, don't add them right before a major snowstorm.
It has priests in it?
The Following 2 Users Say Thank You to HunterGreene For This Useful Post:
BRZfan (02-05-2014), daiheadjai (02-05-2014)
Old 02-05-2014, 11:46 AM   #30
BRZfan
BRZfan's Avatar
Drives: 2013BRZ Premium St Silver Metallic
Don't forget about using a bag of kitty litter under the wheels.. dead cats can also be used.
Originally Posted by reeves View Post
First, if you have room, you should back the car up a little to get momentum getting past the spot you're having a hard time getting through. If you can't do that, you can always try putting a wodden board, gravel, or small rocks under & in front of the rear tires so they have a little more traction. Hope that helps!
BRZfan is offline   Reply With Quote
Old 02-05-2014, 11:50 AM   #31
BRZfan
BRZfan's Avatar
Handling would not be much affected (with bags) if all the driving was in ice and snow.
Originally Posted by HunterGreene View Post
And I feel compelled to post in contradiction to this statement again, as sand bags can make the car's handling less predictable in a skid.
Old 02-05-2014, 12:01 PM   #32
BRZfan
BRZfan's Avatar
Haven't heard about any discussion if tires were all season or summer performance.
I am in the Midwest and summer performance tires came with my BRZ. Probably normal issue.
If summer performance tires were used with the OP's vehicle then the car probably should not have been driven. I agree with an earlier poster: Keep it at the dealership until appropriate to drive it. A good dealer would have suggested it. Note: Summer performance tires should not be use at temps under 40 degrees F.
Old 02-05-2014, 12:25 PM   #33
b rawr z
b rawr z's Avatar
Drives: 2014 BRZ, 2008 Impreza
Lol. Ill keep that mind.
b rawr z is offline   Reply With Quote
Old 02-05-2014, 12:40 PM   #34
bakerr6
Drives: 2013 raven black fr-s
I got stuck yesterday after making a 2 hour trip from work. I didn't get stuck until I actually tried to pull onto our main road. It's straight up hill and it wasn't plowed. We ended up using a tractor to pull it into the driveway lol
bakerr6 is offline   Reply With Quote
Old 02-05-2014, 01:12 PM   #35
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
I got stuck in the middle of one of these east coast snow storms in my car while I was commuting home. The snow was suppose to happen late that night, so I didn't take my truck out. Unfortunately, the snow started during the afternoon commute. I live in a very rural area, so once I got on the road leading to my house, I knew I was screwed. I got stuck on a hill, so I backed out of the area I was stuck in, had to get into first, tried to get the backend to lightly fish tail back and forth, and did that ever so slightly every time I got a little bit of traction. I also tried going in a zig-zag fashion, so I wasn't directly facing upwards and sliding back. It was scary, because I was getting closer to a pole, but after 10 minutes I was able to get up the hill and continue my very slow drive home. I honestly have no idea how I made it up that hill or how I made it home. The car is now in storage
PoorMansRacing is offline   Reply With Quote
The Following User Says Thank You to PoorMansRacing For This Useful Post:
Trigonx (02-07-2014)
Old 02-05-2014, 01:30 PM   #36
BRZBlack
BRZBlack's Avatar
Drives: 2013 Subaru BRZ
This car weighs nothing.... have a friend give you a push =D
Outside of that, I was shown by my older brother looong ago that a bag of kitty litter works wonders. Absorbs water, gives you traction and a little bit of weight over the rear axle. Small shovel and a blanket with some of those chemical plastic hand warmer things.
BRZBlack is offline   Reply With Quote
Old 02-05-2014, 02:37 PM   #37
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Originally Posted by b rawr z View Post
For now I don't think I need sands. I dont plan to take it out of the garage anytime soon cause this weather is gonna get worse this weekend.
That's a bit of a shame - once you get used to it, tail-happy shenanigans in an empty parking lot can be a lot of fun.
Just make sure there are no steep grades or hills.
daiheadjai is offline   Reply With Quote
Old 02-05-2014, 02:38 PM   #38
b rawr z
b rawr z's Avatar
At least u had a tractor to help
The Following User Says Thank You to b rawr z For This Useful Post:
bakerr6 (02-05-2014)
Old 02-05-2014, 02:40 PM   #39
b rawr z
b rawr z's Avatar
Shoulda taken the truck that day..at least u have it in storage now
PoorMansRacing (02-05-2014)
Old 02-05-2014, 02:41 PM   #40
b rawr z
b rawr z's Avatar
So kitty litter is the way to go instead of sands. Gotcha thanks
Old 02-05-2014, 11:07 PM   #41
Monkey_Boy
Bleeds WR Blue
Monkey_Boy's Avatar
Drives: '14 BRZ (WRB), '06 Baja (ABP)
One thing I have not heard suggested...and this is in the manual.
Turn off the traction control.
You do not want to DRIVE it with the TC off, but it can help you get un-stuck if the nanny isn't shutting down the tire-spin as soon as it starts to break free. Once you are out of the stuck place, turn it back on and immediately call to get real tires.
Monkey_Boy is offline   Reply With Quote
Old 02-05-2014, 11:59 PM   #42
b rawr z
b rawr z's Avatar
I tried that a couple of times. My timing might have been bad and didnt try enough. Thanks for the tip.
Got stuck in the snow DoopaTroopa Mid-Atlantic 40 03-06-2014 06:16 AM
Snow tires...wow... Brahsbrah Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 112 02-18-2014 06:31 PM
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires stockysnail Northwest 36 12-19-2013 01:12 PM
Snow Tires Enemies CANADA 289 11-25-2013 10:35 AM
Snow tires? smbrm CANADA 12 05-27-2012 01:20 AM
