Old 01-31-2014, 12:02 AM   #57
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
Just so we're clear: The sound OP is talking about is NOT the start-up-dance backfire lump.
Evil Jesus is offline   Reply With Quote
The Following User Says Thank You to Evil Jesus For This Useful Post:
strat61caster (01-31-2014)
Old 01-31-2014, 01:59 AM   #58
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by whtchocla7e View Post
It was once speculated that it's the flywheel that makes this noise. It should go away after you drive for a while and the car is fully warmed up. It goes away for me at least.
I listened extra hard today. It does sound like it's coming from the flywheel area, and comes and go with the clutch in/out
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 02-02-2014, 11:59 AM   #59
kuhlka
Drives: 2013 BRZ Limited AT
Cars with automatic trans do the same thing. You might notice that if you put the car into gear, push in the clutch, or otherwise get rolling it goes away immediately. I've been told by several tuners that the noisy startup is due to the way the car tries to heat up the catalytic converter. There isn't much they can do to change the startup sequence.
kuhlka is offline   Reply With Quote
Old 02-03-2014, 12:59 PM   #60
Moe23
Drives: 2014 Scion FRS MT
than why does the sound go away when the clutch is pushed in? what does the clutch have to do with the catalytic converter?
Moe23 is offline   Reply With Quote
The Following User Says Thank You to Moe23 For This Useful Post:
strat61caster (02-03-2014)
Old 02-03-2014, 01:26 PM   #61
frslee
Just drive it
Drives: 13' FR-S
Happened to me few times when it was extremely cold. The engine would make bap bap sound for 2-3 times and it goes away after it warms up. Never happens during warm weather.
frslee is offline   Reply With Quote
Old 02-03-2014, 06:44 PM   #62
kuhlka
It's not the cat that's making the sound. My car has no cat in the header and it makes the same loud cut-out sound. It's the startup fueling. The car starts up with TONS of negative timing until the car warms up. When I bump my automatic into drive it seems to bypass that noisy startup sequence and go straight to the 'warmed-up' idle of ~750 rpm. If people with manual trans are reporting pushing in the clutch does the same, it's probably because the ECU is detecting the driver is wanting to get rolling.
I've chatted with a few tuners about startup and this is my best guess as to what's going on. I can reproduce it just about every time I start up when it's under 40F out IFF I just let the car idle to warm-up. If I go into gear a few seconds after start-up, the revs immediately drop and the car smooths out.
The Following User Says Thank You to kuhlka For This Useful Post:
Bristecom (02-03-2014)
Old 02-05-2014, 08:51 PM   #63
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Wow glad I found this thread..
I just recently turbo'd my car so I have been paying extra close attention to every little noise the car makes.
I heard this at idle and was getting worried.. but it goes away as soon as there is any load on the engine.
I had my tuner raise my idle a tiny bit and now it doesn't do it at idle, but it still does it when I give the gas pedal the tiniest little tap. The car wants to studder and then "knock".
I have a hunch it is something to do with the idle/not under load timing.. or piston slap... but whyy..
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following User Says Thank You to woode For This Useful Post:
Moe23 (02-06-2014)
Old 02-06-2014, 09:08 PM   #64
Moe23
you must have changed the clutch since you turbo'd your car, but did you by any chance change the flywheel?
Old 02-06-2014, 09:34 PM   #65
woode
Boosted Member
woode's Avatar
yes, and no the noise I am talking about isn't the flywheel - that definitely makes it's own rattle
Moe23 (02-07-2014)
Old 02-07-2014, 09:20 AM   #66
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
Also glad i found this thread, we have been having cold mornings in houston as of late and my car started making this noise. First i thought it was rod knock but realized it wasnt following RPM. My guess is it has something to do with the engine rocking/shaking when it hasnt warmed up yet. I first noticed it after adding the positive shift bushing into my transmission, but not sure if this is related.
lickitysplit is offline   Reply With Quote
Old 02-07-2014, 12:57 PM   #67
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Mine was definitely flywheel/clutch rattle. Goes away with the clutch pushed in.
ineedyourdiddly
Old 02-07-2014, 04:02 PM   #68
Moe23
ya your right, i heard it again this morning and i realized it wasn't coming from the engine. i listened carefully and noticed it was coming from the transmission, specifically right where the transmission mounts on the engine. I have a feeling that it may be the release bearing or the fork rattling, and once the clutch is engaged and the bearing makes contact with the pressure plate it stabilizes, but thats just a guess
Old 04-11-2014, 11:12 AM   #69
NetMagi
NetMagi's Avatar
Drives: 13 Firestorm FR-S
1800 miles on the clock, and heard it the first time today.
Mine matches the noise from the outside in the second video DEAD-on.
6-spd manual, but other posters were saying they were hearing it on the auto as well.
I was also having idle hunt a little more than usual as well. Nothing to bring it to shudders or throw a code/light, but just varied a bit more.
-Rich H.
Current: 16 Porsche Cayman, 09 Tacoma 4WD, 13 Highlander 4WD, 12 Yamaha WR250R
Past: 13 10-Series FR-S, 13 FR-S, 11 S4, 07 Corolla, 98 Tacoma 4WD, 03 Corolla, 89 Camry, 90 Celica GT-S, 87 Celica GT-S
NetMagi is offline   Reply With Quote
Old 04-11-2014, 03:08 PM   #70
chas3wba0
chas3wba0's Avatar
Drives: Yes
So my first BRZ was totaled and I got a new one in March, and this one doesn't make the sound.... hmmmm
Knocking sound from what sounds like rear suspension husker741 Issues | Warranty | Recalls / TSB 12 04-24-2017 05:26 AM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
Knocking/Rattle on start up. jimbobrand Issues | Warranty | Recalls / TSB 18 01-13-2014 11:34 AM
Bubbling/knocking (but not liquid) sound aside from chirping mike_ekim1024 Issues | Warranty | Recalls / TSB 22 05-05-2013 03:20 PM
Knocking sounds from lowering springs? bbaik Issues | Warranty | Recalls / TSB 7 03-07-2013 11:50 PM
