Old 01-26-2014, 12:27 PM   #1
Casper
Casper's Avatar
Drives: Hot Lava Scion FR-S
Nexus 7 DIY dash install
With this mod, I want to make a tablet mount that secures the tablet, but also allows it to easily be removed from the car – as in, it's something you never leave in the dash. For one, tablets don't tend to handle the heat inside cars during the summer particularly well. Two, why spend this kind of money on a sweet setup and not make it versatile?
My total price (so far) without fabrication: ~$500
Materials:
  • Tablet: 2013 32GB Wi-Fi Nexus 7
  • Amp: [ame="http://www.amazon.com/Alpine-KTP-445U-4-channel-Power-Amplifier/dp/B003VVYL46"]Alpine KTP-445U 4-channel Power Pack Amplifier[/ame]
  • Wiring Harness: [ame="http://www.amazon.com/Metra-70-1761-Wiring-Harness-Speaker/dp/B0002BEQJ8"]Metra 70-1761 Radio Wiring Harness For Toyota 87-Up[/ame]
  • Connectors: [ame="http://www.amazon.com/50pcs-Bullet-Shrink-Crimping-Terminals/dp/B00FIK6LX2"]20pc 16-22 gauge Terminal Wire Connectors[/ame]
  • Audio Input: Generic Bluetooth receiver
  • Charging: [ame="http://www.amazon.com/Lerway-Wireless-Power-Charger-Lumia920/dp/B00E9MUNWU/ref=sr_1_3?ie=UTF8&qid=1390754800&sr=8-3&keywords=wireless+charger"]Lerway Wireless Qi Power Charger Pad[/ame]
  • Aux Power: [ame="http://www.amazon.com/Ultra-Compact-High-Output-Charger/dp/B00470C35E/ref=sr_1_10?ie=UTF8&qid=1390754929&sr=8-10&keywords=2.1a+usb+charger"]2.1A dual USB car charger[/ame]
  • Power supply: [ame="http://www.amazon.com/Motorcycle-Cigarette-Lighter-Outlet-Socket/dp/B007BIUKLI/ref=sr_1_2?ie=UTF8&qid=1390754911&sr=8-2&keywords=12v+cigarette+socket"]Female 12v socket[/ame]
  • Fuse Adapter: Generic Fuse Adapter
  • 10A Fuse
Update #3: Part 1 of the video is now available! Finally!
DIY Nexus 7 Head Unit Replacement Part 1: Materials and Installation
I used this wiring detail and RandomHero's thread for help with the re-pinning of the wiring harness.
I'll be back in a few hours with pictures of the wiring harness and how I pinned it.
Here's how it looks … for now.
Casper is offline   Reply With Quote
The Following 6 Users Say Thank You to Casper For This Useful Post:
Coreyviper (02-03-2014), DjDATZ (02-04-2014), evil_1998 (02-10-2014), Reflex (02-12-2014), ToyoburuBRZ (01-26-2014), YW-Slayer (01-26-2014)
Old 02-02-2014, 04:58 AM   #2
Braindead
Drives: BRZ 2013
Very keen to see your how to video. I want to do this myself, and have a nexus 7 ready and waiting. Wiring/electrical stuff isn't really my forte, and I haven't seen any detailed guides to do it.
Braindead is offline   Reply With Quote
The Following User Says Thank You to Braindead For This Useful Post:
DjDATZ (02-04-2014)
Old 02-03-2014, 01:41 AM   #3
Casper
Casper's Avatar
It isn't really my expertise either. ;-)
But I was determined to do this, and it's turning out better than I expected, honestly.
The Following User Says Thank You to Casper For This Useful Post:
Old 02-03-2014, 02:07 AM   #4
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
good stuff. I am deep into mine as well. I will have some custom skins for torque and such so will post that up once done and ready.
gdrider77 is offline   Reply With Quote
Old 02-04-2014, 04:16 PM   #5
DjDATZ
EightSixClub Co-Founder
DjDATZ's Avatar
Drives: Selina (FR-S), Rondo EX V6 & fortwo
Looks good so far, curious about how much work it will be to set up! I'll watch all the videos and get it set up!
Currently wondering if I should have an amp in the car, considering I'm already hooking a Nexus 5, iPhone 4S, dashcam, and RD into the car, and looking at hooking another dashcam and the N7 into it.
Meet Selina, my Asphalt FR-S MT6.
Like EightSixClub on FB, and follow us on Twitter!
DjDATZ is offline   Reply With Quote
Old 02-06-2014, 01:24 PM   #6
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
@Casper
Interested into seeing how you wired in that amp instead of using a standard head unit. If I understand it correctly, N7 bluetooth ->iClever BT receiver -> Alpine amp via BT/3.5mm -> stock wiring harness?
I did mine like this: N7 BT->Single din Sony headunit-> stock wiring harness. Mine works pretty well, except i have to connect to the headunit every time i start the car, not a huge deal but its something i'd like to not have to deal with.
Trashed675 is offline   Reply With Quote
Old 02-09-2014, 01:27 PM   #7
Casper
Casper's Avatar
Bump for update with video!
Old 02-09-2014, 03:19 PM   #8
transition
Nice job. Why not use the stock amplifier?
transition is offline   Reply With Quote
Old 02-09-2014, 05:17 PM   #9
phloozy
phloozy's Avatar
Drives: Scion FR-S
great video, ill sub. keep it up
phloozy is offline   Reply With Quote
Old 02-10-2014, 09:53 AM   #10
Casper
Casper's Avatar
I wanted this to be easily upgradable. Plus, I'm just directly replacing the head unit, which has its own amp. This was infinitely more simple, especially for a noob (me). Like I said in the intro, I'm not a fabricator or car audio guy. I'm just decent at teaching myself things. Ha
Thanks for the sub and kind words!
transition (02-10-2014)
Old 02-10-2014, 11:12 AM   #11
transition
That makes sense. Thanks for the clarification
Old 02-11-2014, 05:58 PM   #12
Braindead
Drives: BRZ 2013
I haven't had a chance to look at the video yet (at work atm), but are you connecting up an OBD2 adapter to this?
Old 02-11-2014, 07:03 PM   #13
Casper
Casper's Avatar
Yep! Already connected!
Old 02-12-2014, 01:12 AM   #14
Reflex
Drives: Whiteout FR-S
Can your setup make/receive calls via bluetooth and use the microphone to converse? Does the tablet automatically turn on when you start up the car and does it turn off when you turn off the car?
Reflex is offline   Reply With Quote
diy, head unit, install, nexus 7, tablet
Another Nexus 7 install: Clean and Easy Sojhinn Electronics | Audio | NAV | Infotainment 264 10-30-2015 08:26 AM
Request: Dash Cam install w/ pics of A-Pillar/headliner 1Cor10:23 DIY (Do-It-Yourself) Guides 13 01-16-2014 07:31 PM
Problems with NEXUS 7 Install Rhamzy Electronics | Audio | NAV | Infotainment 6 01-03-2014 03:43 AM
Want to install Nexus 7 as head unit....does this cable exist? Necric Electronics | Audio | NAV | Infotainment 3 11-21-2013 03:26 PM
