Old 02-02-2014, 09:50 PM   #715
mike the snake
My car with the Robispec radiator was running at 220 under no load on the dyno, and the FB slim fans died within a few minutes on the dyno.
I swapped the Robispec out for a Full Blown radiator, spal fans, and shroud, along with a revised downpipe that is supposed to give extra clearance.
It was still all too close when finished (I had wrapped the downpipe and header) and at the shop, I concluded that we needed to move the radiator forward.
About 1.5" was gained by drilling holes forward of the lower mounting holes and moving the radiator forward.
This was a relatively easy mod, and IMO should be something everyone should do. It By Far gains you the most clearance. It's easy to accomplish since the front of the car is already off.
FB also sent some new upper mounting tabs that also moved the upper part of the radiator forward as well. The stock upper radiator hoses do not allow much forward movement however, whereas the lower hose has no issues stretching the extra 1.5''.
With this done, I should have 1.5'' to 2" clearance, which is still really close IMO, but that's enough room to also slip some heat shielding between the fans and exhaust.
Part of the reason for the high temps i think is the turbo and exhaust are so close to the radiator, so gaining clearance in that area will make a big difference I think.
We will see tomorrow hopefully, when my tuner gets back to tuning.
The Following User Says Thank You to mike the snake For This Useful Post:
Ironsquid (02-02-2014)
Old 02-02-2014, 09:55 PM   #716
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
That sounds nice Mike, I have data on my current setup, I'll see what I get after the new changes, then I'll try out what you suggested. Thanks
Ironsquid is offline   Reply With Quote
Old 02-03-2014, 08:27 PM   #717
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Ordered stage 1 base with gtx2867r, act 6 puck and some other parts from a local dealer, top speed motorsports!
The Following 2 Users Say Thank You to Reaper For This Useful Post:
Dipstik-sportech (02-03-2014), Sterz (02-04-2014)
Old 02-03-2014, 08:29 PM   #718
jamesm
Originally Posted by Ironsquid View Post
Going to go with their Radiator and Shroud kit and SPAL fans, then remove the mishimoto oil cooler and opt for the FB one.
This should relocate the hot air from the oil cooler to the side fender area instead of flowing onto the IC and Rad.
My downpipe is heat coated AND wrapped, and the turbo is blanketed.
With the new rad and shroud I think that might do it, if not I might try a new racing thermostat.
If that doesn't work, I might try to engineer some air excavation for the bay, I already have a vented hood.
Thanks for the link though
give me a deal on your mishimoto?
Old 02-04-2014, 08:11 AM   #719
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Done
The Following User Says Thank You to Ironsquid For This Useful Post:
jamesm (02-04-2014)
Old 02-04-2014, 09:42 AM   #720
jamesm
woohooo just in time for another brutal summer
Old 02-04-2014, 11:45 AM   #721
Sterz
Great White
Drives: 2013 Whiteout FRS
This is the worst wait of my life haha. All I am waiting on is my FBM Radiator fans and shroud and the FBM Oil Cooler. The rest of the kit is in the car. I seriously cannot wait. WHERE ARE YOU FEDEX?!
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
Old 02-04-2014, 11:46 AM   #722
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Originally Posted by Sterz View Post
This is the worst wait of my life haha. All I am waiting on is my FBM Radiator fans and shroud and the FBM Oil Cooler. The rest of the kit is in the car. I seriously cannot wait. WHERE ARE YOU UPS?!
Fedex UPS guys might disappoint you
FullBlown is offline   Reply With Quote
The Following User Says Thank You to FullBlown For This Useful Post:
Sterz (02-04-2014)
Old 02-04-2014, 11:48 AM   #723
Sterz
Great White
Fixed lol
The Following User Says Thank You to Sterz For This Useful Post:
ZionsWrath (02-04-2014)
Old 02-04-2014, 11:57 AM   #724
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Fixed lol
I'm just giving you a hard time. Just tracked it and its on the truck ready for delivery.
The Following 2 Users Say Thank You to FullBlown For This Useful Post:
Sterz (02-04-2014), ZionsWrath (02-04-2014)
Old 02-04-2014, 12:01 PM   #725
Sterz
Great White
Thank you LJ you are the best! Looks like I will be driving my car home from the shop tonight or tomorrow...the excitement...
Old 02-04-2014, 03:13 PM   #726
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Added:
@Ironsquid
http://www.ft86club.com/forums/showthread.php?t=57303
@Reaper
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Ironsquid (02-04-2014), ZionsWrath (02-04-2014)
Old 02-04-2014, 04:09 PM   #727
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
LJ hopefully the FedEx guys are little more gentle with this order.. Im like picturing an aluminum foil crunch ball at my doorstep
The Following 2 Users Say Thank You to Ironsquid For This Useful Post:
jamesm (02-04-2014), ZionsWrath (02-04-2014)
Old 02-04-2014, 04:12 PM   #728
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Your Fedex guy hates you haha.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
