Old 02-04-2014, 02:53 PM   #1
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Oil temp gauge variation.
I have a PLX DM-200 installed in my car, the original plan was to get oil temp from the obd and expand it with a boost sensor if I go FI.
But that did not work... Could not get it to show oil temps...
Bought a oil temp sensor module for it and hooked it up today.
I am now able to see oil temps, but its very low compared to the temp ecutek shows me.
I installed the sensor in the oil gallery with a M18x1,5 to 1/8" npt adapter.
Any thoughts why the readings are low?
One thing i noticed is that the sensor was a very tight fit into the adapter plug i am using.
Could it be that the fit is so tight that I am more or less reading engine block temp?
EDIT: The tip of the temp sensor does not poke out from the adapter.
I will try to enlarge the hole tomorrow to see if it readings get more accurate.
I am very happy with the gauge itself, blends in really nice.
Here are some pictures from when I installed the gauge.
Andreas83 is offline   Reply With Quote
Oil Temp Gauge installation BRZ NA BRZ First-Gen (2012+) — General Topics 35 08-17-2015 01:59 PM
Coolant Temp Gauge? Pacific Auto Issues | Warranty | Recalls / TSB 4 01-20-2014 04:00 PM
A/C Oil/Water temp gauge Exhaust Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 01:19 PM
exterior temp. gauge off? Rayme CANADA 8 01-23-2013 09:06 PM
Simple Oil Temp. Gauge Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 08:25 PM
