#29 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Run the tank out and fill with premium. You'll at least have a fighting chance.
The dealer I got mine from thought all the Scions ran on regular. No clues to be had anywhere.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | dssence (02-02-2014) |
#30 | |
Drives: Toyota FT/MT 86
To make matters worst stupid dealer forgot the underside rubber grummets and the rubber pads which go on top of the suspesion struts. PD: Could this be a manufacture fault from your view? I would have to have at least a cel on I think.. car is working fine no strange noises nor anything.. just this annoying fuel thing |
#31 | |
Drives: Neptune GR86
I couldn't imagine this being different from car to car.
| The Following User Says Thank You to Andrew025 For This Useful Post: | dssence (02-02-2014) |
#32 |
#33 | |
I would suggest you fill up your car's tank with premium gas (til the pump clicks off) and re-set the trip odemeter to 0. Drive, keeping the rpms below about 4,000, till the tank is down to 1/4 full. Fill up at the same station at the same pump (to click off). Divide the miles driven by the gallons of gas consumed (or kilometers/liters). Do this about 3 times, checking your milage each time. This will give you a good idea of your average gas milage. Then come back with your findings ......
#34 | |
Drives: 2003 S2000, 2008 Fit
I use it to gauge how much unnecessary consumption I am causing (i.e. if I'm not in "fun mode") |
#35 | |
Drives: UltraMarine FRS MT
I must disagree with you here. First of all, coasting downhill in neutral is somewhat dangerous, and it eats up brake pads a lot more. Also, when you cost IN gear, you consume 0 gas, because your engine is driven by the "wheels". However, if you coast NOT in gears but in neutral. You are actually consuming gas. The engine has to inject a small amount of gas into the engine in order to keep the engine spinning, or else the engine will stall. Do correct me if I'm wrong though. Last edited by Cyau; 02-03-2014 at 06:11 AM. |
| The Following User Says Thank You to Cyau For This Useful Post: | Marchy (02-06-2014) |
#36 | |
Drives: 2019 BMW ///M4
#37 |
Drives: 2020 BRZ tS #54
sorry to ask.. but i drive a sports car
whats MPG?
#38 |
Drives: 2013 Subaru BRZ
This is personally my perspective, others may agree or disagree. If fuel economy is that important, might as well get an economy car for good fuel mileage. I always hear individuals complain about fuel economy or how to achieve good fuel economy, but they are driving vehicles that aren't meant to be super good on fuel economy.
Back to the thread. I usually shift around 3000 rpm and drive like a turtle from the get go; however, it annoys me when someone behind me is tailing my butt because I'm starting off slow. |
#39 | |
More horsepower, better handling, and better fuel efficiency! FRS ftw.
#40 |
If you car is brand new, your gas mileage will increase after the first couple of tanks.
Also as others have said, upshift before 3000 rpm and whenever you're moving at a constant speed (highway, etc.), upshift into the lowest gear possible.
2022 BRZ Build 2013 FR-S Build |
#41 | |
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
#42 |
Hey so you mean to upshift before 3k rpm but didn't understand what you meant by upshift into the lowest gear? what for would you upshift into a lower gear? that would be to lower speed . Dont' get it
| Why isn't the fuel economy better? | White Shadow | Scion FR-S / Toyota 86 GT86 General Forum | 495 | 10-28-2019 09:21 AM |
| Fuel economy deteriorating?? | newbrz | Issues | Warranty | Recalls / TSB | 33 | 03-14-2014 03:26 PM |
| What fuel economy numbers are you getting? | Chimpo | Scion FR-S / Toyota 86 GT86 General Forum | 53 | 01-05-2014 04:55 PM |
| Fuel economy | ozne99 | BRZ First-Gen (2012+) — General Topics | 48 | 12-11-2012 01:55 PM |
| Fuel Economy | Lexicon101 | Engine, Exhaust, Transmission | 38 | 02-22-2010 04:50 PM |
