Old 02-04-2014, 05:04 PM   #1
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
turbo with hood
mods move if needed
I know there is already a thread on this but it seemed to not go anywhere.
Who has ran a front mount turbo with the factory hood then changed to a vented? An oil cooler and an upgraded radiator is MORE $ than a vented hood and i dont care how good your cooler is its hard to get air to move into a sealed box.
On a budget i honestly think vented with stock cooling system will be more beneficial.
DISCUSS!
Old 02-04-2014, 05:06 PM   #2
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
majorly depends if you have a water cooled turbo
Ironsquid is offline   Reply With Quote
Old 02-05-2014, 12:36 PM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by Reaper View Post
mods move if needed
DISCUSS!
IMO the bottom mount turbo is better for heat. Although I would still recommend a upgraded radiator and an oil cooler anyway (or a vented hood). with a front mount setup, I have heard of people that have a upgraded rad and oil cooler still not being able to keep engine heat down, someone needs to do a compairison to see which effectively cools more, stock cooling and vented hood vs stock hood and upgraded cooling.
What has been said, water cooled turbos are the best option.
not sure where youve been looking at vented hoods but I'd go with seibon and it's not exactly cheaper than a koyo rad and a oil cooler kit
Old 02-05-2014, 12:51 PM   #4
qtwre
Drives: White FR-S
One thing people may not have noticed is @CARNZ pieced together the coolant-cooled oil cooler from the new Forester XT. It's substantially cheaper than the air-cooled kits.
http://www.ft86club.com/forums/showthread.php?t=50427
I'm not sure how it compares to the aftermarket kits though.
qtwre is offline   Reply With Quote
Old 02-05-2014, 02:12 PM   #5
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by qtwre View Post
coolant-cooled
Lol coolant-cooled...
The Following User Says Thank You to cdrazic93 For This Useful Post:
PERRIN_Mladen (02-05-2014)
Old 02-05-2014, 03:46 PM   #6
qtwre
Drives: White FR-S
Sorry, coolanted I believe was the term I was looking for.
The Following User Says Thank You to qtwre For This Useful Post:
cdrazic93 (02-05-2014)
Old 02-05-2014, 04:09 PM   #7
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
the draw back of that system, if it ever gets damaged, you will have oil and coolant mixing = bad :/
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 02-05-2014, 11:20 PM   #8
qtwre
Drives: White FR-S
I suppose, but it would have to be the sandwich plate that gets damaged. It's an OEM solution so I trust that it's pretty good.
Old 02-06-2014, 01:00 AM   #9
kbye
kbye's Avatar
Drives: 2014 FR-S
The XT cooler will be just as reliable if not more so than aftermarket solutions. it's just a sandwich plate and a bunch of hard lines. subaru have been using them for years.
kbye is offline   Reply With Quote
Old 02-06-2014, 02:46 PM   #10
Reaper
Reaper's Avatar
Drives: violent
his system(forester oem) runs coolant through a sandwich plate around the oil filter unlike other systems that run the oil through a seperate tank in the radiator.
The forester system is NOT as effective on a water cooled turbo since it is essentially doing the same thing. Running coolant through the turbo while oil is running through it. But if i was running an oil only turbo i would use it.
Carbon hood and hood dampers?? ft86me Cosmetic Modification (Interior/Exterior/Lighting) 15 10-19-2013 12:57 PM
Hood pins with vis hood or is it okay Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-31-2013 09:02 PM
Looking for vis aem hood or seibon fa hood ready to ship Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-30-2013 12:25 AM
Looking for Hood Dampers meant for CF hood. Vicious LED Scion FR-S / Toyota 86 GT86 General Forum 3 12-31-2012 03:47 AM
