Old 01-23-2014, 10:20 PM   #211
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@mike the snake why did you ditch the coating
Old 01-23-2014, 10:26 PM   #212
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
Originally Posted by Pitman View Post
Like this?
Yes exactly like that. Is that a custom made job?
shaunsweeney is offline   Reply With Quote
Old 01-23-2014, 11:04 PM   #213
toekneehair
toekneehair's Avatar
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
Like this?
Where can I get me one of these?
toekneehair is offline   Reply With Quote
Old 01-24-2014, 12:16 AM   #214
mike the snake
TIME! Car's been at the shop for 2 months. Problems and delays, I don't want to wait an extra few days for the coating.
I'ma gonna double wrap that DP though for sure.
Old 01-24-2014, 01:47 AM   #215
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
@shaunsweeney @toekneehair I made the duct myself - vacuum bagged carbon fiber
Pitman is offline   Reply With Quote
Old 01-24-2014, 02:29 AM   #216
shaunsweeney
Very nice work! I am going to work with @mrk1 to make something similar using metal though.
Old 01-24-2014, 09:29 AM   #217
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by mike the snake View Post
What radiator are you running? The Robispec I have moves the fans back and left only 1mm clearance between the fans and downpipe/upper header. The fans both died within minutes on the dyno.
I'm getting the FB radiator, and I was told that it is designed such that the thicker portion is to the front, so no clearance is lost.
I'm also getting the Spal fans and shroud, and revised downpipe. My old DP was coated and wrapped, but the new one will only be wrapped.
This all should gain me the clearance I need to have everything work as designed.
I had the Full Blown radiator. It did not change the clearance from my fans to the downpipe.
Old 01-24-2014, 09:38 AM   #218
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Like this?
Dat is a sexy bitch.
Old 01-24-2014, 12:22 PM   #219
mike the snake
That's great to hear! It has totally sucked trying to get the Robispec to work. Wasted time and money trying to make incompatible parts work.
The Robispec is REALLY nice, and cools both the coolant and oil, but has clearance issues with, I suspect, all top-mount turbo kits.
Old 01-24-2014, 12:40 PM   #220
carlossanchez89
2Supras1FR-S
Drives: 13 Scion FR-S, 87 Supra
@mike the snake...getting the proper fans for this setup is a must. I now have the SPAL 12" fans and two heat shields to the fans to combat the heat from the downpipe. I'll post some pictures soon.
carlossanchez89 is offline   Reply With Quote
Old 01-24-2014, 01:36 PM   #221
mike the snake
Thanks! Yeah, with the Robispec and 1mm clearance, the fans up and died on the dyno before they'd even done any full throttle runs. I knew that was a ticking time bomb, even if we did get things to work and make it through tuning.
I'm bummed it's now taking more time, but I feel better with now running these new parts that offer the proper clearance.
Old 02-04-2014, 08:35 PM   #222
mike the snake
Here's a pic of the opened up front bumper. I still have to paint the wire mesh flat black.
Drift Armor crash bar will be in soon, which along with the holes in the bumper, should allow a LOT more air into the front.
Old 02-04-2014, 08:40 PM   #223
SmsAlSuwaidi
Boosted
@mike the snake thats race car status
Sent from my IBrick
Old 02-04-2014, 09:00 PM   #224
mike the snake
Sent from my IBrick
Thanks Mang! That's the goal, I want to track the car without worry eventually.
We moved the radiator forward and gained the necessary clearance between the fans and exhaust.
I plan to do some "custom" ducting to help guide the airflow. If anything though, the openings will help keep the AC evaporator cool, which will help the AC work better too.
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
