Old 02-04-2014, 01:02 PM   #617
Thorpedo
The SquadWhisperer
Originally Posted by Kido1986 View Post
Understand, no douchery taken. However, here is the rule copy/pasted from the rulebook
It may be the front pipe and not the overpipe I'm thinking of. I run Stock/Street so I haven't replaced mine, I just know that wherever the secondary is, you CAN use it inplace of the primary in this car due to the closeness of the inlet of secondary in relation to the outlet of the primary (when discussing OEM)
Oh god I don't know how I came to the conclusion that it was referring to the second one. You're absolutely right about which cat it is talking about. It seems to me the best solution for STX would be go with a catless over/front pipe (Stock front pipe contains the cat FWIW) and get a catted header. That way you avoid the CEL issues and remain legal.
Now I haven't personally measured the distance between the cats, but FWIW I would say it is more than 6".
Thorpedo is offline   Reply With Quote
Old 02-04-2014, 01:03 PM   #618
piknockout
Drives: 2014 BRZ
Edit: Doh, didn't realize it had been answered while doing my research.
piknockout is offline   Reply With Quote
Old 02-04-2014, 01:05 PM   #619
TallTerror13
TallTerror13's Avatar
Drives: 2014 DGM BRZ & 2015 WRB WRX
Why do you want to keep the cat so close to the engine anyways? Correct me if I'm wrong, but I come from a wrx state of mind and that is to keep the cat as far away as possible so that the airflow is not so turbulent making it pass the the cat with ease.
Sent from my DROID RAZR using Tapatalk
TallTerror13 is offline   Reply With Quote
Old 02-04-2014, 01:44 PM   #620
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Well I guess I was wrong. Looking back, the rulebook I had bookmarked was from a while ago :/
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 02-04-2014, 01:48 PM   #621
Wepeel
Drives: '13 BRZ Ltd
Well for "full prep" cars it is probably preferable to go with a catless header and a catted front pipe - they will be running a tune anyway which will take care of the CEL, and removing the header cat is probably better for power/temps and it's getting rid of weight in a better place.
Wepeel is offline   Reply With Quote
The Following User Says Thank You to Wepeel For This Useful Post:
SubiePig (02-04-2014)
Old 02-04-2014, 02:00 PM   #622
Thorpedo
The SquadWhisperer
LOL there ya go.
Old 02-04-2014, 04:13 PM   #623
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
I like the idea of catalytic converter placement to avoid CEL issues, and it is away from the header collector tube at least a little bit. Along the lines of header discussion, conventional thinking has been to use equal length headers for low end torque. Does that apply to these engines too? Looking at the dyno numbers from UEL and EL headers, they look pretty comparable. I will be racing autocross and would like to help the low end torque as much as possible. Call me a heretic, but I would prefer NOT to have the boxer rumble, thus my favoring of EL headers, although FT86 SpeedFactories UEL with cat doesn't sound too bad. Any thoughts?
MTCRX is offline   Reply With Quote
Old 02-04-2014, 04:52 PM   #624
Wepeel
Drives: '13 BRZ Ltd
I've seen it both ways for these cars (EL vs UEL), just based on threads I see here. Of course the header results I see are mainly from vendor-generated threads so
I think either way it's close between the two and probably more dependent on tune. Seems though a header+tune on pump will be worth about 20 whp in general.
Old 02-04-2014, 05:14 PM   #625
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Drift Office did pulls and tunes with various headers and they were all pretty close. I am on my phone or I would find links but if you seatch for threads they created I would consider it a good neutral comparison. Fwiw I remember uels made more power and tq than everything but HKS EL, but not sure if low end was better on one versus the other
MTCRX (02-05-2014)
Old 02-04-2014, 10:19 PM   #626
Wepeel
Drives: '13 BRZ Ltd
For the few actual cars I've known of personally, the HKS seemed to make the most power. It's also $$$. Looking forward to the real world results for the upcoming releases - Nameless, OFH, ft86club... etc
MTCRX (02-05-2014)
Old 02-06-2014, 09:59 AM   #627
piknockout
Drives: 2014 BRZ
Running STX in Dixie next month. This is gonna be fun.
The Following User Says Thank You to piknockout For This Useful Post:
SubiePig (02-06-2014)
Old 02-06-2014, 10:54 AM   #628
Wepeel
Drives: '13 BRZ Ltd
Good luck. So how far have you gotten with setup?
Old 02-06-2014, 11:13 AM   #629
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
I will be there too!
Tires come in today. Mounting them and scrubbing them in next weekend and trying out the new setup and see if I need to adjust anything. Still have about 100 lbs. I plan to remove from the car, corner balance, realign, test event the weekend before Dixie to test changes and go! Have to order my muffler and build my exhuast too.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 02-06-2014, 11:47 AM   #630
Thorpedo
The SquadWhisperer
My I ask your secret in weight removal, @SubiePig?
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
