Old 01-10-2014, 09:57 PM   #1
newbrz
Drives: Limited Dark Gery Metallic BRZ
Fuel economy deteriorating??
Hi guys I really need your help in this one. I love this forum from all that I have learned about my car and I'm counting on you to help me with this. My BRZ has 16k miles on the odometer. At around 12k, I dropped a perrin CAI and catback and a few miles later got it tuned with ECUTEK. I noticed that the fuel economy was being great; but about 3 weeks ago I've seen it getting worse. A LOT. My comparison is based through this process: I normally use the cruise control (I make a lot of long trips) at X speed. The mileage dropped about 4-5mpg at the same speed. This has happened before but if it is windy, or I have a lot of stuff in the trunk, or having a bike rack on. Nevertheless, this is becoming constant. I used to have almost 27mpg on average and dropped around 26mpg. My driving style hasn't change or anything; even if it did, just by comparing consumption with cruise control is alarming for me. Also note, as soon as I had the accessories installed, there was no change in consumption, it even got better! I've been experiencing this for around 3 weeks while the accessories where mounted around 3 months ago. I don't know if it may be normal for the those upgrades or probably a deeper problem. Thank you beforehand for any help!!
newbrz is offline   Reply With Quote
Old 01-10-2014, 10:11 PM   #2
fatherfork
Fears Hiccups
fatherfork's Avatar
Drives: Toyota badged 2013 Whiteout FR-S
Check your tire pressure. Under-inflated tires can cause lowered mileage, and the timing sounds about right.
fatherfork is offline   Reply With Quote
Old 01-10-2014, 11:47 PM   #3
subwaynm
subwaynm's Avatar
Drives: Scion FR-S Coupe
Just a hunch but have you serviced your Trans as yet ? I've read I think two threads on servicing your Trans due to issues with them; and that might hurt your MPG also
subwaynm is offline   Reply With Quote
Old 01-10-2014, 11:54 PM   #4
Pete156
I like to eat!
Wait, your average mPG went from 27 to 26 and that is A LOT worse? WOW
Pete156 is offline   Reply With Quote
Old 01-11-2014, 12:28 AM   #5
humfrz
Hi ya newbrz .....
Let's see if I'm understanding you correctly. Your fuel mileage has dropped from 27 to 26 MPG .... ??
Or, dropped 4-5 MPG .. ??
If it's the former, that just could be within experimental error. Or, that winter blends of gasoline sometimes yield less fuel economy. Or, like mentioned, tire air pressure might be a bit lower.
How are you checking your mileage (calculation vs. the onboard monitor)?
humfrz
Old 01-11-2014, 01:25 AM   #6
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
Lmao a less than 1 mpg drop?
Come on man
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 01-11-2014, 01:27 AM   #7
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
mine dropped 3 MPG when the winter blend gas came out whats wrong with 1 mpg?
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 01-11-2014, 01:55 AM   #8
Pizzman
Crap another obsession.
Drives: 2013 BRZ Limited
Cruise control is not efficient, especially on hills, that with tire pressure, and driving style are the other options. You would hear and or feel (if you are one with your car. IE bearings or trans)any mechanical issues that would result in heavy fuel consumption. Also are you running the recommended oil. That would f up your mpgs as well. Take it in for service if none of these sound like a problem.
Pizzman is offline   Reply With Quote
Old 01-11-2014, 02:20 AM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Winter blend gasoline.
... and 1MPG is not conclusive. How are you measuring this 1MPG drop?
-alex
Old 01-11-2014, 02:37 AM   #10
Poodles
Drives: 2015 Series.Blue
Tire pressure is out because of the TPMS system. It's more likely the winter blend gasoline.
Old 01-11-2014, 04:54 AM   #11
strat61caster
strat61caster's Avatar
Even a couple PSI is noticeable in relation to fuel economy, the light isn't a gauge, just a 'check your tires dummy' light.
They could easily be down around 32 psi and for fuel economy I wouldn't be surprised if people were running the oem tires up to ~40 psi. For the record I believe recommended pressure is 35-36.
ineedyourdiddly
Old 01-11-2014, 12:19 PM   #12
zohare
zohare's Avatar
Drives: '13 Firestorm Base AT
Mine's gone to shit after a long block replacement, from about 31 cruise, 33 self modulated to I CANNOT break 27. No matter what. But I hadn't considered winter blend? Thinks to be noted... tire pressure is slightly low at times.... worth maybe 1 or 2 tops mpg wise. I'm suspecting a manifold leak though.... The motor replacement has been an absolute nightmare. As far as servicing the trans, you're talking MT right?
zohare is offline   Reply With Quote
Old 01-11-2014, 12:50 PM   #13
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Do you have actual data or are you guessing based on the car computer?
ntron1 is offline   Reply With Quote
Old 01-11-2014, 04:49 PM   #14
Bad Habits
Bad Habits's Avatar
Drives: br zed
Mine drops 2mpg if I drink too much lager and eat too much pizza.
Bad Habits is offline   Reply With Quote
brz, ecutek tuning, issues, mileage, tune
Why isn't the fuel economy better? White Shadow Scion FR-S / Toyota 86 GT86 General Forum 495 10-28-2019 08:21 AM
What fuel economy numbers are you getting? Chimpo Scion FR-S / Toyota 86 GT86 General Forum 53 01-05-2014 03:55 PM
Fuel economy ozne99 BRZ First-Gen (2012+) — General Topics 48 12-11-2012 12:55 PM
Optimistic fuel economy? nubbster927 BRZ First-Gen (2012+) — General Topics 15 07-05-2012 08:50 PM
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 03:50 PM
