Old 02-02-2014, 07:41 PM   #15
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
Just trim down the stock snorkel going in to the air box and call it good. Go Seahawks
skye67 is offline   Reply With Quote
Old 02-02-2014, 10:46 PM   #16
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
None of them. filter and win
The Following User Says Thank You to SkAsphalt For This Useful Post:
zooki (02-02-2014)
Old 02-04-2014, 12:50 AM   #17
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
Originally Posted by Turdinator View Post
Best in terms of what? Power? Drivability? Bling?
The stock setup with a drop in filter is best for drivability and fairly good on the power but obviously only looks stock. With a tune something like the Perrin 3" will probably get the most power but you NEED a tune. Not sure if Unichip will work with it or not. For bling, well thats your personal choice whats best.
Personally I have a Perrin drop in filter and silicon tube with a Max Racing dynamic duct. I also removed all the resonators for some extra induction noise. Looks good, sounds great, drivability suffered a littledown low but the top end flys.
you had to remove the crash bar to fit the maxracing air duct? or did u crash it? it looks fuked up or maybe just cause u unbolted the one side... how is it removed? thanks
NYCsubaruBRZ is offline   Reply With Quote
Old 02-04-2014, 12:57 AM   #18
NYCsubaruBRZ
Originally Posted by FRS-Jonathan View Post
i forgot where i read it but supposedly the injen had the best gains but also had a bog issue, forgot but there was a thread with dyno plots on various ones
i have the injen... no problems here just lots of power... yes i have herd of a few problems and also cel. but i ran it without a tune for 6,000mi without problems. (i herd an intake backfire 2 or 3 times but it didnt bother me) now i have the injen intake with a tune, exhaust, headers, pulleys and still no problems... havent herd any intake backfires since tune.. BUT..... it did bog on me a few times when i gave too much throttle from a stop on a cold day. but if you back off, it un-boggs and the only time it will bog is if you are at a dead stop and mash the throttle with the clutch out in 1st gear if your going more than 5mph it will never happen. it hasnt happened in months... i love my setup.
Old 02-04-2014, 06:07 PM   #19
Turdinator
Señor Member
Turdinator's Avatar
Had to remove the bumper and the crash bar to install the duct. I got lazy and didn't fully remove the crash bar. The bumper is relatively easily removed and there are a few DIYs on doing it. The crash bar is held on by 8 bolts and is a piece of cake to remove. Altho from memory I had to take the washer bottle off to get to a couple of the bolts. I installed the duct in less than 3hrs and could do it again much quicker, I was just going slow because it was my first time removing the bumper.
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
NYCsubaruBRZ (02-05-2014)
Old 04-28-2021, 01:56 PM   #20
rikixass
rikixass's Avatar
According to my ECUTEK tuner, CAI is not necessary.
rikixass is offline   Reply With Quote
The Following User Says Thank You to rikixass For This Useful Post:
jcw99 (04-29-2021)
Old 04-29-2021, 01:04 AM   #21
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Thank you for your contribution to a 7 year old thread.
The Following User Says Thank You to x808drifter For This Useful Post:
Apoc (05-08-2021)
Old 04-29-2021, 09:18 PM   #22
Lantanafrs2
Drives: 2013 frs red
Lol
Lantanafrs2 is online now   Reply With Quote
Old 04-29-2021, 09:21 PM   #23
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Yes.
MS, CSCS, TSAC-F, CPT
Old 05-07-2021, 08:36 PM   #24
czellers
czellers's Avatar
Drives: 2K19 GT86
I've had the Skunk2 Powerbox for about 800 miles.
Other mods:
- Tomei Expreme UEL Header
- DC Sports Overpipe
- Invidia N1 (muffler delete)
- OFT Stage2+ E85 OTS Tune
It's not a daily for me, but its a completely closed system, with a large inlet. Install wasn't too bad at all, the bumper has to come off but filter cleaning/changing is all under the hood (but again it's an airtight setup).
Really happy with it, really not much induction noise at all. (I'm running it with the removable baffle in for now until I get a real tune). It was also on sale at 86 speed dot com. Like 250 USD I think..
czellers is offline   Reply With Quote
Old 05-30-2021, 11:04 PM   #25
jflogerzi
jflogerzi's Avatar
Don't waste money on intake. Stock CAI is fine.
Save your money for OFT, then header.
2013 Series 10 FRS #553
Old 05-30-2021, 11:34 PM   #26
PulsarBeeerz
Drives: JRSC BRZ SOLD
Nothing off the shelf beyond the Revolution Garage intake seems worth it. Stock is ok, but its not hard to beat if you have some imagination and light fabrication skills.
PulsarBeeerz is offline   Reply With Quote
Old 05-31-2021, 09:22 AM   #27
Calum
That Guy
Drives: 2013 asphalt FRS MT
At $2500, that intake isn't worth it either.
Sent from my Pixel 4a (5G) using Tapatalk
Old 05-31-2021, 10:39 AM   #28
JD001
JD001's Avatar
Drives: Subaru BRZ
I have the Takeda CAI, it's a really nicely presented unit, looks almost OEM.
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
cold air intake? carbonBLUE Engine, Exhaust, Transmission 72 09-30-2013 12:56 PM
GI/FS: AMR Cold Air Intake Kuzuri Engine, Exhaust, Bolt-Ons 5 08-19-2013 08:58 PM
Cold Air Intake randillio Cosmetic Modification (Interior/Exterior/Lighting) 3 05-29-2013 07:37 PM
TRD Cold Air Intake scioneric Canada Classifieds 1 05-02-2013 07:37 PM
